Ny morsom GTA/Coca-cola reklame
DesertGlow
Error establishing a database connection
This either means that the username and password information in your wp-config.php file is incorrect or we can't contact the database server at 195.128.174.34. This could mean your host's database server is down.
Are you sure you have the correct username and password?
Are you sure that you have typed the correct hostname?
Are you sure that the database server is running?
If you're unsure what these terms mean you should probably contact your host. If you still need help you can always visit the WordPress Support Forums.
Får ikke sett! :cry: Skjønner ingenting jeg.
Ser ut til at SQL-serveren ble restartet, er ikke noe problem her nå. Samtidig har nå YouTube tatt ned sine servere for oppgradering, så videoen er i skrivende øyeblikk utilgjengelig. Youtube er sikkert oppe igjen om et par timer.
Edit: Og nå ser YouTube ut til å være tilbake også.
Endret av DesertGlow
