Kommer meg ikke innpå andre maskiner!
Hei.
Når jeg prøve å gå innpå andre maskiner får jeg bare denne feilmeldingen "\\andeby The network path was not found."
Det går ikke an å gå innpå min PC for andre heller.
Er det noen som vet hva som kan være feil?
EDIT: Hverken jeg eller noen andre har noe brannmur-opplegg.
Endret av Flaringo
Hmm. Tror alt sluttet å virke etter jeg installerte en demo av Titan Quest med følgende instruksjoner: "** important, everyone with problems read this**
Baelthanoc's method was mostly just great, but there's one thing missing, I'll add it here together with his original suggestion (thanks Baelthanoc). This WILL get the demo for you to work.
WARNING : I highly recommend you do this when you are NOT connected via the internet or external network, otherwise you will give access to your root drive to external users.
Step 1: Share the root drive that has windows installed: right click the windows button, click on explore, right click on your hard drive and click properities, then click on share. It will give some kind of warning, click on the warning and it will then allow you to share it. Select both use this folder to make a shared network drive as well as users may edit my files.
Step 2: Map a network drive to the new share using drive letter C:
Probably you've already got a C:\ drive used for something else. To solve this, go to windows explorer (see step 1) right click on 'this computer' and click on 'administration'. In storage click on 'drive administration'. Right click on the drive that at the moment is called C:\ and click on 'change drive letter and path' (this doesn't work for your drive in which windows is installed, so that's why we do it this way) change the drive named C:\ to anything else that pleases you. Restart your computer. Now go to windows explorer again, click on extra -> make network connection -> select C:\ for station -> click on browse. You'll see all your network folders here -> open your network folder -> click on your computer name and it will show you all the folders you're sharing on your computer -> select your shared hard drive and click on OK
Step 3: Change the registry settings at HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion for <drive>:\Program Files to C:\Program Files . To do this: click on windows start button, click on 'execute' type 'regedit' and click enter. In the new screen, just like with using windows explorer, just browse to HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion on the right then you'll see somewhere along the list 'ProgramFilesDir' right click it, click on edit, change it to C:\Program Files
Step 4: Install the demo
Step 5: Remove the share and disconnect the network drive, and change the registry back."
Kan noe av dette påvirke nettverks-greier( :p )?
Beklager all dobbeltpostinga, men jeg trenger virkelig hjelp, siden jeg skal på lan i morgen, og vil ikke bli sittende uten nettverk. :(
EDIT: Det står en lås på Local Area Connection-ikonet, har det noe med dette å gjøre? :hmm:
EDIT2: Å, det var visst bare firewall'en som hadde ble reset'a etter de nye nettverkskortdriverene mine. Tok den av igjen nå. :(
Endret av Flaringo
