Fedora - Drivere til pcmcia wifi kort. Gi opp?
Hmm... Nå skjedde det i hvertfall noe..
[root@localhost ****]# yum update --disablerepo=livna-stable
Loading "installonlyn" plugin
Setting up Update Process
Setting up repositories
core [1/5]
core 100% |=========================| 1.1 kB 00:00
updates [2/5]
updates 100% |=========================| 951 B 00:00
livna-testing [3/5]
http://rpm.livna.org/fedora/5/i386/RPMS.te...ata/repomd.xml: [Errno 14] HTTP Error 404: Date: Tue, 27 Jun 2006 17:55:27 GMT
Server: Apache/2.0.52 (CentOS)
Content-Length: 323
Content-Type: text/html; charset=iso-8859-1
Trying other mirror.
Cannot open/read repomd.xml file for repository: livna-testing
failure: repodata/repomd.xml from livna-testing: [Errno 256] No more mirrors to try.
Error: failure: repodata/repomd.xml from livna-testing: [Errno 256] No more mirrors to try.
Feilmeldinger der også:
[root@localhost ****]# yum update --disablerepo=livna-testing
livna-stable [1/5]
http://rpm.livna.org/fedora/5/i386/RPMS.st...ata/repomd.xml: [Errno 14] HTTP Error 404: Date: Tue, 27 Jun 2006 18:00:34 GMT
Content-Length: 322
Cannot open/read repomd.xml file for repository: livna-stable
failure: repodata/repomd.xml from livna-stable: [Errno 256] No more mirrors to try.
Error: failure: repodata/repomd.xml from livna-stable: [Errno 256] No more mirrors to try.
Takk for kjapt svar! Fortsatt noe gæli her...
[root@localhost ****]# yum update --disablerepo=livna-stable --disablerepo=livna-testing
core [1/4]
updates [2/4]
extras [3/4]
ftp://mirror.newnanutilities.org/pub/fedo...ata/repomd.xml: [Errno 4] IOError: [Errno ftp error] timed out
extras 100% |=========================| 1.1 kB 00:00
livna-unstable [4/4]
http://rpm.livna.org/fedora/5/i386/RPMS.un...ata/repomd.xml: [Errno 14] HTTP Error 404: Date: Tue, 27 Jun 2006 18:13:49 GMT
Content-Length: 324
Cannot open/read repomd.xml file for repository: livna-unstable
failure: repodata/repomd.xml from livna-unstable: [Errno 256] No more mirrors to try.
Error: failure: repodata/repomd.xml from livna-unstable: [Errno 256] No more mirrors to try.
Jaja.. etter updaten fikk jeg i hvertfall kjørt
[root@localhost]# yum install kmod-ndiswrapper --disablerepo=livna-stable --disablerepo=livna-testing --disablerepo=livna-unstable
Men så er jeg lost igjen.. Skal prøve mer når jeg er i form, og si fra om jeg kommer meg videre.
Logg deg inn som root med su -
Du må ha windowsdriverne tilgjengelig(.inf fil)
Skriv:
ndiswrapper -i /der/hvor/filen/ligger.inf
Deretter skal
/sbin/modprobe ndiswrapper
fungere.
Uh, fikk du faktisk installert kmod-ndiswrapper uten livna-repo? Jaja, det er ikke sikkert du må disable livna hver gang du installerer programvare.
Der dumma jeg meg visst litt ut... "yum install kmod-ndiswrapper --disablerepo=livna-stable --disablerepo=livna-testing --disablerepo=livna-unstable", startet, ja, men jeg ble ikke værende for å se hvordan det gikk. Ndiswrapper ble tydeligvis ikke installert... Når jeg fjerner alle livna repoene fra kommandoen finner ikke yum noen ndiswrapper.
Heisann! Nå går det litt bedre her! Etter mye om og men i dag (har ikke hatt tid i det siste) har jeg fått kobla laptopen opp mot trådløsnettet med ndiswrapper. Problemet er (nå) at ingenting skjer hvis jeg skriver nettadresser i browsere f. eks. Så jeg er visst ikke _helt_ på nett.. Noen forslag her? Mistenker at jeg ikke får tildelt ip eller no sånt fra routeren, men jeg er dessverre for grønn på linux og ndiswrapper til å finne ut av det :(
6439915[/snapback]
Kjør denne kommandoen som root og post tilbakemeldingen:
/sbin/iwconfig
hei! idag har laptopen min fått service. dvs ny harddisk, og winxp er installert. skal legge inn fedora igjen så fort jeg får tid. Takk for forsøk på hjelp mikis! skal poste her igjen når jeg er tilbake i fedora.
