Counter, endre hvor i script?
Hei. Jeg er overhodet ingen reser i javascript. derfor dro jeg ut på jakt etter en ferdiglaget counter :blush:
jeg fant en på denne siden: http://andrewu.co.uk/clj/countdown/#howto_multiplecounters
(poster scriptet her inne, så dere slipper laste det ned osv)
Mitt spørsmål er: hva kan jeg endre slik at kun dager og event timer skrives ut, og ikke sekundene?
script:
// Andrew Urquhart : CountDown Timer : http://andrewu.co.uk/clj/countdown/
function CD_T(id,e) {
var n=new Date();
CD_D(+n,id,e);
setTimeout("CD_T('"+id+"',"+e+")",1100-n.getMilliseconds())
function CD_D(n,id,e) {
var ms=e-n;if(ms<=0) ms*=-1;
var d=Math.floor(ms/864E5);ms-=d*864E5;
var h=Math.floor(ms/36E5);ms-=h*36E5;
var m=Math.floor(ms/6E4);ms-=m*6E4;
var s=Math.floor(ms/1E3);
CD_OBJS[id].innerHTML=d+" day"+(d==1?" ":"s ")+CD_ZP(h)+"h "+CD_ZP(m)+"m "+CD_ZP(s)+"s"
function CD_ZP(i) {
return(i<10?"0"+i:i)
function CD_Init() {
var pref="countdown";
var objH=1;if(document.getElementById||document.all) {
 for(var i=1;objH;++i) {
 	var id=pref+i;objH=document.getElementById?document.getElementById(id):document.all[id];
 	if(objH&&(typeof objH.innerHTML)!='undefined') {
   var s=objH.innerHTML;
   var dt=CD_Parse(s);
   if(!isNaN(dt)){
   	CD_OBJS[id]=objH;
   	CD_T(id,dt.valueOf());
   	if(objH.style) {objH.style.visibility="visible"}
   } else {
   objH.innerHTML=s+"<a href=\"http://andrewu.co.uk/clj/countdown/\" title=\"Countdown Error:Invalid date format used,check documentation (see link)\">*</a>"
function CD_Parse(strDate) {
var objReDte=/(\d{4})\-(\d{1,2})\-(\d{1,2})\s+(\d{1,2}):(\d{1,2}):(\d{0,2})\s+GMT([+\-])(\d{1,2}):?(\d{1,2})?/;
if(strDate.match(objReDte)) {
 var d=new Date(0);
 d.setUTCFullYear(+RegExp.$1,+RegExp.$2-1,+RegExp.$3);
 d.setUTCHours(+RegExp.$4,+RegExp.$5,+RegExp.$6);
 var tzs=(RegExp.$7=="-"?-1:1);
 var tzh=+RegExp.$8;
 var tzm=+RegExp.$9;
 if(tzh) {d.setUTCHours(d.getUTCHours()-tzh*tzs)}
 if(tzm){d.setUTCMinutes(d.getUTCMinutes()-tzm*tzs)};
 return d
} else {return NaN}
var CD_OBJS=new Object();
if(window.attachEvent) {
window.attachEvent('onload',CD_Init)
} else if(window.addEventListener) {
window.addEventListener("load",CD_Init,false)
} else {
window.onload=CD_Init
fetcher med denne:
In <span id="countdown7">2006-6-12 00:00:00 GMT+00:00</span>
Du trenger bare å endre denne linjen:
Den bygger strengen som vises ved å kjede sammen dager, timer, minutter og sekunder. Det du må gjøre er å fjerne de delene du ikke ønsker. For å bare få dager og timer blir linjen som følger:
For å bare vise dager blir linjen slik:
Endret av gnab
  • 1 måned senere...
