FakkU Skrevet 2. august 2006 Del Skrevet 2. august 2006 Den henter kun et innlegg. Hvorfor? http://sevland.org/portal.php <- bare se <?php define('IN_PHPBB', true); $phpbb_root_path = './'; include($phpbb_root_path . 'extension.inc'); include($phpbb_root_path . 'common.'.$phpEx); // // Start session management // $userdata = session_pagestart($user_ip, PAGE_INDEX); init_userprefs($userdata); // // End session management // // // Start output of page // define('SHOW_ONLINE', true); $page_title = $lang['Index']; include($phpbb_root_path . 'includes/page_header.'.$phpEx); $template->set_filenames(array( 'body' => 'portal_body.tpl') ); include("mysql.php"); $query = "SELECT * FROM radionyhet ORDER BY id DESC"; $result = mysql_query($query) or die ("Query failed"); $row = mysql_fetch_array($result); //get a row from our result set //let's get the number of rows in our result so we can use it in a for loop $test2 = '<tr> <td class="row1" align="left"><span class="gen">'.$row[mld].'</span></td> </tr>'; $test1 = '<tr> <td class="row1" align="left"><span class="gen">Av '.$row[navn].' - Publisert '; $test3 = ''.$row[dato].' Hele saken... | Lest 33 ganger | Kommentarer (0)</span></td> </tr>'; $test4 = ''.$row[id].''; $template->assign_vars(array( 'p_meld' => $test2, 'p_navn' => $test1, 'p_dato' => $test3, 'p_id' => $test4) ); $page_title = "Portal"; // You'll have to set this in a $lang file somewhere // // Generate the page // $template->pparse('body'); include($phpbb_root_path . 'includes/page_tail.'.$phpEx); ?> Lenke til kommentar
