abcd423417984 Skrevet 27. juni 2006 Del Skrevet 27. juni 2006 Hei Er det noen som vet hva "nitro mode", "device name" og "WDS" er godt for på 3com office-connect routere? Begge settings er plassert under wireless. Skulle sjekke manualen, men den forsvant da jeg flyttet nylig. Lenke til kommentar
no_viking_no Skrevet 27. juni 2006 Del Skrevet 27. juni 2006 Hei Er det noen som vet hva "nitro mode", "device name" og "WDS" er godt for på 3com office-connect routere? Begge settings er plassert under wireless. Skulle sjekke manualen, men den forsvant da jeg flyttet nylig. 6392643[/snapback] Nitro Mode Speed Conventionally, when an 802.11b device is present inside a 802.11g environment, the performance of the entire wireless network can be brought down to the same level as the 802.11b speed (or worse). This has been a particular challenging issue as the wireless networks are based on sharing architecture. The OvisLink 802.11g family are equipped with the latest Nitro Mode technology to lessen the b+g collision problem. Nitro mode adds “RTD/CTS“ packet in front of the "11g" packets to avoid the collision and the interference with "11b" clients. Furthermore, Packet Bursting is used to extend the timing for “11g" traffic. The end result is higher overall performance in the real world environment. WDS: http://en.wikipedia.org/wiki/Wireless_Distribution_System "device name" vet jeg ikke helt..... kan det vare med SSID å gjøre ? (Service Set Identifier)...... Lenke til kommentar
abcd423417984 Skrevet 27. juni 2006 Forfatter Del Skrevet 27. juni 2006 Nitro Mode SpeedConventionally, when an 802.11b device is present inside a 802.11g environment, the performance of the entire wireless network can be brought down to the same level as the 802.11b speed (or worse). This has been a particular challenging issue as the wireless networks are based on sharing architecture. The OvisLink 802.11g family are equipped with the latest Nitro Mode technology to lessen the b+g collision problem. Nitro mode adds “RTD/CTS“ packet in front of the "11g" packets to avoid the collision and the interference with "11b" clients. Furthermore, Packet Bursting is used to extend the timing for “11g" traffic. The end result is higher overall performance in the real world environment. Ok da er det vel lurest å la den stå On. "device name" vet jeg ikke helt..... kan det vare med SSID å gjøre ? (Service Set Identifier)...... 6392698[/snapback] SSID er et eget felt. Det står bare "device name (optional)". Er greit å vite hva det gjør før jeg setter det på. Lenke til kommentar
