Det hender folk avskriver Python som et "script språk" (i betydningen shellscript med Wonderbaum, sjalusi, breie felger og diger spoiler). I slike situasjoner gir Google et godt svar (på dette som så mye annet).
Og svaret er så godt at om du lurer på om du bruker tida di på rett språk, så kan du begynne å lure på noe annet :)
Where is Python used (at Google)?
  • The Google build system is written in python. All of Google's
    corporate code is checked into a repository and the dependency and
    building of this code is managed by python. Greg mentioned that to
    create code.google.com took about 100 lines of python code. But since
    it has so many dependencies, the build system generated a 3 megabyte
    makefile for it!
  • Packaging. Google has an internal packaging format like RPM.
    These packages are created using python.
  • Binary Data Pusher. This is the area where Alex Martelli is
    working, on optimizing pushing bits between thousands of servers
  • Production servers. All monitoring, restarting and data
    collection functionality is done with python
  • Reporting. Logs are analyzed and reports are generated using Python.
  • A few services including code.google.com and google groups.
  • Martelli: I lead Production Systems, which includes parts of all of the above and yet more stuff (account management, network verification, etc etc) -- done mostly in Python, but with substantial helpers in C++ as well
Hentet fra
http://groups.google.com/group/comp.lang.p...ed5b2061c5cc0d/
Flere eye-openers
http://panela.blog-city.com/python_at_goog...in__sdforum.htm
