Formatere
Pug
Jeg så på en guide for å instalere XP... Da stod det:
If you know which drive for certain you want to install Windows XP on, choose the drive and hit C for "create partition". You will have to hit D to "delete partition" if there are any problems with the old partition. This is recommended if you plan on doing a clean install as it could avoid problems during the install. Once you’ve deleted the partition, you will have to recreate it by hitting C.
If you create a partition, it’s best in most cases to use the whole drive for the partition. This might avoid confusion later with drive names.
If you don’t want to create a new one or you are ready to install, choose the desired partition and hit the Enter key. If it prompts you to choose either FAT or NTFS, you would probably be best suited with FAT (in this case, FAT32). It offers some advantages over NTFS (although it also has some disadvantages) and it is compatible with more versions of Windows.
Jeg har altså tent å formatere C: . Kan jeg bare ta å delete partisjon C: , for så å lage den på nytt? Er det så enkelt?
