Via drivere eller Realtek drivere?
Via 8235 er southbridge .
• VIA® KT400 Chipset
- FSB @200/266/333 MHz
- Supports DDR200/266/333/400 memory
- AGP 8X and PCI advanced high performance memory controller.
• VIA® VT8235 Chipset
- Integrated Direct Sound AC'97 audio
- Dual channel Ultra DMA 33/66/100/133 master mode EIDE controller
- ACPI & PC2001 compliant enhanced power management
- Integrated USB 2.0 controller
Ser ikke noe om via hd audio ?
Bruk den som ligger her:
http://www.msi.com.tw/program/support/driv...?UID=362&kind=1
Realtek ALC Series Drivers:
All MSI MB with onboard Realtek® Avance ALC Series audio codec controller.
• Realtek AC'97 Sound System driver Ver.A3.87
• Driver version for Win98/WinMe/Win2000/WinXP: 5.10.00.6080
• Driver version for Windows XP 64: 5.10.0.6070
Date 2006-6-12
Du kan også laste ned direkte fra realtek A3.91 (nyere versjon)
http://www.realtek.com.tw/downloads/dlac97...8&Software=True
Endret av syar2003
VIA Vinyl Audio for 8235:
http://www.viaarena.com/default.aspx?PageI...10&SubCatID=104
Grunnen til at jeg lurer, er at jeg husker at endel av NForce1/2 kortene hadde samme situasjon. Man hadde en driver fra NVidia som tok fordel av APU'en med tanke på lydkvalitet og ytelse, og man hadde en driver fra Realtek som ikke gjorde noen av delene.
http://www.nforcershq.com/forum/nforce-aud...04-vt23721.html
Q12: If I am using the analog connections am I taking advantage of the Soundstorm's (i.e. the APU's) ability?
A: As long as you are using the nvidia drivers the APU will be taken advantage of. The realtek codec in that case is soley being used as a DAC. If you install the realtek drivers then the APU will be bypassed and all effects done using the CPU with the usual limitations (number of voices etc). If you have a board without the APU for now it may be better to make use of the realtek drivers otherwise use the nvidia ones.
Så er det samme situasjon her?
Endret av mad_arab
Vel du har ikke via AC97 codec , men realtek.
Codecs supported: This driver supports all VIA southbridges with integrated sound plus several audio codecs as below:
VIA AC97 codec incorporated into VT82C686A/B South Bridges ( )
VIA AC97 codecs incorporated into VT8233, VT8233A, VT8233C, VT8235 and VT8237/R South Bridges ( )
VIA Vinyl audio codecs: VT1612A VT1613 VT1616 VT1617 VT1618 ( )
VIA AC97 codec incorporated into VT8231 South Bridge ( )
VIA AC97 codec incorporated into VT8251 South Bridge ( )
Edit:
Men du kan jo selvfølgelig prøve ....
Endret av syar2003
Jau jeg tviler ikke på at begge deler fungerer, men jeg gidder ikke sitte å benchmarke heller for å finne ut hva som er best...
"VIA Vinyl" er jo en greie som VIA reklamerer for, så det må jo være noen features den tilbyr. Og isåfall, skulle man jo tro at man gikk glipp av dem ved å bruke en standard Realtek driver.
