VIRUS
Les om Klez-viruset her.
Last ned removal tool her.
Egentlig skal man vel starte Windows i sikkerhetsmodus og kjøre removal tool derfra. På den måten er man sikret å få fjernet absolutt alt av Klezviruset..
Ellers vil jeg anbefale deg å skaffe et oppdatert virusprogram. Selv bruker jeg Norton Antivirus 2003 og det stopper alt av virus (i alle fall Klez!)
Lykke til! :smile:
Edit:
To obtain and run the tool
NOTE: You must have administrative rights to run this tool on Windows NT 4.0, Windows 2000, or Windows XP.
1. Download the FixKlez.com file from http://securityresponse.symantec.com/avcen...ter/FixKlez.com.
2. Save the file to a convenient location, such as your download folder or the Windows desktop (or, if possible, removable media that is known to be uninfected).
3. To check the authenticity of the digital signature, refer to the section The digital signature.
4. Close all programs.
5. If you are on a network or if you have a full-time connection to the Internet, disconnect the computer from the network and the Internet.
6. If you are running Windows Me or Windows XP, then disable System Restore. Refer to the section System Restore option in Windows Me/XP for additional details.
NOTE: If you are running Windows Me/XP, Symantec strongly recommends that you do not skip this step.
7. Restart the computer in Safe mode. All Windows 32-bit operating systems except Windows NT can be restarted in Safe mode. For instructions on how to do this, read the document How to start the computer in Safe Mode.
8. Double-click the FixKlez.com file to start the removal tool.
9. Click Start to begin the process, and allow the tool to run.
10. Restart the computer normally.
11. Next, you must reinstall NAV. For consumer products such as NAV 2000/2001/2002, follow the instructions in the document How to restore Norton AntiVirus after removing a virus. For Enterprise versions, contact your system administrator.
12. Run LiveUpdate to make sure that you are using the most current virus definitions, and scan the computer again. If NAV detects any infected files and cannot repair them, then choose to delete the files.
13. If you are running Windows Me/XP, re-enable System Restore.
_________________
The Devil’s Own Corporate Edition
Noen som vil ha ei sølvfarget plexidør?
[ Denne Melding var redigert av: havegg på 2002-10-16 23:34 ]
