Falcon_ Skrevet 4. juli 2006 Del Skrevet 4. juli 2006 AMD Dual-Core Optimizer - The AMD Dual-Core Optimizer can help improve some PC gaming video performance by compensating for those applications that bypass the Windows API for timing by directly using the RDTSC (Read Time Stamp Counter) instruction. Applications that rely on RDTSC do not benefit from the logic in the operating system to properly account for the affect of power management mechanisms on the rate at which a processor core's Time Stamp Counter (TSC) is incremented. The AMD Dual-Core Optimizer helps to correct the resulting video performance effects or other incorrect timing effects that these applications may experience on dual-core or multiple processor systems. AMD Processor Driver 1.3.2 - Allows the system to automatically adjust the CPU speed, voltage and power combination that match the instantaneous user performance need. Download this Setup Installation program (EXE) to automatically update all the files necessary for installation. This package is recommended for users whom desire a graphical user interface for installation. This .EXE driver is a user friendly localized software installation of the driver designed for end-users. This driver supports AMD Athlon 64/FX processors on Windows XP SP2, Windows 2003 SP1 x84 and x64 Editions. AMD Athlon™ 64/FX Processor Utilities and Updates Lenke til kommentar https://www.diskusjon.no/topic/599480-nye-drivere-fra-amd-a64fxx2/
Malvado Skrevet 4. juli 2006 Del Skrevet 4. juli 2006 La merke til disse nettop, er det noen som har fått testet de litt? Lenke til kommentar https://www.diskusjon.no/topic/599480-nye-drivere-fra-amd-a64fxx2/#findComment-6432066
