Script i cs
Jeg har et problem. I autoexec fila skriver jeg, exec Scriptsscripts.cfg Har laget en egen mappe med script fila. Problemet er at fila ikke blir kjørt. Får opp feilmelding i consol, invalid path(?).
Noen som vet hva jeg har gjort galt?
Edit: Jeg kan skrive opp hva som står i filene vist dette er til hjelp...?
[ Denne Melding var redigert av: RansoM på 2002-10-15 13:06 ]
Script fila:
hud_fastswitch 1
scr_conspeed 9999
console 1
//Shortening Common Commands
alias ms1 "menuselect 1"
alias ms2 "menuselect 2"
alias ms3 "menuselect 3"
alias ms4 "menuselect 4"
alias ms5 "menuselect 5"
alias ms6 "menuselect 6"
alias ms7 "menuselect 7"
alias ms8 "menuselect 8"
alias ms9 "menuselect 9"
alias ms0 "w; w; w; slot10; w; w; w; w; w; w; slot10; slot10; slot10; slot10"
alias w "wait"
alias w2 "w; w"
alias w3 "w; w2"
alias dv0 "developer 0"
alias dv1 "developer 1"
// NetGraph Cycler
alias netgraph_c netgraph_1
alias netgraph_1 "alias netgraph_c netgraph_2; net_graph 1; dv1; echo Netgraph On - Mode 1.; dv0"
alias netgraph_2 "alias netgraph_c netgraph_3; net_graph 2; dv1; echo Netgraph On - Mode 2.; dv0"
alias netgraph_3 "alias netgraph_c netgraph_4; net_graph 3; dv1; echo Netgraph On - Mode 3.; dv0"
alias netgraph_4 "alias netgraph_c netgraph_0; net_graph 0; cl_showfps 1; dv1; echo Netgraph Off, FPS On; dv0"
alias netgraph_0 "alias netgraph_c netgraph_1; cl_showfps 0;dv1; echo FPS OFF; dv0"
//Div Alias
alias buyammo "buy;ms6;w3;ms0"
alias buyammo2 "buy;ms7;w3;ms0"
alias buyarmor2 "buy;ms8;ms1;w3;ms0"
alias buyarmor3 "buy;ms8;ms2;w3;ms0"
alias buyhe "buy;ms8;ms4;w3;ms0"
//Buy Scripts
alias armorhe "buyarmor3;buyhe;w3;ms0"
//Best Wepon
alias best "buy;ms4;ms1;buy;ms4;ms3;buyammo;w3;ms0;"
alias best2 "buy;ms4;ms2;buy;ms4;ms4;buyammo;w3;ms0;"
//Artic
alias sniber "buy;ms4;ms6;buyammo;ms0;"
//Desert
alias desert "buy;ms1;ms3;buyammo2;w3;ms0;"
autoexec fila:
//Dif Ops
cl_showfps 1
rate 5000
gamma 4
brightness 4
Scriptet har jeg fra noen andre, har bare forrandret noen av tinga, så ikke heng meg vist noe er galt. :smile:
Quote:
Den 2002-10-15 13:10, skrev Cappo:
Du må vel ha /directory til scripts.cfg/scripts.cfg
Ikke helt sikker på om du kan bruke / og /. Men det er i hvertfall det du mangler. Altså spesifisere hvor scripts.cfg er siden den ikke ligger i default .cfg directory.
Fila scripts.cfg ligger i en mappe scripts under cstrike.
Quote:
Den 2002-10-15 13:05, skrev RansoM:
Legg Scriptsscripts.cfg i samme mappe som de andre cfg-filene dine (config.cfg, autoexec.cfg). Pass også på store og små bokstaver, bruk helst bare små bokstaver i filnavnene, så slipper du surr i så måte.
Skal prøve å flytte scripts.cfg fila mi når jeg kommer hjem, er på jobb, til "rota" i cstrike mappa.
Når det gjelder å kopiere innholdet i scripts fila til config fila, så hadde jo dette vært det letteste. MEN, hadde tenkt at jeg skulle lage et script som ikke forrandret config fila slik at det hadde blitt lettere for andre å bruke det også.
Men men, skal nok få det til.... :smile:
Skriveleif fra min side, det skal "seff" være scripts.cfg/scripts.cfg , dette er riktig i autoexec fila.
Quote:
Den 2002-10-15 15:55, skrev RansoM:
om mappa heter scripts, og fila heter scripts.cfg, så er rett path "exec scripts/scripts.cfg". altså er det helt vanlig windows mappestruktur, selv om du spiller et spill ;p
Quote:
Den 2002-10-16 11:09, skrev r0nin:
Var jo det jeg sa jo. :razz:
En del misforståelser her. Etter CS v1.4 kan man ikke vise til andre paths enn den aktuelle. Derfor må scripts ligge i /cstrike/. Man kan ikke legge scripts i config.cfg fordi half-life (Og dens mods) renskriver denne fila på nytt hver gang du kjører det. Du mister alle dine aliases, samt enkelte andre innstillinger (scr_conspeed, con_color osv). Viss du så absolutt MÅ ha scriptet i en annen folder kan du legge til en +exec folderscript.cfg på slutten av snarveien. Det burde funke.
Quote:
Den 2002-10-16 13:29, skrev aschj:
Not! Du bare skrivebeskytter fila da din nisse! :razz:
Alle andre enn n00bs gjør jo det da.
Hei,
jeg droppet mappa og la script.cfg i rota på cstrike. Nå funket alt og bedre en noen andre script jeg har prøvet. Problemet jeg har hatt med andre scripts, er at buy-menuen blir stående oppe.
Å skrive **** -game cstrike -exec scripts/scripts.cfg i snarveien burde funke, at jeg ikke tenkte på det :smile:
Men men, nå fungerer det meget bra, så jeg får si takk for all hjelp.
