Diskusjonstråd for kosttilskudd
Gjest Slettet+9817234daf
På MyR ligger det 2 ting ute:
Vi i Norden som får lite sollys, spesielt i vinterhalvåret, bør være bevisst på inntaket av Vitamin D i kostholdet. I mange tilfeller, og dette ser spesielt ut til å gjelde kvinner, bør man sterkt vurdere tilskudd av Vitamin D. Denne studien og flere på området, viser at mangel på Vitamin D er hyppig og kan føre til svekkelser i beinstruktur og -styrke, samt redusert muskelfunksjon/styrke.
Vitamin D and its implications for musculoskeletal health in women: An update.
Maturitas. 2007 Jun 28; [Epub ahead of print]
Pérez-López FR.
Department of Obstetrics and Gynaecology, University of Zaragoza, Faculty of Medicine, Domingo Miral s/n, Zaragoza 50009, Spain.
Vitamin D is a hormone that controls phosphorus, calcium, and bone metabolism and neuromuscular function. Vitamin D synthesis is a process in which the skin, liver, and kidney are sequentially involved. The vitamin D pool is completed by the amount taken with food and supplements. Vitamin D deficiency causes osteopenia, precipitates and exacerbates osteoporosis, causes a painful disease, osteomalacia, and increases muscle weakness, which worsens the risk of falls and fractures. A high prevalence of vitamin D insufficiency exists in the apparently healthy population, osteoporotic patients, and patients with prior fractures. Factors contributing to low vitamin D levels include low sunlight exposure, decreased skin synthesis and intestinal absorption, and inadequate diet. The simplest way to correct hypovitaminosis is adequate nutrition and supplements. However, few patients with osteoporosis and/or fractures, receive adequate supplements. Vitamin D insufficiency may alter the regulatory mechanisms of parathyroid hormone and may induce a secondary hyperparathyroidism that increases the risk of osteoporosis and fractures, although the necessary degree of this is not established. Monitoring of serum 25-hydroxyvitamin D levels is the only way to assess vitamin D status. The ideal healthy blood levels of 25-hydroxyvitamin D are controversial, although a range from 30 to 60ng/mL is widely accepted. The role of vitamin D supplementation is to provide humans with the nutrient in an amount closer to the biological norm for our species. This amount of vitamin D results in optimal function of many aspects of health, including balance and muscle strength, thus reducing the risk of fracture beyond what is possible via the quality and quantity of bone itself.
Og
For oss nordboere som får lite sollys – spesielt i vinterhalvåret - kan Vitamin D3 (kolekalsiferol) være et kritisk tilskudd, og det kommer mer og mer forskning på effektene det kan ha på humør, hormoner, kolesterol og generell helse. Høydoseversjonen på apoteket anbefales (tips: mye billigere på helsekost i Sverige), 3000-5000IU per dag, tilsvarende 75-125mcg. Vitamin D2 har så dårlig opptak i kroppen at det ikke kan anbefales. Små doser solarium i vinterhalvåret vil også ha en positiv effekt, men jeg vil være konservativ på dette og anbefaler kun 5-10min 1-2 ganger i uka.
Sammen med denne artiklen Her.
Satt og kikka litt på grønn te tilskudd, og kom over disse to: Burn og Brenn
X-life's Burn inneholder kun koffein (2000mg per dosering).
Mens TN's inneholder bare 1134 mg per dosering, men den inneholder også kalsium, ingefærekstrakt, chilipulver og svart pepperekstrakt.
Synes Brenn virka ganske interesant, men gir alle disse eksta sakene (kalsium, ingefærekstrakt, chilipulver og svart pepperekstrakt) bedre effekt enn bare grønn te? Eller er dette bare bullshit?
Synspunkter?
200 mg er jo under grensa di for kaldsvette da. Det skal sies at jeg ikke får i meg noe koffein til vanlig i løpet av dagen.
Ved høye inntak av koffein (fra 250 til 750 mg) kan hodepine, svimmelhet, rastløshet og kvalme opptre. Dødelig dose koffein er rundt 3 til 20 g koffein, avhengig av toleranse. (wikipedia)Andre kilder mener dødelig dose ligger rundt 8-10 gram eller høyrere enn det (15-20)
Endret av Sir-Andy
  • 2 uker senere...
Om du tar alle de lovlige stoffene med best effekt på en liste og velger de øverste og putter dette i en boks så ender man opp med den som myR selger.
Halle produkter som inneholder de samme stoffene vil da ha effekt.
De fleste produktene øker kroppstempen med 1 grad, noe som krever fler kcal.
Er man på kino så svetter man ihjel (TN-Thermozyne)
Her forklart i MyR-sin.
NeoDiet er designet for alle som effektivt ønsker å gå ned i vekt. Alle ingredienser i NeoDiet er naturlige og har dokumentert effekt. NeoDiet er unik ved at fettlagrene angripes på to måter - grønn te og capsaicin fra cayennepepper øker energiomsetning og forbrenningen, mens fiber som NeoPuntia™ og Chitosan gjør at du lagrer mindre fett fra maten du faktisk spiser.
Det menes tar opp, men da skjønner ikke kundene noe.
Endret av War
Den må forbrenne det, øker aktiviteten i forbrenningen så man blir varm / mer energi.
1 grad var bare et tall, kroppen må jobbe mer og bruker da mer energi.
Det er hele poenget, og jeg svetter iallefall da om jeg er inne med vintertøy.
Skole/kino.
Anbefaler du (et mysepulver alene) ok om man vet hvorfor man kjøper den, som smaker så rart at man må blande i melk + tilsette kakao? Og på toppen av det hele inneholder en del protein fra konsentrater?
Jobbet for de eller sponset og reklamerer så hadde jeg skjønt det.
Men uten om det så er det kun prisen som teller til dette produktets fordel.
Haha, isåfall må jeg ha vært utrolig uheldig med det første jeg kjøpte, som smakte helt forferdelig. Alle jeg kjenner som har brukt litt proteinpulver sier de aldri har funnet noe som er godt, men det har jeg gjort nå. Og det er godt med vann og, men smaker naturligvis ikke like fyldig.:)
Bruker det sammen med kasein fra samme merke og samme smak. Blander vanligvis ca 50/50, noen ganger litt mer i kasein, f.eks hvis jeg tar det nærme søvn.
Det med konsentrater vet jeg ingenting om.
Grunnen til at de ikke er gode er at man skal drikke dette 5-6-7 ganger pr dag i 60? år?
Smaker det godt/søtt så blir man lei.
Ikke første uka, men etter noen år.
Jeg er ikke enig i det, men de som har peil/selger varer påstår dette.
TN og MyR sine tilskudd basert på melkeprotein smaker faktisk godt i vann.
  • 3 uker senere...
Er det noen erfarne folk som kan hjelpe meg litt med kosthold? :D
For å få en liten oversikt over hvor mye mat jeg trenger osv, så jeg vil gjerne ha tilbakemeldinger på måltidet jeg pleier å spise.
Frokost: To rugbrødskiver med skinke. 3 dl melk
Lunsj 11:25: Fire skiver med skinke og ost. 5 dl melk
MIddag: To kyllinglår med ris, saus, salat og mais
Kvelds: To skiver med skinke og skinkeost. 3-4 dl melk. PLuss havregrynsgrøt
Pluss litt småplukk som youghurt, eple, banan, druer...
Veier 72 kilo, er 183 høy. Trener vekter ca 5 ganger i uken. I følge kalorikalkulator.no trenger jeg ca 3000+ kcal for å dekke behovet mitt.
Er den maten jeg pleier å spise nok til å gå opp i vekt?
Edit: Er det en måte jeg kan regne ut hvor mange kalorier jeg får i meg på en dag? Må vel være helt umulig å regne ut kaloriene i en skive med rugbrød, skinke og smør? :hmm:
Endret av Sammy-Lee
Øker effekten av kreatin dersom man bruker et magnesium-tilskudd? F. eks ZMA.
Over 300 enzymes require the presence of magnesium ions for their catalytic action, including all enzymes utilizing or synthesizing ATP
For example, ATP (adenosine triphosphate), the main source of energy in cells, must be bound to a magnesium ion in order to be biologically active.
Kilde: Wikipedia
For å regne ut kalorier kan du bruke Mat på data
Eller "FitDay", som er utrolig bra ( http://www.fitday.com/ ).
Online-versjonen er gratis, men om du ønsker å bruke $30, så får du den nedlastbare versjonen (installeres på PC'n) som gjør alt det online versjonen kan gjøre + enda mer.
Eller du kan lage deg ditt eget Excel regneark, ved å plotte inn verdier for hver enkelt vare du måte ønske :)
Endret av Requi
