WinSock og chatteprogram
Jeg prøver å lage et enkelt chatte program, bare for å lære litt om winsock. Men jeg sliter litt. Jeg skal sende litt tekst, men får bare sendt tekst en gang. Deretter får jeg bare error. Har laget ett "delprogramm" for å teste ut hovedprogrammet. Her er koden:
Code:
'Hovedprogram
Private Sub Command1_Click()
Winsock.Close
Winsock.RemoteHost = Text2.Text
Winsock.RemotePort = 10101
Winsock.Connect
End Sub
Private Sub Form_Load()
txtoutput.Enabled = False
txtsendtxt.Enabled = False
cmdSend.Enabled = False
Text2.TabIndex = 0
Label1.BackColor = &HFF&
Label2.Caption = "Not Connected"
' Winsock code
Winsock.LocalPort = 10101
Winsock.Listen
End Sub
Private Sub Winsock_Close()
Text2.SetFocus
Text2.Locked = False
End Sub
Private Sub Winsock_Connect()
Label1.BackColor = &HFF00&
Label2.Caption = "Connected"
txtoutput.Enabled = True
txtsendtxt.Enabled = True
Text2.Locked = True
End Sub
Private Sub Winsock_ConnectionRequest(ByVal RequestID As Long)
Winsock.Close
Winsock.Accept RequestID
Text2.Locked = True
cmdSend.Enabled = True
End Sub
Private Sub Winsock_DataArrival(ByVal bytesTotal As Long)
Dim tEmp As String
Dim newData As String
tEmp = txtoutput.Text
Winsock.GetData newData
txtoutput.Text = tEmp & vbCrLf & newData
Winsock.Close
End Sub
Private Sub Winsock_Error(ByVal Number As Integer, Description As String, ByVal Scode As Long,
ByVal Source As String, ByVal HelpFile As String, ByVal HelpContext As Long, CancelDisplay As Boolean)
MsgBox "Error:" & vbCrLf & vbCrLf & Description, vbCritical, "ChtR - Error"
End Sub
Og hjelpeprogrammet:
Code:
Private Sub cmdConnect_Click()
Winsock.RemoteHost = "127.0.0.1"
Winsock.Connect
End Sub
Winsock.SendData ("test")
DoEvents
Winsock.Close
End Sub
MsgBox "Connected"
End Sub
Private Sub Winsock_Error(ByVal Number As Integer, Description As String, _
ByVal Scode As Long, ByVal Source As String, ByVal HelpFile As String, _
MsgBox "Error: " & vbCrLf & Description, vbCritical
End Sub
Hva er galt, hva skal jeg endre på for å få det til å virke ?
Erroren jeg får er :
Runtime error '40006':
Wrong protocol or connection state for the requested transaction or request
Edit: måtte fikse litt slik at det ikke ødela designet til hw.no
[ Denne Melding var redigert av: Dumbo på 2002-10-14 22:27 ]
i tillegg burde du legge til en rutine for å sjekke og du er tilkoblet før du prøver å sende noe.
bytt ut winsock.senddata X med:
if winsock.state = 7 then
winsock.senddata X
end if
state 7 betyr at du er tilkoblet serveren som client (hvis det er på serversiden trenger du en annen state, men husker den ikke i hodet).
