Tape Backup - Hvordan bruke ftape
Edit!
Fant ut av noe av det.
ftape var med kjernen, så jeg bare lastet ftape(modprobe ftape).
Men jeg får ikke skrevet til den.
tar cf /dev/ftape /home
tar: /dev/ftape: Cannot open: No such device or address
tar: Error is not recoverable: exiting now
Noen som har vært borti noe lignende?
Endret av Jorek
Yes, beklager for en lite utfyllende post.
Det er en MicroSolutions Backpack 800TD.
Tapemaskinen er koblet til maskinen gjennom paralellporten(den største, right?).
Vet ikke om det kan ha noe å si.
Når jeg kjører kommandoen:
tar cf /dev/ftape /
Og jeg får jeg dette outputet i dmesg:
Skjult tekst: (Marker innholdet i feltet for å se teksten):
zftape for ftape v3.04d 25/11/97
© 1996, 1997 Claus-Justus Heine ([email protected])
vfs interface for ftape floppy tape driver.
Support for QIC-113 compatible volume table, dynamic memory allocation
and builtin compression (lzrw3 algorithm).
Compiled for Linux version 2.4.31
[070] zftape-init.c (zft_init) - zft_init @ 0xd09deba0.
[071] zftape-init.c (zft_init) - installing zftape VFS interface for ftape driver ....
[072] fdc-io.c (fdc_issue_command) - fdc_ready_out_wait(500 ) failed: -62.
[073] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -62.
[074] fdc-io.c (fdc_reset) - sense failed for 0.
[075] fdc-io.c (fdc_command) - fdc not ready.
[076] fdc-io.c (fdc_issue_command) - fdc_command(out_data, out_count) failed: -16.
[077] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -16.
[078] fdc-io.c (fdc_reset) - sense failed for 1.
[079] fdc-io.c (fdc_command) - fdc not ready.
[080] fdc-io.c (fdc_issue_command) - fdc_command(out_data, out_count) failed: -16.
[081] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -16.
[082] fdc-io.c (fdc_reset) - sense failed for 2.
[083] fdc-io.c (fdc_command) - fdc not ready.
[084] fdc-io.c (fdc_issue_command) - fdc_command(out_data, out_count) failed: -16.
[085] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -16.
[086] fdc-io.c (fdc_reset) - sense failed for 3.
[087] fdc-io.c (fdc_command) - fdc not ready.
[088] fdc-io.c (fdc_command) - fdc not ready.
[089] fdc-io.c (fdc_issue_command) - fdc_command(out_data, out_count) failed: -16.
[090] fdc-io.c (fdc_probe) - No FDC found.
[091] fdc-io.c (fdc_issue_command) - fdc_ready_out_wait(500 ) failed: -62.
[092] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -62.
[093] fdc-io.c (fdc_reset) - sense failed for 0.
[094] fdc-io.c (fdc_command) - fdc not ready.
[095] fdc-io.c (fdc_issue_command) - fdc_command(out_data, out_count) failed: -16.
[096] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -16.
[097] fdc-io.c (fdc_reset) - sense failed for 1.
[098] fdc-io.c (fdc_command) - fdc not ready.
[099] fdc-io.c (fdc_issue_command) - fdc_command(out_data, out_count) failed: -16.
[100] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -16.
[101] fdc-io.c (fdc_reset) - sense failed for 2.
[102] fdc-io.c (fdc_command) - fdc not ready.
[103] fdc-io.c (fdc_issue_command) - fdc_command(out_data, out_count) failed: -16.
[104] fdc-io.c (fdc_sense_interrupt_status) - fdc_issue_command(out, 1, in, 2) failed: -16.
[105] fdc-io.c (fdc_reset) - sense failed for 3.
[106] fdc-io.c (fdc_command) - fdc not ready.
[107] ftape-ctl.c (ftape_enable) - fdc_init() failed: -6.
[108] zftape-ctl.c (_zft_open) - ftape_enable failed: -6.
[109] zftape-init.c (zft_open) - _ftape_open failed.
Og jeg har loada ftape modulet:
# lsmod | grep tape
zftape 61944 -1 (autoclean)
ftape 104357 0 [zftape]
Hmm, litt merkelig dette...
Endret av Jorek
