brrah Skrevet 3. juni 2006 Del Skrevet 3. juni 2006 Micro-ATX: Produkt Vurdering Antall Enhetspris Linjepris AMD Athlon 64 3000+ 1.8GHz Socket 939, 512KB, BOXED m/vifte Dato ny: 2006-06-01; Pris ny: 995.00; Prisdiff: .00% 100+ stk på lager Kommentar: 995.00 995.00 Aspire X-Qpack Sort mATX, Aluminium, 120mm Vifte, 420W Strømforsyning Dato ny: 2006-06-01; Pris ny: 829.00; Prisdiff: .00% Ikke på lager. Ubekreftet 100 stk 2006-06-21 Kommentar: 829.00 829.00 Asus A8V-MX, K8M800, Socket-939, m-ATX LAN, S-ATA, Raid, Lyd, VGA, AGP8X Dato ny: 2006-06-01; Pris ny: 475.00; Prisdiff: .00% Ikke på lager. Ubekreftet 20 stk 2006-06-03 Kommentar: 475.00 475.00 Kingston ValueR. PC3200 DDR-DIMM 512MB 64MX64,Non-ECC,400MHz,184-pin,CL3(3-3-3) Dato ny: 2006-06-01; Pris ny: 425.00; Prisdiff: .00% 50-99 stk på lager Kommentar: 425.00 425.00 Samsung DVD-brenner SH-S162A IDE Black OEM Dato ny: 2006-06-01; Pris ny: 250.00; Prisdiff: -58.00% 500+ stk på lager Kommentar: 395.00 395.00 Samtron/Samsung 17" LCD Syncmaster 74V TCO99 Silver, 1280x1024, 600:1,8ms, VGA Dato ny: 2006-06-01; Pris ny: 1695.00; Prisdiff: .00% 500+ stk på lager Kommentar: 1695.00 1695.00 4814.00 4814.00 ATX: Produkt Vurdering Antall Enhetspris Linjepris AMD Athlon 64 3000+ 1.8GHz Socket 939, 512KB, BOXED m/vifte Dato ny: 2006-06-01; Pris ny: 995.00; Prisdiff: .00% 100+ stk på lager Kommentar: 995.00 995.00 Kingston ValueR. PC3200 DDR-DIMM 512MB 64MX64,Non-ECC,400MHz,184-pin,CL3(3-3-3) Dato ny: 2006-06-01; Pris ny: 425.00; Prisdiff: .00% 50-99 stk på lager Kommentar: 425.00 425.00 MSI K8N NEO2-FX,nForce3 250Gb,Socket-939 Raid, ATX, SATA, GbLAN, Lyd, AGP8X Dato ny: 2006-06-01; Pris ny: 575.00; Prisdiff: .00% 50-99 stk på lager Kommentar: 575.00 575.00 Q-Tec Midi tower ATX, Sort, H-Serien, 2 X USB 2.0, Med 350W Strømforsyning Dato ny: 2006-06-01; Pris ny: 449.00; Prisdiff: .00% 100+ stk på lager Kommentar: 449.00 449.00 Samsung DVD-brenner SH-S162A IDE Black OEM Dato ny: 2006-06-01; Pris ny: 250.00; Prisdiff: -58.00% 500+ stk på lager Kommentar: 395.00 395.00 Samtron/Samsung 17" LCD Syncmaster 74V TCO99 Silver, 1280x1024, 600:1,8ms, VGA Dato ny: 2006-06-01; Pris ny: 1695.00; Prisdiff: .00% 500+ stk på lager Kommentar: 1695.00 1695.00 4534.00 4534.00 Først og fremst, passer delene sammen? Og vil det oppstå noe varme eller andre problemer? HD, grafikkort og en 512 mb ram brikke har jeg, grafikkortet er AGP derfor bestilte jeg et AGP HK... Lenke til kommentar
pizzafordi Skrevet 3. juni 2006 Del Skrevet 3. juni 2006 micro-atx hovedkort passer til de fleste kabinetter vanlig hovedkort atx passer kun til midi-kabinetter mini-micro=micro-atx kansje noen atx er mellom atx og midi kabinetter og passer dermed i mini-case. unngå q-tec kabinett, iallefall q-tec strømforsyning m-atx kabinett skal ha spesiell strømforsynig sånn jeg har forstått det. en kan kjøpe mini-kabinett med micro-atx hovedkort og normal strømforsyning er vel relativt liten pc. kjøp 1gb ram. Lenke til kommentar
pizzafordi Skrevet 3. juni 2006 Del Skrevet 3. juni 2006 http://www.psdata.no/ps.asp?it=128795 Lenke til kommentar
MrAHB Skrevet 3. juni 2006 Del Skrevet 3. juni 2006 Hvis du skal ha ATX bør du heller gå for Asrock kortet som støtter både PCIe og AGP. Men det er ikke noe feil med m-atx, bra greier det Lenke til kommentar
pizzafordi Skrevet 3. juni 2006 Del Skrevet 3. juni 2006 Hvis du skal ha ATX bør du heller gå for Asrock kortet som støtter både PCIe og AGP. Men det er ikke noe feil med m-atx, bra greier det 6235274[/snapback] det er noe en kjøper hvis en har et bra agp kort fra før på et gammelt hovedkort som senker hastigheten på skjermkortet. micro atx har jo integrert skjermkort 6100/6150 evt dårlige via/intel/ati x200 Lenke til kommentar
brrah Skrevet 3. juni 2006 Forfatter Del Skrevet 3. juni 2006 Men PASSER det jeg har satt sammen der? Og det vil ikek bli for høy varmeutvikling og slikt? Takker for svar btw Lenke til kommentar
MrAHB Skrevet 3. juni 2006 Del Skrevet 3. juni 2006 Har du tenkt å bruke AGP kortet ditt eller ikke? Det blir nok ikke for varmt, men du bør ha to LIKE minnebrikker. Lenke til kommentar
efikkan Skrevet 3. juni 2006 Del Skrevet 3. juni 2006 Hei! Parvis like minnebrikker gir ytelsefordel. Styr unna Q-tec, de er ikke brukbare. Hilsen, efikkan. Lenke til kommentar
brrah Skrevet 4. juni 2006 Forfatter Del Skrevet 4. juni 2006 Har du tenkt å bruke AGP kortet ditt eller ikke? Det blir nok ikke for varmt, men du bør ha to LIKE minnebrikker. 6236396[/snapback] Skal bruke AGP-kortet, ja.. Har jeg sagt noe annet? Har en KLIN lik rambrikke her hjemme =) Hei! Parvis like minnebrikker gir ytelsefordel. Styr unna Q-tec, de er ikke brukbare. Hilsen, efikkan. 6238017[/snapback] Jaok, om jeg går for vanlig ATX velger jeg et annet kabinett.. Men har et litt stramt budsjett her... Men ellers er det ikke noe å si på disse 2 alternativene? Takker for svar alle sammen...! Lenke til kommentar
