Penger å tjene - hør forskjell på høyttalerkabler
Lch
Nei, dette er ikke tull eller spam.
$2500 å tjene på å treffe minst 16 av 20 ganger i en dobbel-blind AB/X-test. Ikke verst.
rec.audio.high-end
Quote:
Since BEAR seems to have decided to ignore the 'cable challenge', for whatever reasons, let's try another tack.
Is there *anyone* out there who really *does* believe that one cable sounds better than another?
The prize pool is somewhere around the $2500 mark, and all you have to do is demonstrate that you can hear the difference between any two cables which meet a very simple level-matching criterion.
The basic rules are as follows:
Cables must be level-matched from 20Hz to 20kHz, within +/- 0.1dB at the speaker terminals. Any conductor and insulation materials are allowed, and any cable construction is allowed.
The test protocol will be double-blind ABX, implemented in whatever way is both practical for the circumstances, and acceptable to all
interested parties. The test will comprise 20 trials, the 'pass' criterion being correct identification in 16 out of the 20 trials.
The rest of the system (source, amplifier, speakers and listening room) is at the choice of the test subject, as is the selection of
music, and the duration of the individual trials.
We have all seen the numerous claims made for 'high end' cables, and many posters claim to hear 'huge' differences, so there should be no problem in beating this straightforward challenge in the poster's own 'reference' system, with his own choice of music, right?
Who will be the first to put his ears where his mouth is, and claim the prize?
Stewart Pinkerton | Music is Art - Audio is Engineering
Edit: Slem linjebrekking og subject
[ Denne Melding var redigert av: LarsC på 2002-10-20 23:28 ]
