WinPatrol - versjon 10.0.1.0 lansert
G
Sikkerhetsprogramvaren WinPatrol's webside finner du her:
http://www.winpatrol.com/
Det finnes en gratis variant og en betal variant av programmet. Nedlastningslenken er for gratisvarianten.
Nedlastningslenker finner du her http://www.winpatrol.com/wpsetup.exe
Alternativt her http://www.winpatrol.com/download.html
Beskrivelse av programmet på engelsk:
Major WinPatrol 10 Innovations
      Hidden Icon  Hidden Files
      Scotty can now be set to monitor Hidden files in critical system areas. A new list of Hidden Files is available to help you clean up your machine. Almost all new infiltrations and/or root kits will attempt hiding their files but Scotty can detect them in real-time before any serious danger can be done. While many hidden files are normal system files, the introduction of new hidden files should be questioned. Now it can be.  The ability to delete hidden files will allow proper system cleanup. Right-click on the hidden file to view or delete.
      Task Icon  Date & Time Program First Detected
      Ever wonder when a new file was first introduced to your system?
      WinPatrol 10 detects and records the introduction of new program files and malware infiltrations. This new feature will allow you to detect files which have all infiltrated your system at the same time. Even if they have random file names or file names matching legitimate files you can sort files by Date Detected and Kill them all at once.
      File Type Icon  Lock File Type Associations
      This checkbox on the Options tab will allow you to keep your desired File Type associations settings without being annoyed by persistent programs.  Scotty will automatically restore your original settings.
      PLUS Icon  More Secret Startup Locations including WinLogon/Notify
      WinPatrol PLUS now monitors even more non-tradition Startup locations found in the registry. Disable unwanted programs including the Windows Genuine Advantage.
      HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\Notify
      Examples:WGALogon(Windows Genuine Advantage), GoToMyPC,Adware.Look2Me (O20)
New and Improved
      Optimized for Multiple Security Programs
      WinPatrol PLUS 10 has been optimized to work even better with other security programs. No one program can protect you and we recommend you don't rely on any single source of protection. WinPatrol PLUS 10 works even better while running other popular security and AntiSpyware programs.
      PLUS Info one click away
      By popular request we've made PLUS Info available on our main program lists. Just right-click on a program title and the menu will let you connect to our online database.
Endret av G
