Tastatur dummy
Er det en Compaq?
I såfall sett maskinen til "Server" en eller annen plass i BIOS så booter den uten tastatur...
Om det er en Compaq og du ikke har Server valget kan du bruke ei fil kallt: NO_F1.COM
Fra Compaq's sider:
SP0667.EXE - NO_F1.COM
All Compaq 386 and 486 based machines have the ability to run without a
keyboard attached. Some Compaq machines allow the user to select this mode
of operation by selecting "Network Server" mode in their setup program.
For those that do not offer this option NO_F1.COM is a DOS based program
that is run one time which sets a bit in CMOS that instructs the BIOS not
to wait for a keystroke after displaying the "Press [F1] to continue"
message.
This Softpaq (SP0667.EXE) replaces SP0378.EXE which is an older
version of NO_F1.COM.
NO_F1.COM kan du laste ned her:
ftp://ftp.compaq.com/pub/softpaq/sp0501-1...1000/sp0667.zip
Det er jo mulig denne fila funker med andre maskiner enn Compaq også...ikke vet jeg, men kan være verdt et forsøk..
[ Denne Melding var redigert av: Erra på 2002-10-14 01:35 ]
