Beste HK for Core 2 Duo
Thmas
P5B dlx har ikke noen biosbrikke som du kan ta av. Men den har jo backup på biosen og det skal vel være nesten umulig å kræsje biosoppgraderingen på det kortet.
Men det kortet har også en annen kjekk funksjon. Du kan legge biosen på en minnepinne og flashe den direkte når du starter maskinen.
Oppskrift i spoiler.
Klikk for å se/fjerne innholdet nedenfor
4.1.5 ASUS CrashFree BIOS 3 utility
The ASUS CrashFree BIOS 3 is an auto recovery tool that allows you to restore the BIOS file when it fails or gets corrupted during the updating process. You can update a corrupted BIOS file using the motherboard support CD, the floppy disk, or the USB flash disk that contains the updated BIOS file.
Prepare the motherboard support CD, the floppy disk or the USB flash disk containing the updated motherboard BIOS before using this utility.
Recovering the BIOS from the support CD
To recover the BIOS from the support CD:
1. Turn on the system.
2. Insert the motherboard support CD to the optical drive.
3. The utility displays the following message and automatically checks the CD for the BIOS file.
Bad BIOS checksum. Starting BIOS recovery...
Checking for floppy...
When found, the utility reads the BIOS file and starts flashing the corrupted BIOS file.
Floppy found!
Reading file “P5BDELUXE.ROM”. Completed.
Start flashing...
4. Restart the system after the utility completes the updating process.
• Only the USB flash disk with FAT 32/16 format and single partition can support ASUS CrashFree BIOS 3. The device size should be smaller than 8GB.
• DO NOT shut down or reset the system while updating the BIOS! Doing so can cause system boot failure!
Recovering the BIOS from the USB flash disk
To recover the BIOS from the USB flash disk:
1. Insert the USB flash disk that contains BIOS file to the USB port.
2. Turn on the system.
3. The utility will automatically checks the devices for the BIOS file When found, the utility reads the BIOS file and starts flashing the corrupted BIOS file.
*Only the USB flash disk with FAT 32/16 format and single partition can support ASUS CrashFree BIOS 3. The device size should be smaller than 8GB.
*DO NOT shut down or reset the system while updating the BIOS! Doing so can cause system boot failure!
Floppy found!
Start flashing...
8134282[/snapback]
Etter siste oppdateringa av bios vart jo alt svart kommer ikke inn i bios med en svart skjerm. Så jeg vet ikke hva jeg skal gjøre enast å flytt på noen jumpere på hk da sikkert. Hvist ikke cpuen er død da?
