http://swchat.nostdal.org:6123/swchat/main.html
kildekode:
Skjult tekst: (Marker innholdet i feltet for å se teksten):
;;;; http://nostdal.org/SWChat/ ;;;;
(defpackage SWChat
  (:use :cl :SymbolicWeb :AmUtil))
(in-package :SWChat)
(defparameter *max-length* 100000)
(defclass SWChat (Application)
  ((username :accessor username-of
            :initform (concatenate 'string "anonymous-" (SW::generateID)))
  (messages :accessor messages-of :allocation :class
            :initform "")
  (participants :accessor participants-of :allocation :class
                :initform (make-instance 'AppGroup)))
  (:default-initargs
  :name "SWChat"
  :static-path "/home/lars/programming/lisp/swchat/static/"))
(export 'SWChat)
(defmethod initialize-instance :after ((app SWChat) &key)
  ;; TODO: Some way the instances get removed from the group.
  (add app (participants-of app))
  ;; Set up handlers.
  (setf (handler-of app "say") 'say)
  (setf (handler-of app "redraw") 'redraw))
(defmethod scrollView ((app Ajax))
  "Scroll view so one sees the last message arrived."
  (evalJS app "getElt('messages').scrollTop = getElt('messages').scrollHeight;"))
(defmethod redraw ((app SWChat))
  (setElement app "messages" (messages-of app))
  (setValue app "nick" (mkstr "anonymous-" (SW::generateID)))
  (scrollView app))
(defmethod say ((app SWChat) (message string) (nick string))
  (setf message (mkstr "<br/>" nick ": " (AmWeb:escapeHTML (AmWeb:urlDecode message))))
  ;; Update server side..
  (setf (messages-of app)
        (concatenate 'string (messages-of app) message))
  ;; ..but make sure it doesn't store too much.
  (when (> (- (length (messages-of app)) *max-length*) 0)
          (subseq (messages-of app)
                  (length (messages-of app)))))
  ;; Send message to `app' (the one who sent the message originally).
  (appendToElement app "messages" message)
  (scrollView app)
  ;; Send message to every other client.
  (appendToElement (participants-of app) "messages" message)
  (scrollView (participants-of app))
  (dispatch (participants-of app) app))
edit:
oh, jeg har kun bekreftet at denne fungerer under Firefox og Opera (noen småbugs i Opera fortsatt, men ok) .. en på IRC nevnte at den fungerte under Safari og Konqueror også
om noen er interesserte i et samarbeid m.t.p. design eller lignende er det bare å ta kontakt :) (jeg har et par andre eksempler liggende også ..)
Endret av dayslepr
hm, det er ikke noen som har litt greie på AJAX/JavaScript i Opera her?
denne applikasjonen http://nostdal.org:6123/hello-world/hello-world.html skal oppdatere tallet ved siden av "The time is: " hvert sekund, men under Opera så skjer ikke dette
  debugMsg("debug", "server-initiated: about to send new request");
 window.xhr_si.onreadystatechange = siHandler;
 window.xhr_si.open("POST", "?type=server-initiated", true);
 window.xhr_si.setRequestHeader('Content-Type',
                                'application/x-www-form-urlencoded; charset=UTF-8');
 window.xhr_si.setRequestHeader('User-Agent', navigator.userAgent);
 window.xhr_si.send("");
 debugMsg("debug", "server-initiated: new request sent");
siHandler, readyState: 1
siHandler, readyState: 4
siHandler, readyState: 3
updateElements, response_text: '[["setElement","time",3357397454],["setElement","session-id","4677"]]'
sndReq: '[["redraw"]]'
queueReq: '[["redraw"]]'
siste debug-melding er øverst .. det som er snedig, er at etter jeg har kallt abort og skal resende http-requesten (ajax dette) så sender den ikke, den blokker og siste melding blir da "about to send new request" - altså den blir aldri sendt .. har noen peil på dette? IE og FF fungerer som de skal
edit: rop om mer info trengs!
Endret av dayslepr
