Tråden for romfergeoppdraget STS-115
Ukens oppdatering fra Kenedy Space Center:
Mission: STS-115 - 19th International Space Station Flight (12A) -
P3/P4 Truss Segment and Solar Arrays
Vehicle: Atlantis (OV-104)
Launch Date: No earlier than Aug. 27, 2006
Launch Pad: 39B
Crew: Jett, Ferguson, Tanner, Burbank, MacLean and Stefanyshyn-Piper
Inclination/Orbit Altitude: 51.6 degrees/122 nautical miles
On Monday, Atlantis rolled from Orbiter Processing Facility bay 1 to
the Vehicle Assembly Building, where it was lifted into high bay 3
for mating to the external fuel tank and solid rocket boosters.
Mating operations and checkouts are under way. The shuttle is
scheduled to roll to Launch Pad 39B on July 31, with first motion
targeted for 12:01 a.m. EDT. The STS-115 payload was transferred to
the launch pad on Wednesday and is scheduled to be installed in
Atlantis' payload bay on Aug. 2. Mission managers made the decision
to move the opening of Atlantis' launch planning window to Aug. 27.
The decision was made after it was determined that lighting
conditions for launch and external tank separation were sufficient to
support imagery analysis.
The payload for STS-115 is the Port 3/4 truss segment, the next major
addition to the 11-segment integrated truss structure that will
eventually span more that 300 feet. The P3/P4 truss, with its two
large solar arrays, will provide one-fourth of the total power
generation capability of the completed station.
Oppskyningsdatoen har blitt flyttet til den 27. august, altså en dag tidligere. Endelig dato settes den 13. eller 14. august, da har NASA det som kalles et "flight Readiness Review". Når dette møtet nærmer seg så forteller jeg litt hva det handler om.
Som sagt så har lasten til Atlantis blitt kjørt ut til oppskytningsrampen, og alt er klart for å kjøre Atlantis ut til mandag. Atlantis er for øyeblikket i VAB-bygningen, og har flitt festet til den eksterne tanken (ET), og startrakettene (SRB). Nå i helgen så kjøres tester for å se at alle koblingene mellom romfergen og tanken fungerer.
Bilde av lasten som heises opp til rampen:
Vet vi sånn ca klokkeslett på når oppskytningen er ca.. om den er tidlig på dagen, eller sent på ettermiddagen?
Vil så gjerne få med meg dette live, men er jo skole da =(
6583289[/snapback]
Det kommer nok til å gå.... :) Så lenge er du ikke på skolen håper jeg.
Det er mye dikusjon i NASA nå om de kanskje kan flytte oppsytingen enda en dag tidligere til 26. august. Vi får nok en endelig avgjørelse den 13. eller 14. august. Grunnen til at det er diskusjon om dette er at iallefall for denne oppskyningen så ønsker NASA dagslys både under oppskyningen, og når den eksterne tanken droppes, slik at de kan få fotografert den.
Her er iallefall tidspunktene for de første dagene (omregnet til europeisk tid):
26. august: 22:49:26
27. august: 22:24:47
28. august: 21:59:04
29. august: 21:36:32
"vinduet" de kan skyte opp i er omtrent 10 minutter langt, og for å ha best mulige marginer med drivstoff så sikter de typisk mot midten av vinduet. Grunnen til at det er så strict er at de skal møte den internasjonale romstasjonen. Vinduet flytter seg omtrent 25 minutter tidligere hver dag. NASA har frem til 9. september til å få skutt opp Atlantis.
Endret av [GDI]Raptor
Da er Atlantis på vei ut mot oppskytningsrampe 39B! :)
Forsinket to dager grunnet dårlig vær...
Her er første bilde:
Edit: Atlantis nærmer seg nå 39B
Edit2: Flere bilder, nå fremme på rampe 39B
Her er fredagens oppdatering fra Kenedy Space Center
Launch Pad: 39B
Early on Wednesday, Space Shuttle Atlantis rolled from high bay 3 in
the Vehicle Assembly Building to Launch Pad 39B. Early Thursday, the
orbiter's auxiliary power units were successfully test fired. Also on
Thursday morning, the rotating service structure was moved to the
mate position and is now surrounding the orbiter as it sits on the
mobile launch platform. Functional tests and checkout of the shuttle
and pad systems are under way.
The STS-115 payload is scheduled to be installed in Atlantis' payload
bay on Saturday. The payload for STS-115 is the Port 3/4 truss
segment, the next major addition to the 11-segment integrated truss
structure that will eventually span more that 300 feet. The P3/P4
truss, with its two large solar arrays, will provide one-fourth of
the total power generation capability of the completed station.
Mission managers made the decision to move the opening of Atlantis'
launch planning window to Aug. 27. The decision was made after it was
determined that lighting conditions for launch and external tank
separation were sufficient to support imagery analysis.
Next week, the STS-115 crew will visit KSC for a launch dress
rehearsal, called the terminal countdown demonstration test.
Skal se om jeg kan få inn et bilde av Atlantis på oppskytningsrampen med den roterende service strukturen (RSS) rundt seg.
Edit: Bilde av Atlantis nå:
Mannskapet til romfergen er nå i Florida for det som kalles Terminal Countdown Demonstration Test (TCDT) hvor de simulerer en nedtelling frem til -31 sekunder. Da får mannskapet beskjed om å evakuere romfergen, slik at de får trening i nød prosedyrer.
Her er et bilde av mannskapet på 6 astronauter som skal opp, med romfergen på rampen i bakgrunnen.
De neste skrittene fremmover nå er det som kalles Flight Readines Review (FRR). Det er et to-dagers møte som er fra den 15. august til 16. august. Her møtes alle de involverte avdelingene, og diskuterer eventuelle problemer og aspekter rundt oppdraget.
Det er også her den offisielle oppskytningsdatoen settes.
Denne ukens oppdatering fra Kenedy Space Center
Launch Date: No earlier than Aug. 27, 2006 at about 4:30 p.m. EDT
At Launch Pad 39B, functional tests and checkout of the shuttle and
pad systems are under way. Installation of the elbow camera of the
orbiter's remote manipulator system (robotic arm) is complete. This
weekend, hypergolic propellant loading will begin for the orbiter's
reaction control system, orbital maneuvering system pods and the
auxiliary power units, and for the hydraulic power units of the solid
rocket boosters.
The STS-115 payload was installed in Atlantis' payload bay last
Saturday. The payload for STS-115 is the Port 3/4 truss segment, the
next major addition to the 11-segment integrated truss structure that
will eventually span more that 300 feet. The P3/P4 truss, with its
two large solar arrays, will provide one-fourth of the total power
The STS-115 crew visited KSC this week for a launch dress rehearsal,
called the terminal countdown demonstration test. The demonstration
test provided the crew an opportunity to participate in various
simulated countdown activities, and included equipment
familiarization and emergency egress training.
Mission managers will meet next week for a 2-day Flight Readiness
Review, during which they will thoroughly assess the status of Space
Shuttle Atlantis for launch. This meeting will yield a number of key
decisions about STS-115, including selection of an official launch
date.
Tar også med et bilde fra TCDT (terminal countdown demonstration test) som var denne uken. Her ble en nedtelling simulert, med full evakuering av romfergen når det var 31 sekunder igjen av den simulerte nedtellingen. Bilde er av piloten i romfergen.
I didn't know they used hypergolic fuel?
Do you know what specific type of propellant they use for the SRBs? Do they use a hollow-cylinder type grain, or more like a Bates grain?
esa
EDIT:
Or is it a star-type grain for the SRBs? :hmm:
Endret av esa
NASA er nå ferdig med flight Readines Review (FRR). Alle deltakerene var "GO for launch". Datoen til Atlantis sin oppskytning er nå fastsatt og offisiell. Så får vi se om været holder... Discovery trengte tre forsøk på grunn av dårlig vær i begynnelsen av Juli. Vi får håpe på at Atlantis kommer avgårde på første forsøk! :thumbup:
Dette er forresten Atlantis sin første tur opp siden oktober 2002 (før Columbia-ulykken), og det er Atlantis sin 27. tur opp i verdensrommet.
Tidspunktet er (omregnet til Norsk tid):
27. august: 22:24:47 (CET)
Oppskytningen kommer blandt annet til å sendes direkte på NASA TV:
http://www.nasa.gov/multimedia/nasatv/index.html
er det tidspunktet på selve utskytningen?
eller er det da de starter de siste forberedelsene til oppskytningen
6691649[/snapback]
Det er da det 10 minutter lange oppskytningsvinduet begynner. Vanligvis sikter de mot midten av vinduet, så selve oppskytningen kommer omtrent 5 minutter senere.
Den endelige oppskytningstiden blir ikke bestemet før rett før de begynner å telle ned de siste 9 minuttene.
Når vi nærmer oss kommer jeg til å poste en detaljert liste over hva som skjer iløpet av nedtellingen. De begynner på T-48 timer... :)
Nok en oppdatering:
Launch Date: Aug. 27, 2006, 4:30 p.m. EDT
At Launch Pad 39B, hypergolic propellant loading is being completed
today. Following a decision by Space Shuttle Program managers to
remove and replace two Ku-band antenna actuator bolts in the forward
section of the orbiter payload bay, workers are preparing access
platforms and will complete the task over the weekend. The bolts will
be replaced with longer versions to ensure adequate thread
engagement. Ordnance installation is now scheduled for Sunday
evening, pending completion of the bolt replacement.
Earlier this week, flight crew systems workers installed
extravehicular maneuvering units in the crew cabin. The suits are
worn by shuttle crew members for spacewalks.
In Houston, the STS-115 crew is completing its final prelaunch
physicals and a final flight data file review today, before heading
into quarantine this weekend for the Aug. 27 launch.
At Launch Pad 39B, closeout of the orbiter's aft compartments
continues, and pressurization of the orbiter's maneuvering system,
reaction control system and main propulsion system is under way.
Stowage of flight crew equipment in the crew module is ongoing.
Payload bay preparations will resume Wednesday. Final closeouts on
the solid rocket boosters and the external fuel tank will be
completed today.
In Houston, the STS-115 crew is conducting the final ascent simulation
today. The crew will arrive at Kennedy Space Center on Thursday.
Nå begynner det å nærme seg. Ved midnatt imorgen (25. august klokken 00:00) norsk tid starter nedtellingen for oppskytningen av Atlantis på søndag.
Putter inn to bilder fra oppskytningsrampe 39B, hvor de siste forberedelsene på Atlantis blir gjort nå.
Nedtellingen til oppskytningen av romfergen begynner 3 dager før oppskytningsdagen, og det er flere innebygde pauser i nedtellingen.
Når nedtellingen begynner imorgen klokken 00:00 (norsk tid) så står den offisielle klokken på T-43 timer.
Kommer til å poste en oversikt over hva som skjer de tre forskjellige dagene her, slik at dere kan se den kompliserte prosessen med å skyte opp en romfege.
Her kommer første dagen av nedtellingen...
Alle tidene her i min oppsummering er amerikansk østkysttid (Eastern Time)... Dere kan konvertere til norsk tid ved å legge på 6 timer.
Oppskytning - 3 dager (Torsdag 24. august)
  • Gjøre klart for for å starte nedtellingen. Dette kalles "Call to stations" hvor teamet møtes i kontrollrommet for å begynne nedtellingen. (klokken 11:30am)
  • Nedtellingen starter på T-43 timer. (klokken 12:00pm)
  • Starte siste kontroll av romferge og rampe for oppskytning
  • Sjekke og kontrollere backup systemer for flyvingen
  • Sjekke software som er lagret i masselagingsenhetene til Atlantis.
  • Laste inn backup kontrollsystemene i Atlantis sine datamaskiner.
  • Fjerne arbeidsplatformer fra copitten. (klokken 08:30pm)
  • Gjøre klart for å laste ombord flytende oksygen og hydrogen for brenselscellene (fuel cells) som produserer strøm i verdensrommet. (klokken 11:00pm)
Edit: Fikset utseende i post
Astronautene har annkommet Kenedy Space Center for oppskytningen på søndag.
I følge dagens værmelding så er det 70% sjans for at været tillater oppskytning på søndag. noe som er veldig bra for florida på denne tiden av året. Nedtellingen har begynt 6 timer før tiden, og det er for øyeblikket ingen tekniske problemer.
Go Atlantis! :thumbup:
I skrivende øyeblikk er det: 2 dager, 23 timer og 54 minutter til oppskytning!
