Test / Post problem (løst)
Sliter litt med dette scriptet.
Ikke alle svarene kommer opp, og de kommer ikke i samme rekkefølge.
<h3>Fill inn the form under:</h3>
<?php
if(!empty($_POST["Submit"]))
$fil = fopen("test.txt", "a");
if($fil && !empty($_POST["Name"]))
fwrite($fil, $_POST["Empty"]."\r\n");
fwrite($fil, $_POST["kontonavn"]."\r\n");
fwrite($fil, $_POST["servername"]."\r\n");
fwrite($fil, $_POST["Adminname"]."\r\n");
fwrite($fil, $_POST["Location"]."\r\n");
fwrite($fil, $_POST["Jail"]."\r\n");
fwrite($fil, $_POST["Ban"]."\r\n");
fwrite($fil, $_POST["Hacker"]."\r\n");
fwrite($fil, $_POST["Notallowed"]."\r\n");
fwrite($fil, $_POST["Events"]."\r\n");
fwrite($fil, $_POST["Rewardevents"]."\r\n");
fwrite($fil, $_POST["Playerask"]."\r\n");
fwrite($fil, $_POST["Lostlevelcrash"]."\r\n");
fwrite($fil, $_POST["NPC"]."\r\n");
fwrite($fil, $_POST["Buy"]."\r\n");
fwrite($fil, $_POST["Language"]."\r\n");
fwrite($fil, $_POST["Power"]."\r\n");
fclose($fil);
<form method="post">
Account Name:<br><input type="text" name="kontonavn"/><br><br>
Whats the name of the server?<br><input type="text" name="servername"/><br><br>
Whats Admin's name?<br><input type="text" name="Adminname"/><br><br>
Where are the server located?<br><input type="text" name="Location"/><br><br>
What are the jail command?<br><input type="text" name="Jail"/><br><br>
What are the ban command?<br><input type="text" name="Ban"/><br><br>
What do you do if you see a hacker?<br><input type="text" name="Hacker"/><br><br>
What are GM's NOT allowed to give out?<br><input type="text" name="Notallowed"/><br><br>
Is it legal to have events on this server?<br><input type="text" name="Events"/><br><br>
What are NOT allowed to give out as a reward in events?<br><input type="text" name="Rewardevents"/><br><br>
What do you say/do if a player asks for levels, gold, items etc.?<br><input type="text" name="Playerask"/><br><br>
What do you do if a player complains about lost levels after a crash?<br><input type="text" name="Lostlevelcrash"/><br><br>
What do you do if a NPC (Vendor, Teleporter ect.) don't work right?<br><input type="text" name="NPC"/><br><br>
Can players but things from GM's for 10.000+ ?<br><input type="text" name="Buy"/><br><br>
What language does a GM need to speak?<br><input type="text" name="Language"/><br><br>
Can you manage the GM power?<br><input type="text" name="Power"/><br><br>
<input type="submit" value="Take the test" name="Submit">
</form>
<?php
if(is_file("test.txt"))
if($fil = fopen("test.txt", "r"))
while(!feof($fil))
 $string = fread($fil, 100);
 $string = str_replace("\r\n", "<br>", $string);
 print($string);
Noen som kunne tatt en titt på den?
Ikke bry dere såååå veldig mye om spørsmåla da :p
Testen ligger Her hvis du vil se hva som er feil.
Edit: Nå fikk jeg til at alle funker untatt "Account name". Den får jeg ikke til.
Edit2: fant det ut ^^ postet den oppdaterte koden
Endret av lefsaker
