GS500 vs GS300
Hei,
skal kjøpe meg kamera, og har bestemt meg for å satse på Panasonic, men vurderer begge modellene nevnt i emnetittelen.
Er det vesentlig forskjeller mellom disse modellene (foruten megapixlene)?
Anders
GS500 har litt større biletsensorar, og er dermed litt meir lyssterkt. Her er kva Camcorderinfo seier om GS500 samanlikna med GS300 (dei har testa amerikanske modellar, men trur dei er like dei norske, sett bort frå PAL/NTSC):
The PV-GS300 is this year’s step-down model from the PV-GS500. Like the GS500, the GS300 took a big step back from its predecessor, dropping a lot of features and lowering the price to try and entice consumers. It is missing a manual focus ring and has smaller chips (1/6” vs. 1/4.7), a smaller maximum aperture (f/1.8 vs. f/1.6), a cold rather than hot accessory shoe, a smaller optical zoom (10x vs. 12x), a lower max still size (3.1 versus 4.0), and no Cinema mode. The smaller chip size made a sizable impact in low light performance. Finally, the GS500 offers true widescreen, while the GS300 uses a crop-and-zoom technique to obtain 16:9 aspect ratio.
That is a pretty substantial list. Do these features add up to $300? That’s the real question you need to ask yourself. Even if you do choose to step up to the GS500, you’ll still be missing many of the great features of the GS400 and GS250 (the GS300 predecessor). Yes, the GS500 is better than the GS300, but we first recommend you dig around for some of last year’s model.
Testen av GS500 finn du her, testen av GS300 finn du her.
