Tråden for romfergeoppdraget STS-115
Dagens oppdatering:
Mission: STS-115 - 19th International Space Station Flight (12A) -
P3/P4 Truss Segment and Solar Arrays
Vehicle: Atlantis (OV-104)
Launch Date: Aug. 27, 2006, 4:30 p.m. EDT
Crew: Jett, Ferguson, Tanner, Burbank, MacLean and Stefanyshyn-Piper
Inclination/Orbit Altitude: 51.6 degrees/122 nautical miles
At Launch Pad 39B, closeout of the orbiter's aft compartments is
complete and the aft doors have been installed. Technicians have
finished performing the aft confidence test, which involves powering
up and testing all of the aft systems, such as the main propulsion
system circuits. The payload bay doors will be closed today for
flight.
The start of the launch countdown was moved from 6 p.m. to noon
Eastern time today to allow for earlier loading of fuel for the power
reactant storage and distribution system. The goal is to finish the
system loads before the predicted afternoon thunderstorms on Friday.
Additional hold time will be added at the T-19 hour mark, extending
the hold from four hours to 10 hours. After T-19, the schedule will
proceed as normal, culminating in a launch on Sunday at 4:30 p.m.
Eastern time.
The STS-115 crew arrived at 11:30 a.m. today at the Shuttle Landing
Facility from Johnson Space Center in Houston. They will spend the
next days prior to launch going over their flight plans.
U.S. Air Force weather officers are forecasting a 30-percent chance of
weather prohibiting a launch attempt on Sunday. The primary weather
concerns are anvil clouds, showers and thunderstorms within 20
nautical miles of the Shuttle Landing Facility.
Samt et bilde av lasterommet til Atlantis før dørene ble lukket for siste gang før oppskytning:
Endret av [GDI]Raptor
Dagens aktiviteter i nedtellingen...
Alle tidene her i min oppsummering er amerikansk østkysttid (Eastern Time)... Dere kan konvertere til norsk tid ved å legge på 6 timer.
Oppskytning - 2 dager (Fredag 25. august)
  • Aktivere og teste navigasjonssystemet. (klokken 01:00 am)
  • Inspeksjoner i copit ferdig. (klokken 04:00 am)
  • Begynne første pause i nedtellingen på T-27 timer. Denne varer i 4 timer. (klokken 04:00 am)
  • Fjerne alle folk som ikke trenger å være ved oppskytningsrampen.
  • kjøre test på enhenten romfergen bruker for å kontrollere pyroteknikken. (eksplosive ladninger som separerer forskjellige komponenter, f.eks. startrakettene)
  • Fortsette nedtellingen. (klokken 08:00 am)
  • Begynne opperasjonen med å fylle drivstoff. (flytende oksygen og hydrogen) i Atlantis sine brenselscelle tanker. (klokken 08:00 am)
  • Begynne pause i nedtellingen på T-19 timer. Denne varer i 10 timer. (klokken 04:00 pm)
  • Koble fra utstyret som ble bruker for å laste drivstoff til brenselsceller. (mid-body umbilical unit) (klokken 04:30 pm)
  • Fortsette siste sjekk av romferge og bakke-utstyret.
Dagens oppdatering:
At Launch Pad 39B, final launch preparations continue. The payload bay
doors were closed for flight last night, and loading of the fuel for
the power reactant storage and distribution system is now under way.
Weather delays interrupted the PRSD loading earlier this afternoon,
but the task is expected to be completed later this evening. No
impact to the remaining schedule is expected. Also, the Tyvek ring
covers have been installed on the forward reaction control system
thrusters. These covers protect the thrusters from inclement weather.
They are designed to release from the orbiter shortly after launch,
as the shuttle clears the tower.
Mission managers met at KSC this afternoon to further discuss progress
made and give final approval to continue with launch activities. No
problems were discussed that would prevent an on-time launch on
Sunday.
Weather forecasters indicate the launch day probability of weather
prohibiting launch is 40 percent. A Bermuda high pressure ridge
located over the Florida Straits is creating a southwesterly flow
over Central Florida, bringing afternoon thunderstorms for the next
two days. The primary concerns on Sunday are anvil clouds, showers
and thunderstorms within 20 nautical miles of the Shuttle Landing
Facility.
Det er for øyeblikket 40% sjans for at været hindrer oppskytning på søndag. Mandag og tirsdag ser bedre ut, da er det kun 20% sjans for dårlig vær.
Aktiviteter i nedtellingen idag:
Oppskytning - 1 dager (Lørdag 26. august)
  • Fortsette nedtelling (klokken 02:00am)
  • Starte siste forberedelser for drivstofftanking på romfergens hovedmotorer (SSME) (klokken 02:00am)
  • Starte å fylle tankene til oppskytningsrampen sitt lydempingssystem med vann (klokken 04:00am)
  • Fjerne platorformene under hovedmotroene til romfergen
  • Kjøre test på romforgen sin "star tracker" (brukes til navigering i verdensrommet) (klokken 09:50 am)
  • Begynne planlagt 13 timer og 34 minutters pause på T-11 timer (klokken 10:00am)
  • Aktivere romfergen sine interne målesystemer
  • Aktivere kommunikasjonssystemene i romfergen
  • Installere film i kamraer som overåker rampen (klokken 10:55am)
  • Installasjon av siste del av mannskaptes utstyr (klokken 03:10pm)
  • Flytte den roterende service strukturen (RSS) som beskytter romfergen for vær og vind (klokken 07:00pm)
  • Gjøre romfergens brenselceller klare
  • Fortsette nedtellingen på T-11 timer (klokken 11:34pm)
Grunnet lynnedslag på oppskytningsrampen trenger NASA ekstra tid for å sjekke at alt er i orden.
Det blir derfor en 24 timers utsettelse...
NY tid (Norsk tid): 28. august: 21:59:04
Her er forresten et bilde av lynnedslaget... Rett i lynavlederen...
6749775[/snapback]
Haha! Wow, I can see why lol :tease:
esa
Flere kilder ved kenedy Space Center sier nå at de trenger litt mer tid på å undersøke alle systemene, og oppskytning kan bli utsatt til tirsdag...
Isåfall er det følgende tidspunkt som gjelder (norsk tid): 29. august: 21:36:32
Mens ekstra sjekk av romfergen og utstyret på oppskytningsrampen foregår så står nedtellingsklokken stille på T-11 timer.
Grunnet den tropiske stormen/orkenen Ernesto ser det ut som at tirsdagens forsøk må avlyses.
NASA jobber nå på spreng med å kjøre Atlantis tilbake til Veichle Asebly Buildning (VAB). Denne bygningen brukes for å beskytte romfergen for orkanen.
Dette gjør at det begynner å spøke for sjansen til å skyte opp romfergen nå. Kravene til NASA sier at denne oppskytningen skal være i dagslys.
Værvarslet i florida har blitt bedre!
NASA har nettopp reversert avgjøelsen om å kjøre Atlantis bort fra rampen! De er nå på vei tilbake!  :thumbup:
6767031[/snapback]
Haha, imagine if they had to turn the "whole thing around" :tease:
*The "crawler", make it do a "u-turn" :!:
esa
Ok... Her kommer oppdateringen...
KSC har blitt gjennåpnet etter at stormen var dratt over. Det var ingen skader. Atlantis står trygt på oppskytningsrampen. De driver å å kobler utstyret tilbake igjen, og verrifiserer tilkoblingene.
De neste dagene kommer de til å re-installere pyro-ladningene som brukes til å separere tanken, startraketter osv.
Nedtellingen begynner på søndag klokken 1200am lokal tid (USA, østkyst)
Oppskytningen blir omtrent (Norsk tid): 6. september klokken 18:29:00
NASA har også muligheten til å skyte opp den 7. september og den 8. september. Etter det så lukker oppskytningsvinduet seg, grunnet at russerene skal sende opp en Soyuz rakett med nytt manskap til romstasjonen (ISS)
Her kommer noen bilder: Disse bildene er fra tirsdag 29. august
Romfergen Atlantis som er montert til en ekstern tank og to startraketter blir fraktet tilbake til oppskytningsrampe 39B etter at NASA avlyste planan om å trekke seg tilbake til VAB.
Atlantis tilbake på rampe 39B. Crawler transporteren er på vei til å kjøre tilbake. Det jobbes med å koble esensielle systemer til på Atlantis, og kjøre den roterende service strukturen (det som er til venstre i bildet under) rundt romfergen for å begytte den mot regnet og vinden.
Dagen idag blir brukt til å koble til alle koblingene mellom oppskytningsrampen og romferge-systemet. Alle koblingene skal også verifiseres...
De som tror det bare er noen få ledninger bør tro om igjen! ;)
Setter inn et bilde av noen av kablene:
Planan imorgen: Sette inn de eksplosive ladningene som brukes til å separere startrakettene, separere tanken, samt mange andre funksjonaliteter...
Trodde jeg hadde klart å gå glipp av oppskytningen jeg.. !
Ble den utsatt? (og hva var grunden?)
Og når ble den utsatt til?
6785736[/snapback]
Tror jeg har skrevet det før i tråden...
Først ble oppskytningen utsatt grunnet lynneddslag i lynavlederen på rampen (bilde av det i denne tråden) og så ble den utsatt grunnet den tropiske stromen som har vært over Florida.
Den er utsatt til onsdag 6. september.
Her er forresten oppdateringen fra Kenedy Space Center:
Mission: STS-115 - 19th International Space Station Flight (12A) - P3/P4 Truss Segment and Solar Arrays
Launch Date: Sept. 6, 2006, 12:29 p.m. EDT
At Launch Pad 39B, preparations for Wednesday's launch are under way, with the launch countdown scheduled to begin on Sunday at 8 a.m. The liquid oxygen and liquid hydrogen transfer lines used for filling the external fuel tank (ET) were reconnected to the mobile launch platform. The ET hydrogen vent line hook-up is complete. The ordnance was disconnected to allow for vehicle power-up and will be reconnected this weekend. The Orbiter Midbody Umbilical Unit (OMBUU) mate is complete. This is the connection point for lines that will be used to provide hydrogen and oxygen reactants for the fuel cells. Weekend work includes pressurization of the orbital maneuvering system, the reaction control system and the main propulsion system. The two doors to the aft compartment of Atlantis were removed for access to ordnance, and they will be closed during the weekend to allow for the aft confidence test on Sunday. This test involves powering up and testing all aft systems, such as the main propulsion system circuits.
On Tuesday, the shuttle was moved off the pad in advance of Tropical Storm Ernesto, then returned to the pad after traveling about 2 miles toward the Vehicle Assembly Building when the storm predictions became more favorable. On Thursday, engineers inspected the ET thermal protection system, post-rollback, and found three areas of minor foam damage. One area, about 3/8 inches long, is located at the midsection of the liquid oxygen tank, about 2 feet outboard of the ice frost ramps. A second area, about 1 inch long by 1/16 inch wide, is located near the ET/right SRB aft fairing, which is the attach point between the two components. Both of these resemble a scratch, are accessible and are expected to be easily repaired. The third area, a missing foam nodule from the liquid hydrogen barrel between the ET and the left SRB, about five feet below the intertank flange closeouts, will not need repair.
6785736[/snapback]
6788260[/snapback]
Onsdag 6. september er bursdagen min :D
Håper bare vi er hjemme fra skoletur da det skjer...
