For ikke startet X i ubuntu LØST!
Nyinstallert Ubuntu(uten gnome\KDE, skal kjøre fluxbox) og har installert xorg og xdm. Men X\xdm vil ikke starte.
X Window System Version 7.0.0
Release Date: 21 December 2005
X Protocol Version 11, Revision 0, Release 7.0
Build Operating System:Linux 2.6.15.7 i686
Current Operating System: Linux GakkBox 2.6.15-23-386 #1 PREEMPT Tue May 23 13:49:40 UTC 2006 i686
Build Date: 16 March 2006
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Thu Jul 27 17:46:56 2006
(==) Using config file: "/etc/X11/xorg.conf"
error opening security policy file /etc/X11/xserver/SecurityPolicy
(EE) xf86OpenSerial: Cannot open device /dev/wacom
No such file or directory.
Error opening /dev/wacom : No such file or directory
Could not init font path element /usr/share/X11/fonts/misc/, removing from list!
Could not init font path element /usr/share/X11/fonts/TTF/, removing from list!
Could not init font path element /usr/share/X11/fonts/OTF, removing from list!
Could not init font path element /usr/share/X11/fonts/Type1/, removing from list!
Could not init font path element /usr/share/X11/fonts/CID/, removing from list!
Could not init font path element /usr/share/X11/fonts/100dpi/, removing from list!
Could not init font path element /usr/share/X11/fonts/75dpi/, removing from list!
Fatal server error:
could not open default font 'fixed'
Thu Jul 27 17:46:59 2006 xdm error (pid 3845): IO Error in XOpenDisplay
Thu Jul 27 17:46:59 2006 xdm error (pid 3799): server for display :0 terminated unexpectedly: 1
Thu Jul 27 17:46:59 2006 xdm error (pid 3799): display :0 cannot be opened
Thu Jul 27 17:46:59 2006 xdm error (pid 3799): display :0 is being disabled
Thu Jul 27 17:46:59 2006 xdm info (pid 3799): exiting
noen som vet hvordan jeg kan fikse denne?
EDIT!!
Jeg fikk til slutt i allefall fram nvidia logoen på skjermen, men så går den ut igjen. loggen var lang, men jeg tror dette er problemet:
Er det fonts som jeg trenger og installere?
Endret av Gakkakk
  • 1 måned senere...
