To små spørsmål kom masjerende...
Error Line 59 column 73: there is no attribute "TARGET".
.../kibneb.no/gallery/index.php?list=1" target="_blank">Galleri
You have used the attribute named above in your document, but the document type you are using does not support that attribute for this element. This error is often caused by incorrect use of the "Strict" document type with a document that uses frames (e.g. you must use the "Transitional" document type to get the "target" attribute), or by using vendor proprietary extensions such as "marginheight" (this is usually fixed by using CSS to achieve the desired effect instead).
This error may also result if the element itself is not supported in the document type you are using, as an undefined element will have no supported attributes; in this case, see the element-undefined error message for further information.
How to fix: check the spelling and case of the element and attribute, (Remember XHTML is all lower-case) and/or check that they are both allowed in the chosen document type, and/or use CSS instead of this attribute.
Hva skal jeg bruke da??
EDIT: enda en ting som jeg lurer på... Den siden likte ikke at jeg skrev border="0" Det gjorde jeg fordi bildene var linker og dermed fikk en stygg border rundt seg. Bed Border="0" fikk jeg da fjernet den linken, men det likte da altså ikke validator...
