Svak PC, burde jeg bruke 98SE eller XP Pro?
Først litt system info: (liten kopi av DxDiag)
System Information
Time of this report: 6/19/2006, 12:04:30
Machine name: OSLAnita_HPC
Operating System: Windows 98 (4.10, Build 2222) A
Language: Norwegian (Bokmål) (Regional Setting: Norwegian (Bokmål))
System Manufacturer: n/a
System Model: n/a
BIOS: n/a
Processor: Intel Pentium III, ~700MHz
Memory: 128MB RAM
Page File: 103MB used, 1816MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: /Silent
DxDiag Version: 4.09.0000.0904 32bit
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Number Nine Pepper M32 (Norwegian)
Manufacturer: NVIDIA
Chip type:
DAC type:
Device Key: Enum\PCI\VEN_10DE&DEV_002D&SUBSYS_0002105D&REV_15\000800
Display Memory: 31.5 MB
Current Mode: 1024 x 768 (32 bit)(optimal refresh rate)
Monitor: IBM 0183 C92
Monitor Max Res: 1600,1200
Driver Name: nvdisp.drv
Driver Version: 4.12.0001.0362 (English)
DDI Version: 7
Driver Attributes: Final Retail
Driver Date/Size: 12/8/1999 02:06:02, 66592 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: 6/1/1999
VDD: *vdd
Mini VDD: nvmini.vxd
Mini VDD Date: , 0 bytes
Device Identifier: {D7B71E3E-436D-11CF-8772-0320B6C2C935}
Vendor ID: 0x10DE
Device ID: 0x002D
SubSys ID: 0x0002105D
Revision ID: 0x0015
Revision ID: 0x0015
Video Accel:
Deinterlace Caps: n/a
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: ESS PCI Solo-1 DirectSound Driver
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCI\VEN_125D&DEV_1969&SUBSYS_01651014&REV_01\BUS_00&DEV_0B&FUNC_00
Manufacturer ID: 46
Product ID: 46
Type: VXD
Driver Name: ESSOLO.VXD
Driver Version: 4.06.0000.1121 (English)
Driver Attributes: Beta Retail
WHQL Logo'd: Yes
Date and Size: 5/19/1999 22:30:40, 46733 bytes
Other Files: essolo.vxd
Driver Provider: ESS
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 100000
Static/Strm HW Mix Bufs: 42, 42
Static/Strm HW 3D Bufs: 42, 42
HW Memory: 16777216
Voice Management: Yes
EAX 2.0 Listen/Src: No, No
I3DL2 Listen/Src: No, No
Sensaura ZoomFX: No
Registry: OK
Sound Test Result: Not run
Jeg har måtte gi fra meg PC-en min, og får ikke kjøpt meg en ny en før i august eller noe sånt...
Derfor må jeg bruke mamma sin gammle PC frem til jeg får min nye...
Ovenfor har jeg limt inn en liten del av DxDiag til detta skrapet...
Som dere ser så kjører den Windows 98SE
Det jeg lurer på er om jeg burde installere og kjøre Windows XP Pro SP2,
isteden for 98SE... Eller er PC-en for svak til det?
Alt jeg kan gjøre på PC-en uansett, om jeg kjører 98SE eller ikke er bare å sørfe på nettet med FireFox, chatte med MSN og høre på litt musikk...
Så burde jeg installere XP på detta skrapet, eller blir det for mye for den?
På den gamle dataen min (1,3 GHz, 384 MB RAM, Radeon 9200) gjekk XP fortare enn Windows 2000.
6337569[/snapback]
Mest sannsynlig pga at 2000 hadde vært installert i et par år og samlet opp masse drittprogrammer, mens du hadde en helt nyvasket harddisk da du installerte XP. :)
Jeg har installert Win2000 på lillebror sin maskin. Det er en Pentium III 600 MHz med 129 MB RAM. Det fungerer veldig bra til Firefox, WinAmp, MSN osv., og er relativt kjapt så lenge du er kritisk til hva du installerer (styling, tulleprogrammer osv.) og er flink med vedlikehold og oppsett.
Også kjører vi Windows XP på noen skikkelige vrak på skolen. De er fullstappet med dritt og har gammel hardware (husker dessverre ikke detaljer), men mange av dem er helt greie å bruke så lenge man vet hvordan man håndterer slike saker.
Jeg tror det går bra å legge inn WinXP hvis du slår av XP Style (og kjører Windows classic) og slår av diverse greier i: System -> Avansert -> Ytelse. Du kan også avinstallere mye dritt i: Kontrollpanel -> Legg til/fjern programmer -> Windowskomponenter.
Jeg synes stabiliteten og mulighetene er såpass mye verdt at jeg ville installert WinXP (eller Win2000 hvis du får tak i) og strippet det så godt som mulig.
Linux er vel best på såpass svak pc.
6337456[/snapback]
Da må han skreddersy, en moderne Linux med allt av fancy GUI er ikke noen stor opplevelse på denne maskinvaren.
win2000 og noen brukte minnebrikker så vil det flyte bra. 128MB er alt for lite uansett.
6337569[/snapback]
6340039[/snapback]
Nope, hadde ein heilt fersk installasjon av 2k.
6337456[/snapback]
6340436[/snapback]
Nei. Det spørs hvor flink og kresen man er.
Og som du sier, så er nyeste Linux-versjon med GUI minst like krevende som Windows XP.
