Brukervenlig, norsk fotoalbum
Ja, man laster det opp via nett, en og en fil eller som zip-fil. :)
Fikk du noen feilmeldinger?
Fulgte du readme-instruksene da?
1. CHMOD the following files/folders to 777 so that the script has writing-permission for it:
  a) temp_images/
  b) albums/
  c) search_index.txt
2. Open config.inc.php and change the settings to fit your needs.
3. Run ezgallery.php?selftest to make sure everything is OK.
  • 2 uker senere...
