Har MSI KT3 ULTRA støtte for 166 mhz fsb?
trondbue
Jeg ser at på msi sin hjemmeside står det blant annet:
VIA® KT333 (552 BGA) Chipset
- FSB @200/266MHz
- AGP 4X and PCI Advanced high performance memory
controller
FSB
100/133 (200/266)MHz clocks are supported
Main Memory
- Support six memory banks using three 184-pin DDR DIMMs
- Support a maximum memory size up to 3GB
- Support 2.5v DDR 200/266/333 DDR SDRAM DIMM
Mens om MSI KT3 ULTRA 2 står det dette:
VIA® KT333 Chipset
- FSB @200/266/333 MHz
controller
FSB
100/133/166 MHz clocks are supported.
Main Memory
* Supports six memory banks using three 184-pin DDR DIMMs
* Supports a maximum memory size up to 3GB
* Supports 2.5V DDR200/266/333 DDR SDRAM DIMM
Vil det si at en ikke kan kjøre 166mhx fsb på MSI KT3 Ultra?
