Richard87 Skrevet 29. mai 2006 Del Skrevet 29. mai 2006 Jeg prover meg pa CreateService i VB6, skal innstalere en kernel driver, men ingen av funksjonene fungerer! Er det noen her som har erfaring med VB6 Services etc? btw, her er koden min: (clsService) Option Explicit Private Type SERVICE_STATUS dwServiceType As Long dwCurrentState As Long dwControlsAccepted As Long dwWin32ExitCode As Long dwServiceSpecificExitCode As Long dwCheckPoint As Long dwWaitHint As Long End Type Private Const STANDARD_RIGHTS_REQUIRED As Long = &HF0000 Private Const ERROR_SERVICE_ALREADY_RUNNING As Long = 1056& Private Const ERROR_SERVICE_MARKED_FOR_DELETE As Long = 1072& Private Const ERROR_SERVICE_EXISTS As Long = 1073& Private Const ERROR_SERVICE_DATABASE_LOCKED As Long = 1055& Private Const ERROR_SERVICE_DEPENDENCY_DELETED As Long = 1075& Private Const ERROR_SERVICE_DEPENDENCY_FAIL As Long = 1068& Private Const ERROR_SERVICE_DISABLED As Long = 1058& Private Const ERROR_SERVICE_LOGON_FAILED As Long = 1069& Private Const ERROR_SERVICE_NO_THREAD As Long = 1054& Private Const ERROR_SERVICE_REQUEST_TIMEOUT As Long = 1053& Private Const ERROR_SERVICE_CANNOT_ACCEPT_CTRL As Long = 1061& Private Const ERROR_SERVICE_NOT_ACTIVE As Long = 1062& Private Const ERROR_INVALID_HANDLE As Long = 6& Private Const ERROR_INVALID_NAME As Long = 123& Private Const ERROR_INVALID_PARAMETER As Long = 87 Private Const ERROR_INVALID_SERVICE_ACCOUNT As Long = 1057& Private Const ERROR_INVALID_SERVICE_CONTROL As Long = 1052& Private Const ERROR_PATH_NOT_FOUND As Long = 3& Private Const ERROR_ACCESS_DENIED As Long = 5& Private Const ERROR_CIRCULAR_DEPENDENCY As Long = 1059& Private Const ERROR_DUP_NAME As Long = 52& Private Const ERROR_DEPENDENT_SERVICES_RUNNING As Long = 1051& Private Const ERROR_SHUTDOWN_IN_PROGRESS As Long = 1115& Private Const SC_MANAGER_CONNECT As Long = &H1 Private Const SC_MANAGER_CREATE_SERVICE As Long = &H2 Private Const SC_MANAGER_ENUMERATE_SERVICE As Long = &H4 Private Const SC_MANAGER_LOCK As Long = &H8 Private Const SC_MANAGER_MODIFY_BOOT_CONFIG As Long = &H20 Private Const SC_MANAGER_QUERY_LOCK_STATUS As Long = &H10 Private Const SC_MANAGER_ALL_ACCESS As Long = (STANDARD_RIGHTS_REQUIRED Or SC_MANAGER_CONNECT Or SC_MANAGER_CREATE_SERVICE Or SC_MANAGER_ENUMERATE_SERVICE Or SC_MANAGER_LOCK Or SC_MANAGER_QUERY_LOCK_STATUS Or SC_MANAGER_MODIFY_BOOT_CONFIG) Private Const SERVICE_QUERY_CONFIG As Long = &H1 Private Const SERVICE_CHANGE_CONFIG As Long = &H2 Private Const SERVICE_QUERY_STATUS As Long = &H4 Private Const SERVICE_ENUMERATE_DEPENDENTS As Long = &H8 Private Const SERVICE_START As Long = &H10 Private Const SERVICE_STOP As Long = &H20 Private Const SERVICE_PAUSE_CONTINUE As Long = &H40 Private Const SERVICE_INTERROGATE As Long = &H80 Private Const SERVICE_USER_DEFINED_CONTROL As Long = &H100 Private Const SERVICE_ALL_ACCESS As Long = (STANDARD_RIGHTS_REQUIRED Or SERVICE_QUERY_CONFIG Or SERVICE_CHANGE_CONFIG Or SERVICE_QUERY_STATUS Or SERVICE_ENUMERATE_DEPENDENTS Or SERVICE_START Or SERVICE_STOP Or SERVICE_PAUSE_CONTINUE Or SERVICE_INTERROGATE Or SERVICE_USER_DEFINED_CONTROL) Private Const SERVICE_KERNEL_DRIVER As Long = &H1 Private Const SERVICE_DEMAND_START As Long = &H3 Private Const SERVICE_ERROR_NORMAL As Long = &H1 Private Const SERVICE_CONTROL_STOP As Long = &H1 Private Const SERVICE_BOOT_START As Long = &H0 Private Declare Function OpenSCManager Lib "advapi32.dll" Alias "OpenSCManagerA" (ByVal lpMachineName As String, ByVal lpDatabaseName As String, ByVal dwDesiredAccess As Long) As Long 'SC_HANDLE OpenSCManager( Private Declare Function ControlService Lib "advapi32.dll" (ByVal hService As Long, ByVal dwControl As Long, ByRef lpServiceStatus As SERVICE_STATUS) As Long Private Declare Function CreateService Lib "advapi32.dll" Alias "CreateServiceA" (ByVal hSCManager As Long, ByVal lpServiceName As String, ByVal lpDisplayName As String, ByVal dwDesiredAccess As Long, ByVal dwServiceType As Long, ByVal dwStartType As Long, ByVal dwErrorControl As Long, ByVal lpBinaryPathName As String, ByVal lpLoadOrderGroup As String, ByRef lpdwTagId As Long, ByVal lpDependencies As String, ByVal lp As String, ByVal lpPassword As String) As Long Private Declare Function CloseServiceHandle Lib "advapi32.dll" (ByVal hSCObject As Long) As Long Private Declare Function GetLastError Lib "kernel32.dll" () As Long Private Declare Function OpenService Lib "advapi32.dll" Alias "OpenServiceA" (ByVal hSCManager As Long, ByVal lpServiceName As String, ByVal dwDesiredAccess As Long) As Long Private Declare Function StartService Lib "advapi32.dll" Alias "StartServiceA" (ByVal hService As Long, ByVal dwNumServiceArgs As Long, ByVal lpServiceArgVectors As Long) As Long Private Declare Function DeleteService Lib "advapi32.dll" (ByVal hService As Long) As Long Private Declare Sub Sleep Lib "kernel32.dll" (ByVal dwMilliseconds As Long) Public Function GetErrorDescription(lError As Long, nFunction As Long) As String Dim strText As String Select Case nFunction Case 1: 'Install Select Case lError Case ERROR_ACCESS_DENIED: strText = "The handle to the specified service control manager database does not have SC_MANAGER_CREATE_SERVICE access." Case ERROR_CIRCULAR_DEPENDENCY: strText = "A circular service dependency was specified." Case ERROR_DUP_NAME: strText = "The display name already exists in the service control manager database either as a service name or as another display name." Case ERROR_INVALID_HANDLE: strText = "The handle to the specified service control manager database is invalid." Case ERROR_INVALID_NAME: strText = "The specified service name is invalid." Case ERROR_INVALID_PARAMETER: strText = "A parameter that was specified is invalid." Case ERROR_INVALID_SERVICE_ACCOUNT: strText = "The user account name specified in the lpServiceStartName parameter does not exist." Case ERROR_SERVICE_EXISTS: strText = "The specified service already exists in this database." End Select Case 2: 'Uninstall Select Case lError Case ERROR_ACCESS_DENIED: strText = "The specified handle was not opened with DELETE access." Case ERROR_INVALID_HANDLE: strText = "The specified handle is invalid." Case ERROR_SERVICE_MARKED_FOR_DELETE: strText = "The specified service has already been marked for deletion." End Select Case 3: 'Stop Select Case lError Case ERROR_ACCESS_DENIED: strText = "The specified handle was not opened with the necessary access." Case ERROR_DEPENDENT_SERVICES_RUNNING: strText = "The service cannot be stopped because other running services are dependent on it." Case ERROR_INVALID_HANDLE: strText = "The specified handle was not obtained using CreateService or OpenService, or the handle is no longer valid." Case ERROR_INVALID_PARAMETER: strText = "The requested control code is undefined." Case ERROR_INVALID_SERVICE_CONTROL: strText = "The requested control code is not valid, or it is unacceptable to the service." Case ERROR_SERVICE_CANNOT_ACCEPT_CTRL: strText = "The requested control code cannot be sent to the service because the state of the service is SERVICE_STOPPED, SERVICE_START_PENDING, or SERVICE_STOP_PENDING." Case ERROR_SERVICE_NOT_ACTIVE: strText = "The service has not been started." Case ERROR_SERVICE_REQUEST_TIMEOUT: strText = "The process for the service was started, but it did not call StartServiceCtrlDispatcher, or the thread that called StartServiceCtrlDispatcher may be blocked in a control handler function." Case ERROR_SHUTDOWN_IN_PROGRESS: strText = "The system is shutting down." End Select Case 4: 'Start Select Case lError Case ERROR_ACCESS_DENIED: strText = "The specified handle was not opened with SERVICE_START access." Case ERROR_INVALID_HANDLE: strText = "The specified handle is invalid." Case ERROR_PATH_NOT_FOUND: strText = "The service binary file could not be found." Case ERROR_SERVICE_ALREADY_RUNNING: strText = "An instance of the service is already running." Case ERROR_SERVICE_DATABASE_LOCKED: strText = "The database is locked." Case ERROR_SERVICE_DEPENDENCY_DELETED: strText = "The service depends on a service that does not exist or has been marked for deletion." Case ERROR_SERVICE_DEPENDENCY_FAIL: strText = "The service depends on another service that has failed to start." Case ERROR_SERVICE_DISABLED: strText = "The service has been disabled." Case ERROR_SERVICE_LOGON_FAILED: strText = "The service could not be logged on." Case ERROR_SERVICE_MARKED_FOR_DELETE: strText = "The service has been marked for deletion." Case ERROR_SERVICE_NO_THREAD: strText = "A thread could not be created for the service." Case ERROR_SERVICE_REQUEST_TIMEOUT: strText = "The process for the service was started, but it did not call StartServiceCtrlDispatcher, or the thread that called StartServiceCtrlDispatcher may be blocked in a control handler function." End Select End Select GetErrorDescription = strText End Function Public Function Start(strName As String) As Boolean Dim hService As Long, hSCM As Long, ret As Long, SS As SERVICE_STATUS Start = False hSCM = OpenSCManager(vbNullString, vbNullString, SC_MANAGER_ALL_ACCESS) If hSCM = 0 Then Exit Function End If hService = OpenService(hSCM, strName, SERVICE_ALL_ACCESS) If hService <> 0 Then ret = StartService(hService, 0, 0) If ret <> 0 Then Start = True End If End If CloseServiceHandle hSCM CloseServiceHandle hService End Function Public Function Uninstall(strName As String) As Boolean Dim hService As Long, hSCM As Long, ret As Long Uninstall = False hSCM = OpenSCManager(vbNullString, vbNullString, SC_MANAGER_ALL_ACCESS) If hSCM = 0 Then Exit Function End If hService = OpenService(hSCM, strName, SERVICE_ALL_ACCESS) If hService <> 0 Then ret = DeleteService(hService) If ret <> 0 Then Uninstall = True End If CloseServiceHandle hSCM CloseServiceHandle hService End Function Public Function Install(strName As String, strFile As String, Optional bBoot As Boolean = False) As Boolean Dim hService As Long, hSCM As Long, ret As Long Install = False hSCM = OpenSCManager(vbNullString, vbNullString, SC_MANAGER_CREATE_SERVICE) If hSCM = 0 Then Debug.Print "INSTALL", "hSCM = 0" Exit Function End If Dim lFlag As Long If bBoot Then lFlag = SERVICE_BOOT_START Else lFlag = SERVICE_DEMAND_START End If If Not Left(strFile, 1) = Chr(34) Then strFile = Chr(34) & strFile & Chr(34) hService = CreateService(hSCM, strName, strName, SERVICE_ALL_ACCESS, SERVICE_KERNEL_DRIVER, lFlag, SERVICE_ERROR_NORMAL, strFile, 0, 0, vbNullString, strName, 0) If hService <> 0 Then Install = True Else Sleep 100 DoEvents ret = GetLastError If ret <> 0 Then Dim strText As String Select Case ret Case ERROR_ACCESS_DENIED: strText = "The handle to the specified service control manager database does not have SC_MANAGER_CREATE_SERVICE access." Case ERROR_CIRCULAR_DEPENDENCY: strText = "A circular service dependency was specified." Case ERROR_DUP_NAME: strText = "The display name already exists in the service control manager database either as a service name or as another display name." Case ERROR_INVALID_HANDLE: strText = "The handle to the specified service control manager database is invalid." Case ERROR_INVALID_NAME: strText = "The specified service name is invalid." Case ERROR_INVALID_PARAMETER: strText = "A parameter that was specified is invalid." Case ERROR_INVALID_SERVICE_ACCOUNT: strText = "The user account name specified in the lpServiceStartName parameter does not exist." Case ERROR_SERVICE_EXISTS: strText = "The specified service already exists in this database." End Select Err.Raise ret, "INSTALL", strText End If End If CloseServiceHandle hSCM CloseServiceHandle hService End Function Public Function Pause(strName As String) As Boolean Dim hService As Long, hSCM As Long, ret As Long, SS As SERVICE_STATUS Pause = False hSCM = OpenSCManager(vbNullString, vbNullString, SC_MANAGER_ALL_ACCESS) If hSCM = 0 Then Exit Function End If hService = OpenService(hSCM, strName, SERVICE_ALL_ACCESS) If hService <> 0 Then ret = ControlService(hService, SERVICE_CONTROL_STOP, SS) If ret <> 0 Then Pause = True End If End If CloseServiceHandle hSCM CloseServiceHandle hService End Function Lenke til kommentar
MadGonzo Skrevet 5. juni 2006 Del Skrevet 5. juni 2006 um det var da veldig så mye unødvendig kode du hadde der det er ikke så lurt å ta det første du finner på nettet let etter noe enklere jeg har en modul jeg bruker (har laget) selv men jeg trokke den hjelper deg så veldig koden du har er jo oversiktlig og grei, og veldig overkill har sett igjennom koden og... det er ingen kode der for å lage en windows service klient det du har er kode for å lage, starte, stoppe ntservices.. Lenke til kommentar
Richard87 Skrevet 5. juni 2006 Forfatter Del Skrevet 5. juni 2006 Det er ikke kode for og gjore om mitt programm til en service, men for og innstalere en service(.sys fil, drivere etc), med funksjone til og innstalere, uinstalere, start og stop btw, har skrevet alt selv, og ikke bare kopiert fra nettet... Btw, den modulen din, hvordan funker den? Lenke til kommentar
MadGonzo Skrevet 5. juni 2006 Del Skrevet 5. juni 2006 den sier fra at en service er startet / stoppet dvs gjør prosessen om til en ntservice jeg kan ikke sjekke koden din for feil, jeg kan ikke ntservice api'et hvem kan vel det... uansett, bruk Install "servicename", "filepath", (boolean) autorun men det visste du vel allerede.. en ting... jeg veit ikke om du bare kan sette den som SERVICE_KERNEL_DRIVER mulig windows freaker ut pga manglende privileges hvem vet Lenke til kommentar
Richard87 Skrevet 5. juni 2006 Forfatter Del Skrevet 5. juni 2006 OK, jeg vett at det er Install funksjonen som innstalerer servicen, det er jeg som har skrevet funksjonen, problemet er at CreateService returnerer 'Invalid SCM Handle'... noen som har en ide? Lenke til kommentar
