Lang oppstartstid i XP.
Jeg har, synes hvertfall jeg, lang oppstartstid i XP. Jeg tok faktisk tiden på tingene:
POST: ca 25 sek
XP loading bar: ca 1.05 (1min, 5 sek), telte også antall ganger den blå loading baren gikk fra venstre til høyre: 32 ganger.
Tiden inn til XP desktop etter XP loading bar virket normal: ca 5 sek.
Jeg har vært inne på en del guider/poster her i forumet, men ser ikke ut til å hjelpe:
Hvordan få raskere oppstart i Windows
Tok også en Bootlog. Jeg har ikke peiling så jeg lar dere eksperter se om det er noe underlig:
Service Pack 2 5 21 2006 15:39:42.500
Loaded driver \WINDOWS\system32\ntkrnlpa.exe
Loaded driver \WINDOWS\system32\hal.dll
Loaded driver \WINDOWS\system32\KDCOM.DLL
Loaded driver \WINDOWS\system32\BOOTVID.dll
Loaded driver sptd.sys
Loaded driver \WINDOWS\System32\Drivers\WMILIB.SYS
Loaded driver \WINDOWS\System32\Drivers\SPTD3133.SYS
Loaded driver ACPI.sys
Loaded driver pci.sys
Loaded driver isapnp.sys
Loaded driver pciide.sys
Loaded driver \WINDOWS\System32\DRIVERS\PCIIDEX.SYS
Loaded driver MountMgr.sys
Loaded driver ftdisk.sys
Loaded driver PartMgr.sys
Loaded driver VolSnap.sys
Loaded driver atapi.sys
Loaded driver disk.sys
Loaded driver \WINDOWS\System32\DRIVERS\CLASSPNP.SYS
Loaded driver fltmgr.sys
Loaded driver sr.sys
Loaded driver PxHelp20.sys
Loaded driver KSecDD.sys
Loaded driver Ntfs.sys
Loaded driver NDIS.sys
Loaded driver nv_agp.sys
Loaded driver Mup.sys
Loaded driver \SystemRoot\System32\DRIVERS\processr.sys
Loaded driver \SystemRoot\System32\DRIVERS\usbohci.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbehci.sys
Loaded driver \SystemRoot\system32\DRIVERS\nvnetbus.sys
Loaded driver \SystemRoot\system32\drivers\ALCXWDM.SYS
Loaded driver \SystemRoot\system32\DRIVERS\imapi.sys
Loaded driver \SystemRoot\System32\DRIVERS\cdrom.sys
Loaded driver \SystemRoot\System32\DRIVERS\redbook.sys
Loaded driver \SystemRoot\System32\DRIVERS\Pcatip.sys
Loaded driver \SystemRoot\System32\Drivers\GEARAspiWDM.sys
Loaded driver \SystemRoot\system32\DRIVERS\nv4_mini.sys
Loaded driver \SystemRoot\System32\DRIVERS\RT2500.sys
Loaded driver \SystemRoot\System32\Drivers\dtscsi.sys
Loaded driver \SystemRoot\System32\DRIVERS\fdc.sys
Loaded driver \SystemRoot\System32\DRIVERS\serial.sys
Loaded driver \SystemRoot\System32\DRIVERS\serenum.sys
Loaded driver \SystemRoot\System32\DRIVERS\parport.sys
Loaded driver \SystemRoot\System32\DRIVERS\gameenum.sys
Loaded driver \SystemRoot\system32\drivers\msmpu401.sys
Loaded driver \SystemRoot\System32\DRIVERS\audstub.sys
Loaded driver \SystemRoot\System32\DRIVERS\rasl2tp.sys
Loaded driver \SystemRoot\System32\DRIVERS\ndistapi.sys
Loaded driver \SystemRoot\System32\DRIVERS\ndiswan.sys
Loaded driver \SystemRoot\System32\DRIVERS\raspppoe.sys
Loaded driver \SystemRoot\System32\DRIVERS\raspptp.sys
Loaded driver \SystemRoot\System32\DRIVERS\msgpc.sys
Loaded driver \SystemRoot\System32\DRIVERS\psched.sys
Loaded driver \SystemRoot\System32\DRIVERS\ptilink.sys
Loaded driver \SystemRoot\System32\DRIVERS\raspti.sys
Loaded driver \SystemRoot\System32\Drivers\Pcouffin.sys
Loaded driver \SystemRoot\System32\DRIVERS\termdd.sys
Loaded driver \SystemRoot\System32\DRIVERS\kbdclass.sys
Loaded driver \SystemRoot\System32\DRIVERS\mouclass.sys
Loaded driver \SystemRoot\System32\DRIVERS\swenum.sys
Loaded driver \SystemRoot\System32\DRIVERS\update.sys
Loaded driver \SystemRoot\System32\DRIVERS\mssmbios.sys
Loaded driver \SystemRoot\System32\DRIVERS\usbhub.sys
Loaded driver \SystemRoot\System32\Drivers\NDProxy.SYS
Did not load driver \SystemRoot\System32\Drivers\NDProxy.SYS
Loaded driver \SystemRoot\System32\DRIVERS\flpydisk.sys
Loaded driver \SystemRoot\System32\Drivers\VETFDDNT.SYS
Did not load driver \SystemRoot\System32\Drivers\lbrtfdc.SYS
Did not load driver \SystemRoot\System32\Drivers\Sfloppy.SYS
Did not load driver \SystemRoot\System32\Drivers\i2omgmt.SYS
Did not load driver \SystemRoot\System32\Drivers\Changer.SYS
Did not load driver \SystemRoot\System32\Drivers\Cdaudio.SYS
Loaded driver \SystemRoot\System32\Drivers\Fs_Rec.SYS
Loaded driver \SystemRoot\System32\Drivers\VET-REC.SYS
Loaded driver \SystemRoot\System32\Drivers\VET-FILT.SYS
Did not load driver \SystemRoot\System32\Drivers\VET-FILT.SYS
Loaded driver \SystemRoot\System32\Drivers\VETMONNT.SYS
Loaded driver \SystemRoot\System32\Drivers\Null.SYS
Loaded driver \SystemRoot\System32\Drivers\Beep.SYS
Did not load driver \SystemRoot\System32\DRIVERS\i8042prt.sys
Did not load driver \SystemRoot\system32\DRIVERS\kbdhid.sys
Loaded driver \SystemRoot\System32\drivers\vga.sys
Loaded driver \SystemRoot\System32\Drivers\mnmdd.SYS
Loaded driver \SystemRoot\System32\DRIVERS\RDPCDD.sys
Loaded driver \SystemRoot\System32\Drivers\Msfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Npfs.SYS
Loaded driver \SystemRoot\System32\DRIVERS\rasacd.sys
Loaded driver \SystemRoot\System32\DRIVERS\ipsec.sys
Loaded driver \SystemRoot\System32\DRIVERS\tcpip.sys
Loaded driver \SystemRoot\System32\DRIVERS\netbt.sys
Loaded driver \SystemRoot\System32\vsdatant.sys
Loaded driver \SystemRoot\System32\drivers\ws2ifsl.sys
Loaded driver \SystemRoot\System32\drivers\afd.sys
Loaded driver \SystemRoot\System32\DRIVERS\netbios.sys
Did not load driver \SystemRoot\System32\Drivers\PCIDump.SYS
Loaded driver \SystemRoot\System32\DRIVERS\rdbss.sys
Loaded driver \SystemRoot\System32\Drivers\PQNTDrv.SYS
Loaded driver \SystemRoot\System32\DRIVERS\mrxsmb.sys
Loaded driver \SystemRoot\System32\Drivers\Fips.SYS
Loaded driver \SystemRoot\System32\DRIVERS\ipnat.sys
Loaded driver \SystemRoot\System32\DRIVERS\wanarp.sys
Loaded driver \SystemRoot\system32\DRIVERS\P0630Vid.sys
Loaded driver \SystemRoot\system32\DRIVERS\usbccgp.sys
Loaded driver \SystemRoot\System32\Drivers\Cdfs.SYS
Loaded driver \SystemRoot\System32\Drivers\Udfs.SYS
Loaded driver \SystemRoot\system32\DRIVERS\hidusb.sys
Loaded driver \SystemRoot\system32\DRIVERS\OmniUsbl.sys
Loaded driver \SystemRoot\system32\DRIVERS\kbdhid.sys
Loaded driver \SystemRoot\system32\DRIVERS\OmniUsb.sys
Loaded driver \SystemRoot\System32\Drivers\Razerlow.sys
Loaded driver \SystemRoot\System32\DRIVERS\mouhid.sys
Did not load driver \SystemRoot\System32\DRIVERS\rdbss.sys
Did not load driver \SystemRoot\System32\DRIVERS\mrxsmb.sys
Loaded driver \SystemRoot\System32\DRIVERS\mrxdav.sys
Loaded driver \SystemRoot\System32\Drivers\ParVdm.SYS
Loaded driver \SystemRoot\System32\DRIVERS\secdrv.sys
Loaded driver \SystemRoot\System32\DRIVERS\srv.sys
Did not load driver \SystemRoot\System32\DRIVERS\ipnat.sys
Loaded driver \SystemRoot\system32\drivers\wdmaud.sys
Loaded driver \SystemRoot\system32\drivers\sysaudio.sys
Loaded driver \SystemRoot\system32\drivers\splitter.sys
Loaded driver \SystemRoot\system32\drivers\aec.sys
Loaded driver \SystemRoot\system32\drivers\swmidi.sys
Loaded driver \SystemRoot\system32\drivers\DMusic.sys
Loaded driver \SystemRoot\system32\drivers\kmixer.sys
Loaded driver \SystemRoot\system32\drivers\drmkaud.sys
Loaded driver \SystemRoot\System32\Drivers\HTTP.sys
Dette kan jo skyldes alt mulig rart - virus, hardware-innstillinger, overklokking etc.
Si litt mer om maskinen og hvor lenge det har vært sånn og hva du har i den og hvilke programmer som kjører ved oppstart...
6153318[/snapback]
Har ikke virus. Det er jeg ganske sikker på.
Jeg har HK: Epox EP-8KDA3J, CPU: AMD Athlon 64, 2100 (overklokket 100 Mhz), RAM: 2048 Mb PC3200 DDR SDRAM, GFX: GeForce 6800 LE, HD 1: Seagate Barracuda 3.5" IDE 160 Gb, HD 2: Samsung SpinPoint 3.5" SATA 250Gb.
Det er 9 program som kjøres ved oppstart:
Program - File
NvCplDeamon - RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStarup
nwiz - nwiz.exe /install
NvMediaCenter - RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
SoundMan - SOUNDMAN.EXE
SpybotSnD - "D:\Programs\Spybot - Search & Destroy\SpybotSD.exe" /autoclose
Zone Labs Client - D:\Programs\ZoneAlarm\zlclient.exe
AWMON - "D:\programs\AD-AWA~1\Ad-Watch.exe
razer - C:\Program Files\Razer\razerhid.exe
Microsoft Office.lnk - C:\Program Files\Microsoft Office\Office10\OSA.EXE
Men så vidt jeg kan se, så starter disse programmene når Desktopen dukker opp.
Jeg hadde dette problemet selv. Avinnstallerte Nvidia harddiskdriverne, og problem løst.
6153346[/snapback]
Står de på BOOTLOG listen? Og hvordan fjerner man de?
Edit:
Var inne på Add and Remove Programs og sjekket NVIDIA Drivers. Der kunne jeg velge mellom 4 forskjellige nVidia drivere:
Display Driver
Ethernet Driver
GART Driver
nForce PCI System Managment Driver
Endret av Frico855
32 ganger den xp baren er der driverne loades. Så det skyldes nok drivere. Post er det nok lite å få gjort med, med mindre en ny firmware til bios på hovedkortet kommer og retter dette.
6153389[/snapback]
POST har jeg fått ned til ca 7 sek. Var inne på BIOS og slo av PC Health status og andre små ting som ikke var nødvendig.
Har du hode til det, kan du sjekke ut ServiWin
http://www.nirsoft.net/utils/serviwin.html
Her får du listen over alle drivere (+ services) som systemet kjenner til, hvilke som er satt til å starte etc. Sorterer du etter navn eller produsent, kan du kanskje finne ut om det er noe gamalt slagg som skal vekk.
Et annet tips er å foreta følgende i regedit:
[start] [Run] [Regedit]
Registry Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\Environment
Data Type: REG_SZ [string Value] // Value Name: DEVMGR_SHOW_NONPRESENT_DEVICES
Modify/Create the Value Name [DEVMGR_SHOW_NONPRESENT_DEVICES] according to the Value Data listed below.
Value Data: [1 = Show Devices / 0 = Hide Devices]
Exit Registry and Reboot
( fra http://www.theeldergeek.com/show_hidden_de...ice_manager.htm )
Går du så inn i enhetsbehandling og velger Vis/Skjulte enheter, vil du nedover listen se all hardware som er - og har vært - tilkoblet. De som ikke lenger er tilkoblet (ses som "grået ut") kan du, hvis du er sikker, høyreklikke og avinstallere.
Endret av zjulik
Testet ServiWin, og fant noen drivere som jeg kunne stoppe. Men så lurer jeg på hvor mange drivere som er "normalt" å ha. Hos meg så står det 195 drivere.
Tok denne også. Fant en hel del "grået ut" installasjoner. Tok vekk meste parten, men fremdeles ingen forskjell på XP loading bar.
Hvis den har vært på et LAN men ikke er det lenger - hva slags LAN? Trådløst? En annen her inne slettet en gammel nettverkstilkobling og vips var ting raskere.
Det kan høres ut som om maskinen tror den er på LAN ennå og bruker tid på å se etter de andre maskinene.
6160531[/snapback]
Trådløst LAN. Men kan ikke finne noe gammelt nettverkstilkobling. Det er like før jeg gir opp og lar XP bruke litt lang til på å starte... *sukk*
Nå skal alle dere vanlige dødelige høre etter her:
M$ har laget et veldig ukjent, men kult og funksjonelt lite programm som de så pent kaller "Bootvis". Sjekk ut dette:
BootVis is a performance trace visualization tool for use with Windows XP systems. Customer research shows a frequently requested feature that users want from their PCs is fast system startup, whether from cold boot or when resuming from standby or hibernation.
The Windows development team at Microsoft has taken bold steps in making fast startup PCs a reality with the Microsoft Windows XP operating system.
Kult, ikke sant? Så nå lurer dere vanlige dødelige sikkert på hvor dere skaffer dette hellige programmet? Google er en bra plass å starte, men siden jeg fremdeles føler meg i det hjelpsomme hjørnet skal jeg mane frem en link som dere vanlige dødelige kan bruke for å få tilgang til denne godbiten! *huggabuggah*
*poof*
Den hellige link. :innocent:
6160531[/snapback]
6163610[/snapback]
Det var da en tråd om nøyaktig samme problemet forikke så lenge siden. Vært på LAN, trådløst, kom hjem, maskinen langsom til å starte.... se om ikke vi finner den tråden...
*poof*
6165822[/snapback]
Prøvde dette før jeg postet. BootVis viste meg absolutt ingenting. Ingen grafer dukket opp. Så vidt jeg vet er det bare å kjøre programmet og ta 'Trace/Next Boot + Driver Delays'...?
Prøver igjen nå.
EDIT:
Prøvde 2 ganger. Ingen grafer dukker opp. Alle er blank.
Endret av Frico855
Til Frico855:
I Bootvis, under menyen "Trace" finner du en magisk knapp som heter "Optimize System". Knappen snakker vel litt for seg selv, vil jeg anta. Trykker du på denne knappen popper det opp en boks som forteller deg det mest vanlige i Windows, nettopp at du er nødt til å restarte system for at ting skal få skje i ro og mak. Så da er det bare å trykke denna knappen, hente litt popcorn, og vente på at PCn starter opp som et nytt og bedre digitalt rot.
Men en ting som jeg må gjøre helt klart: Når maskinen har starta opp etter en omgang Bootvis, tar det inntil 10 minutter for Bootvis å kartlegge og optimalisere systemet ditt. Du *vil* få beskjed når det er gjort, så du får nyte popcornet mest du venter.
Endret av StianGH
Til Frico855:
6167558[/snapback]
Etter å ha startet BootVis, valgt Optimize System og for så å vente på at det skulle dukke opp noe beskjed... Noe som ikke skjedde. Når jeg skriver dette har jeg ventet i ca 30 min. Med mindre beskjeden lukket seg automatisk...
Vet ikke om dette gjelder for deg, men en del avanserte brukere har deaktivert et par Services som BootVis trenger. Disse to må stå på Automatic for at det skal virke:
Com+ Event System
Task Scheduler
Stilles inn i Kontrollpanel / Administrative verktøy / Tjenester.
