Error Code: F4D41436
Caddy
Fant et par tråder fra 2004 ang. denne feilmeldingen, men svarene hjalp meg ikke mye..
DVD skal kjøres på Acer Travelmate 230.
PowerDVD 5 er installert.
Får samme feilmelding i windows mediaplayer.
"Error Code: F4D41436
The TV Out port of your display card is not working properly."
Details:
"This copy protected disc can not be played when the TV out function is enabled."
Skjermkort typen er Intel Montara-GML.. ?
Noen flere forslag til hva som kan være problemet med disse? Andre forslag enn hva som står i de andre trådene....
Takker for svar!
Edit:
Google gir meg mange svar på hva jeg skal gjøre om jeg har nVidia skjermkort... Men det er det jo ikke...
Endret av Caddy
Copy protection support is added to the display driver in a laptop PC. Laptop PCs without any copy protection facilitate illegal copying of optical disks such as digital-versatile disk (DVD), since some laptop PCs now include a TV encoder (scan-line converter) that converts the computer-generated formats such as SVGA to TV formats such as NTSC and PAL. While VCRs cannot make copies of computer formats such as SVGA, a VCR connected to the laptop PCs TV-encoder output can make an illegal videocassette copy of a DVD title. The portability of laptop PCs makes them particularly attractive to video thieves. Some PCs are being equipped with TV encoders with advanced copy-protection features such as MacroVision encoders. The video BIOS determines if the TV encoder is MacroVision compliant and is queried by the display driver when a DVD navigator or player requests MacroVision encoding. MacroVision-compliant TV encoders add low-level pulses to the TV output that TV sets confuse with sync pulses degraded by VCR copying. Thus the TV output cannot be copied when MacroVision encoding is used. The display driver emulates copy-protection for older TV encoders that are not MacroVision-compliant. The display driver stops play of copy-protected DVD titles until a user disables the TV output. Multiple DVD players are controlled by the display driver by storing a list of DVD identifiers an the DVD identifier of the last DVD navigator or player to enable MacroVision encoding.
Macrovision.. Highlighted my me.
Kilde:Kilde
mvh r.-
