Slå av pc over nettverk
Hei!
Har et lite spørsmål her.....
Er det noen som vet hvordan man kan skru av pcen over nettverk?
Fra en vanlig pc med windowsXP Pro.. skal skru av en annen pc med winxpPRO
Har prøvd med "ledetekst" i windows.. shutdown.exe -m \\datamaskinavn
fikk det ikke til....
Er dette egentlig mulig? Noen som har prøvd dette før?
Takker for alle svar...
Mvh
Holthegutten
Usage: shutdown.exe [/i | /l | /s | /r | /a | /p | /h | /e] [/f]
[/m \\computer][/t xxx][/d [p|u:]xx:yy [/c "comment"]]
No args Display help. This is the same as typing /?
/? Display help. This is the same as not typing any options
/i Display the graphical user interface (GUI).
This must be the first option
/l Log off. This cannot be used with /m or /d option
/s Shutdown the computer
/r Shutdown and restart the computer
/a Abort a system shutdown.
This can only be used during the time-out period
/p Turn off the local computer with no time-out or warning.
Can be used with /d and /f options
/h Hibernate the local computer.
Can be used with the /f option
/e Document the reason for an unexpected shutdown of a computer
/m \\computer Specify the target computer
/t xxx Set time-out period before shutdown to xxx seconds.
The valid range is 0-600, with a default of 30.
Note that the use of /t xxx imples that /f is set
/c "comment" Comment on the reason for the restart or shutdown.
Maximum of 512 characters allowed
/f Force running applications to close without forewarning users
/d [p|u:]xx:yy Provide the reason for the restart or shutdown
p indicates that the restart or shutdown is planned
u indicates that the reason is user defined
if neither p nor u is specified the restart or shutdown is unp
anned
xx is the major reason number (positive integer less than 256)
yy is the minor reason number (positive integer less than 65536)
Hei!
Mvh
Holthegutten
6358301[/snapback]
Et spørsmål, er detta sånn "kødde på LAN"-opplegg?
6358479[/snapback]
Tipper det ja :dontgetit:
Hehe tar shutdown på skolen hele tiden!! ;P
er litt morsomt til tider.. menne egentlig så er det ikke så morsomt når man har gjort det mye.. :p
En ting jeg bruker det til, er å sette på shutdown på min egen pc, setter tiden på ca en time
sette på musikk. så legger jeg meg :D herlich!! :yes:
Lager du en snarvei på maskinen din og skriver inn dette som "location" vil maskinen tvinge alle program til å avslutte for så å slå seg av uten forsinkelse når snarveien blir trykket på:
%windir%\System32\shutdown.exe -s -f -t 00
Edit: Hvorvidt den kan kjøres fra en annen maskin skal være usagt, men skulle tro det kan la seg gjøre via Remote Desktop e.l.
Kan også anbefales om du ønsker mulighet til å slå av maskinen din uten å måte gå gjennom startmenyen ved bare å ha en snarvei på skrivebordet som du trykker på. Så vidt jeg husker bytter du ut "-s" med "-r" om du vil lage en restart knapp/snarvei også.
Endret av squabbish
Hei!
Mvh
Holthegutten
6358301[/snapback]
Om du ser på posten til trondh, så ser du at du har skrevet litt feil, du skal skrive "shutdown.exe /m \\datamaskinavn" og ikke "shutdown.exe -m \\datamaskinnavn" (/m istedetfor -m)
Som andre har nevnt må du også ha administratortilgang for å gjøre dette!
Arcade
Endret av arcade
Takker for alle svar her.
Men har prøvd noe av det samme som dere har foreslått......
dette kommer når jeg har gjort som dere har beskrivet:
Bruk: shutdown.exe [-i | -l | -s | -r | -a] [-f] [-m \\datamaskinnavn] [-t xx] [
-c "kommentar"] [-d up:xx:yy]
Ingen argumenter Vis denne meldingen (samme som -
-i Vis GUI-grensesnitt, må være første alternativ
-l Logg av (kan ikke brukes med alternativet -m)
-s Slå av datamaskinen
-r Avslutt og start datamaskinen på nytt
-a Avbryt maskinavslutning
-m \\datamaskinnavn Ekstern datamaskin som skal avsluttes/startes på
nytt/avbrytes
-t xx Angi tidsavbrudd for avslutning til xx sekunder
-c "kommentar" Avslutningskommentar (maksimum 127 tegn)
-f Tvinger programmer som kjører å lukke uten advar
sel
-d [p]:xx:yy Årsakskode for avslutningen
u er brukerkoden
p er koden for en planlagt avslutning
xx er koden for hovedårsaken (positive heltall m
indre enn 256)
yy er koden for underordnede årsaker (positive h
eltall mindre enn 65536)
Maskinen som skal skrus av har ikke satt passord på administrator kontoen...
Takker igjen for alle svar! :D
Hvordan gir man administrator-rettigheter til den andre PC'en i nettverket da egentlig?
Du gir ikke administratorrettigheter til en maskin.
Under WindowsNT må alt som skal gjøres bli utført med en brukerkonto. Brukerkontoer blir lagt i brukergrupper som har forskjellig tilgang og forskjellige rettigheter. Som default er innstillingene ganske løse, men de fleste seriøse innstillinger for systemet er begrenset til administratorer, altså brukerene som er medlem av brukergruppen "administrators"/"administratorer". Å f.eks bruke MMC eller shutdown.exe over nettverket er begrenset for brukere av den brukergruppen.
Når du har to maskiner på et lokalnettverk og skal ha tilgang til den andre maskinen (for eksempel for å koble til delte mapper, MMC o.l) må du ha en bruker på maskinen du skal koble til som i følge den maskinens security policy har tilgang til å koble til over nettverket. Først må XPs [security settings\local policies\security options\network access:sharing and security model for local users] settes til "Classic" for å oppføre seg som andre NT-versjoner. Så logger du inn fra den andre maskinen, enten ved å bare kjøre \\maskinnavn eller en annen metode. Skriver du inn brukernavn/passord til en administrator på den andre maskinen vil du ha tilgang til det den maskins security policies gir deg tilgang til. Som default innebærer dette det meste.
Dersom du skriver \\maskinnavn, skriver inn en administrators brukernavn\passord vil du så ha en session mot den maskinen med administratortilgang. Dersom du da skriver shutdown -s -t 00 -m \\maskinnavn vil den maskinen øyeblikkelig skru seg av.
Jeg vil anbefale alle å låse ned deres system så mye som mulig for andre brukere, kun la din egen bruker ha tilgang til noe som helst, aldri gi bort ditt passord til noen som helst... gi de heller en begrenset bruker (ikke hva Windows XP kaller en "begrenset bruker", men en bruker du selv har begrenset tilgang for), bruke et godt passord (over 15 tegn er et must med mindre du deaktiverer den gamle LM-hash. Dersom passord er under 15 tegn og en person får administratortilgang til din maskin og har et program på f.eks minnepinne som leser ut LM-hashene kan han på sekunder lese ut alle passordene på maskinen din i klartekst), deaktivere automatiske administrator-sharings, begrense maskinens security policy, endre maskinens innloggingssystem, stramme inn NTFS-tilgang og mer.
Og de to viktigeste: Trust no one og opprett en backup-administrator.
Finnes det en guide for slik sikring av brukerkontoer her på forumet?
