janken Skrevet 12. oktober 2002 Del Skrevet 12. oktober 2002 Er det kun denne som de har gitt ut? Battlefield 1942 Retail Patch v1.1 Lenke til kommentar
RogueFreak Skrevet 12. oktober 2002 Del Skrevet 12. oktober 2002 Ja, eneste offisielle patch hittil er 1.1 Teamet bak BF hadde en pressrelease for noen dager siden, der de annonserte hva de ville jobbe med fram mot 1.2 patchen. Siden du åpenbart ikke har giddi å lete frem dette selv, kan jeg jo lime det inn her da... "Atten-hut Soldiers! Thank you for making Battlefield 1942's launch a huge success. It's been three weeks since BF1942 hit the shelves and people all over the world are playing. First, we'd like to send out a BIG THANK YOU to those of you who are actively helping others on the BF1942 servers, patiently explaining how to fly certain planes, healing others, repairing vehicles as engineers, and all the other little things that have helped to create such a strong community. To Do List Update For those of you who have shared your thoughts on where we need to go next with BF1942... keep 'em coming. While we can't answer everyone's feedback personally, we are taking notes. As it stands our "To Do" list is pretty big. At the top of the list: - Linux Server - 1.2 Patch - Map Editor - Mod Tools We also have some updated information about the top list items. The Linux Server is currently going through the debug process and we're working hard to get it out as soon as possible. The 1.2 patch will address many of the issues which have been brought up on the forums and boards concerning bandwidth optimization, client prediction tweaking and general stability (sorry, Digger, we're not going to add a grappling hook!) The patch will also deliver the highly anticipated Map Editor. As for other mod tools, we're looking at what it would take to modify the existing dev tools for the mod-community. Stay tuned for more updates. See you on the battlefield! And remember, for weekly community updates, stay tuned to http://www.battlefield1942.com. ..................................... The Battlefield 1942 Production Team Lenke til kommentar
minimum payne Skrevet 12. oktober 2002 Del Skrevet 12. oktober 2002 hei rågefrik, du må jo huske på blood patch, det er knallbra patch altså, du ser om du treffer eller ikke, blir den blodspruten Lenke til kommentar
RogueFreak Skrevet 13. oktober 2002 Del Skrevet 13. oktober 2002 Funker den greit altså? Har lasta ned bloodpatchen, men ikke installert den enda... Åssen er det på musefronten da magnet mannen? Lenke til kommentar
minimum payne Skrevet 13. oktober 2002 Del Skrevet 13. oktober 2002 nei sliter med samme musa ennå, acrox hihi, det er merket ja. uansett har akkurat koblet opp peltierkjølinga nå på fredag. så det har ikke vært noe spilling i uka, men nå er jeg igang igjen. merkelig hvor få servere som takler over 30 stykker før de sliter? og det bloodpatchet kan jeg sende deg , det er bare to filer som skal legger i achives mappa under bf anbefaler det på det sterkeste, blir liksom 10 ganger mere action når blospruten står, særlig i nærkamp. Lenke til kommentar
AndersE Skrevet 13. oktober 2002 Del Skrevet 13. oktober 2002 Fungerer bloodpatchen på multiplayer også?? Er det en patch som EA har lagt ut?? Lenke til kommentar
kim Skrevet 13. oktober 2002 Del Skrevet 13. oktober 2002 Har bare hørt om en blood patch til bf1942, den sender cd keyen til den som har laget patchen. Lenke til kommentar
minimum payne Skrevet 13. oktober 2002 Del Skrevet 13. oktober 2002 patchet finner du her: http://www.bf1942.nl/?pagina=downloads/ind...tion=file&id=45 har brukt det i helga og det funker fint. Lenke til kommentar
