qualbeen Skrevet 31. mai 2006 Del Skrevet 31. mai 2006 Er litt ny på linux, men ikke helt n00b. har fått lagt til de fleste programmer jeg vil ha, men sliter nå litt med bluefish Ok, jeg sliter mye! har lastet ned nyeste versjon og pakket ut denne - men blir ikke klok på hvordan jeg skal gå videre... har prøvd å kjøre install-sh og configure (2 sh-filer i mappen), men det hjelper lite.. har lagt ved loggen: (klager blandt annet over "missing C compiler"??) Skjult tekst: (Marker innholdet i feltet for å se teksten): This file contains any messages produced by compilers whilerunning configure, to aid debugging if configure makes a mistake. It was created by configure, which was generated by GNU Autoconf 2.59. Invocation command line was $ configure ## --------- ## ## Platform. ## ## --------- ## hostname = linux uname -m = x86_64 uname -r = 2.6.13-15.10-default uname -s = Linux uname -v = #1 Fri May 12 16:13:03 UTC 2006 /usr/bin/uname -p = unknown /bin/uname -X = unknown /bin/arch = x86_64 /usr/bin/arch -k = unknown /usr/convex/getsysinfo = unknown hostinfo = unknown /bin/machine = unknown /usr/bin/oslevel = unknown /bin/universe = unknown PATH: /usr/local/bin PATH: /usr/bin PATH: /sbin PATH: /usr/X11R6/bin PATH: /usr/sbin PATH: /bin PATH: /usr/games PATH: /opt/gnome/bin PATH: /opt/kde3/bin PATH: /usr/lib/jvm/jre/bin PATH: /usr/lib/mit/bin PATH: /usr/lib/mit/sbin ## ----------- ## ## Core tests. ## ## ----------- ## configure:1445: checking for gcc configure:1474: result: no configure:1525: checking for cc configure:1554: result: no configure:1567: checking for cc configure:1613: result: no configure:1666: checking for cl configure:1695: result: no configure:1709: error: no acceptable C compiler found in $PATH See `config.log' for more details. ## ---------------- ## ## Cache variables. ## ## ---------------- ## ac_cv_env_CC_set= ac_cv_env_CC_value= ac_cv_env_CFLAGS_set= ac_cv_env_CFLAGS_value= ac_cv_env_CPPFLAGS_set= ac_cv_env_CPPFLAGS_value= ac_cv_env_CPP_set= ac_cv_env_CPP_value= ac_cv_env_LDFLAGS_set= ac_cv_env_LDFLAGS_value= ac_cv_env_build_alias_set= ac_cv_env_build_alias_value= ac_cv_env_host_alias_set= ac_cv_env_host_alias_value= ac_cv_env_target_alias_set= ac_cv_env_target_alias_value= ## ----------------- ## ## Output variables. ## ## ----------------- ## ALLOCA='' ALL_LINGUAS='bg cs da de es eu fi fr hu it ja no pl pt pt_BR ru sk sr sv ta tr zh_CN zh_TW' BUILD_INCLUDED_LIBINTL='' CATALOGS='' CATOBJEXT='' CC='' CFLAGS='' CPP='' CPPFLAGS='' DATADIRNAME='' DEFS='' ECHO_C='' ECHO_N='-n' ECHO_T='' EGREP='' EXEEXT='' EXTERNAL_FIND='' EXTERNAL_GREP='' FDMENU='' FDMIME='' GAPPREG='' GENCAT='' GLIBC21='' GMIMEINFO='' GMOFILES='' GMSGFMT='' GNOME1MENU='' HAVE_GNOME_VFS='' ICONPATH='' INSTALLDATA='' INSTALLMAIN='' INSTALL_DATA='' INSTALL_PROGRAM='' INSTALL_SCRIPT='' INSTOBJEXT='' INTLBISON='' INTLLIBS='' INTLOBJS='' INTL_LIBTOOL_SUFFIX_PREFIX='' LDFLAGS='' LIBICONV='' LIBOBJS='' LIBS='' LTLIBOBJS='' MAKEMAIN='' MKINSTALLDIRS='' MSGFMT='' MSGMERGE='' OBJEXT='' PACKAGE='bluefish' PACKAGE_BUGREPORT='' PACKAGE_NAME='' PACKAGE_STRING='' PACKAGE_TARNAME='' PACKAGE_VERSION='' PATH_SEPARATOR=':' PCRE_CONFIG='' PKG_CONFIG='' POFILES='' POSUB='' RANLIB='' SET_MAKE='' SHELL='/bin/sh' UPDATE_DESKTOP='' UPDATE_MIME='' USE_INCLUDED_LIBINTL='' USE_NLS='' VERSION='1.0.5' XGETTEXT='' ac_ct_CC='' ac_ct_RANLIB='' bindir='${exec_prefix}/bin' build='' build_alias='' build_cpu='' build_os='' build_vendor='' datadir='${prefix}/share' exec_prefix='NONE' host='' host_alias='' host_cpu='' host_os='' host_vendor='' includedir='${prefix}/include' infodir='${prefix}/info' libdir='${exec_prefix}/lib' libexecdir='${exec_prefix}/libexec' localedir='' localstatedir='${prefix}/var' mandir='${prefix}/man' oldincludedir='/usr/include' pkgdatadir='' prefix='NONE' program_transform_name='s,x,x,' sbindir='${exec_prefix}/sbin' sharedstatedir='${prefix}/com' sysconfdir='${prefix}/etc' target_alias='' ## ----------- ## ## confdefs.h. ## ## ----------- ## #define CONFIGURE_OPTIONS "configure " #define CURRENT_VERSION_NAME "bluefish 1.0.5 HTML editor" #define PACKAGE "bluefish" #define PACKAGE_BUGREPORT "" #define PACKAGE_NAME "" #define PACKAGE_STRING "" #define PACKAGE_TARNAME "" #define PACKAGE_VERSION "" #define VERSION "1.0.5" configure: exit 1 --- noen som vet hva jeg kan gjøre? Lenke til kommentar
JonJ Skrevet 31. mai 2006 Del Skrevet 31. mai 2006 Brug rug/YaST: http://www.thejemreport.com/mambo/content/view/254/42/ Lenke til kommentar
