Arch vil ikke starte KDM automatisk
Har brukt Arch Linux med KDM lenge, og tenkte jeg skulle teste Slim(login manager´en), men fikk ikke helt til og funke, og ville tilbake til KDM.
Jeg fjernet Slim fra systemet, og la tilbake KDM i /etc/rc.conf. Men når jeg starter maskinen kommer ikke kdm opp. Det står heller ingenting. Men når jeg starter X også kdm, så fungerer det.
# /etc/rc.conf - Main Configuration for Arch Linux
# LOCALIZATION
# LOCALE: available languages can be listed with the 'locale -a' command
# HARDWARECLOCK: set to "UTC" or "localtime"
# TIMEZONE: timezones are found in /usr/share/zoneinfo
# KEYMAP: keymaps are found in /usr/share/kbd/keymaps
# CONSOLEFONT: found in /usr/share/kbd/consolefonts (only needed for non-US)
# CONSOLEMAP: found in /usr/share/kbd/consoletrans
# USECOLOR: use ANSI color sequences in startup messages
#LOCALE="no_NO.ISO-8859-15"
LOCALE="nb_NO  ISO-8859-1"
HARDWARECLOCK="localtime"
TIMEZONE="Canada/Pacific"
KEYMAP="no"
CONSOLEFONT=
CONSOLEMAP=
USECOLOR="yes"
# HARDWARE
# Scan hardware and load required modules at bootup
MOD_AUTOLOAD="yes"
# Module Blacklist - modules in this list will never be loaded by udev
MOD_BLACKLIST=()
# Modules to load at boot-up (in this order)
#  - prefix a module with a ! to blacklist it
MODULES=()
# Scan for LVM volume groups at startup, required if you use LVM
USELVM="no"
# NETWORKING
HOSTNAME="GakkBox"
# Interfaces to start at boot-up (in this order)
# Declare each interface then list in INTERFACES
#  - prefix an entry in INTERFACES with a ! to disable it
#  - no hyphens in your interface names - Bash doesn't like it
# Note: to use DHCP, set your interface to be "dhcp" (eth0="dhcp")
lo="lo 127.0.0.1"
eth0="dhcp"
INTERFACES=(lo eth0)
# Routes to start at boot-up (in this order)
# Declare each route then list in ROUTES
#  - prefix an entry in ROUTES with a ! to disable it
gate
Noen som veit hva som kan være feil?
Legger ved default rc.conf
Skjult tekst: (Marker innholdet i feltet for å se teksten):
# LOCALIZATION
# CONSOLEMAP: found in /usr/share/kbd/unimaps
LOCALE=
TIMEZONE=Canada/Pacific
KEYMAP=no
CONSOLEFONT=
CONSOLEMAP=
USECOLOR="yes"
# HARDWARE
MOD_AUTOLOAD="yes"
# Module Blacklist - modules in this list will never be loaded by hwdetect
MOD_BLACKLIST=()
MODULES=(!usbserial)
USELVM="no"
# NETWORKING
HOSTNAME="myhost"
lo="lo 127.0.0.1"
eth0="eth0 192.168.0.2 netmask 255.255.255.0 broadcast 192.168.0.255"
gateway="default gw 192.168.0.1"
ROUTES=(!gateway)
# Enable these network profiles at boot-up. These are only useful
# if you happen to need multiple network configurations (ie, laptop users)
# - set to 'menu' to present a menu during boot-up
# - prefix an entry with a ! to disable it
# Network profiles are found in /etc/network-profiles
#NET_PROFILES=(main)
# DAEMONS
# Daemons to start at boot-up (in this order)
# - prefix a daemon with a ! to disable it
# - prefix a daemon with a @ to start it up in the background
DAEMONS=(syslog-ng !hotplug !pcmcia network netfs crond)
# End of file
Den linja som starter med DAEMONS=... legger du inn kdm på slutten av.
Endret av wiley
Prøvde med orntlig rc.conf fil, men ingen endring.
Prøvde med how-toen fra wiki.archlinux.org, men da fikk jeg myyye errors på skjermen når jeg starta Linux. Orka ikke og skrive ned noe av de, men gjør det i en mere våken tilstand i morgen.
Endret av Gakkakk
