brenning av bin filer!
Nero can burn BIN image too, so give Nero a try see if it works on your
system. Here is how to burn BIN image using Nero
1. Select "File" -> "Burn Image" and tell it to load .BIN image
2. It will pop up a menu say "It's a foreign or unknown image file. You
must set options to burn this image. Would you do it?"
Just click "OK" to continue.
3. It then pop up another menu, and all you need to do is setting the
MODE's and the information you get from .CUE file comes with the .BIN
image. If the .CUE says MODE-1 then check the "block size" and change
to correct #'s if needed. If the CUE says MODE-2 then just change to
MODE-2 then select "OK" to continue.
If you select wrong mode then it may warn you and may not continue (I
tried to mess around with it but don't want to go too far yet).
4. Then "WRITE" to start. I have unchecked the "determine" and
"simulation" as it takes too long to test, and the CD-R costs me only
60 cents so spend an hour testing not worth it.
