Selecting Motherboard with Wake On LAN
ajocius
Looking for the list of motherboards supporting Wake on LAN. Find it very difficult to figure out which motherboards supports this functionality and which one does not. I almost need to download manual and read it ... Hopefully someone came accross good web page that can filter motherboards only with WOL support. Hw.no unfortunately does not have this filter.
This I thought was supported by almost every mb these days, or they do not? With implemented LAN, as any card got, the Wake On Lan got the support in BIOS aswell, I presumed ... ( except some cheap brand maybe?)
I recommend you decide which mb meats other specs you'd like onboard - or in particular. Include the general functionality. When tests are found to be satisfactory and the price is right, then go check out the WOL.
