problemer med codeblocks, diverse feilmeldinger
hei
jeg har problemer med programmet codeblocks, får diverse feilmeldinger når jeg skal komplimere koden min, som det ikke er noe feil med, får komplimert i devcpp...
de er skjult nedenfor...
folka på #scene.no sa jeg ikke burde bruke dev-cpp, men codeblocks, er dere enige med dette
Skjult tekst: (Marker innholdet i feltet for å se teksten):
Project : Project1
Compiler : GNU GCC Compiler (called directly)
Directory : C:\Programfiler\CodeBlocks\Projekts\Copy of glut_base\
Switching to target: default
Compiling: main.cpp
Linking executable: C:\Programfiler\CodeBlocks\Projekts\Copy of glut_base\Project1.exe
.objs\main.o:main.cpp:(.text+0x3f3): undefined reference to `glutSwapBuffers'
.objs\main.o:main.cpp:(.text+0x401): undefined reference to `glutPostRedisplay'
.objs\main.o:main.cpp:(.text+0x564): undefined reference to `glutInit'
.objs\main.o:main.cpp:(.text+0x570): undefined reference to `glutInitDisplayMode'
.objs\main.o:main.cpp:(.text+0x584): undefined reference to `glutInitWindowSize'
.objs\main.o:main.cpp:(.text+0x590): undefined reference to `glutCreateWindow'
.objs\main.o:main.cpp:(.text+0x59c): undefined reference to `glutDisplayFunc'
.objs\main.o:main.cpp:(.text+0x5a8): undefined reference to `glutIdleFunc'
.objs\main.o:main.cpp:(.text+0x5b4): undefined reference to `glutKeyboardFunc'
.objs\main.o:main.cpp:(.text+0x5c0): undefined reference to `glutReshapeFunc'
.objs\main.o:main.cpp:(.text+0x5ca): undefined reference to `glutMainLoop'
collect2: ld returned 1 exit status
Process terminated with status 1 (0 minutes, 1 seconds)
her er koden min...
#include <GL/glut.h>
#include <cstdlib>
#include <iostream>
#include <windows.h>
using namespace std;
float posx = 0.0f;
float posy = 0.0f;
float xspeed = 0.00012f;
float yspeed = 0.00005f;
long delay = GetTickCount() + 1000;
long fps;
void init()
// generell initialisering
glClearColor(1.0, 0.0, 0.0, 1.0); // Setter hvilken farge gl skal fylle skjermen med når den 'blanker' bufferen
//glEnable(GL_DEPTH_TEST);
void render()
glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); // Blanker ut buffere
glPushMatrix(); // 'Lagrer' tidligere matrise
posx += xspeed; // Endrer posisjonen til objektet, X
posy += yspeed; // Endrer posisjoin til objektet, Y
if (posx > 0.5f)
xspeed = xspeed - xspeed - xspeed;
if (posx < -0.5f)
if (posy > -0.5f)
yspeed = yspeed - yspeed - yspeed;
if (posy < 0.5f)
glTranslatef(posx, posy, 0.0);
// Her skal man tegne det som skal tegnes
glColor3f(1.0, 0.0, 1.0);
// glBegin() tar følgende verdier'.
GL_POINTS
GL_LINES
GL_LINE_STRIP
GL_LINE_LOOP
GL_TRIANGLES
GL_TRIANGLE_STRIP
GL_TRIANGLE_FAN
GL_QUADS
glBegin(GL_TRIANGLE_STRIP);
glVertex3f(-0.5f, -0.5f, 0.0f);// bredde, høyde, dybde
glVertex3f(0.5f, -0.5f , 0.0f);
glVertex3f(-0.5f , 0.5f , 0.0f);
glVertex3f(0.5f , 0.5f, 0.0f);
/* glBegin(GL_TRIANGLES);
glVertex3f(0.0, 0.5, 0.0);// bredde, høyde, dybde
glVertex3f(0.0, -0.5, 0.0);
glVertex3f(-0.5, 0.5, 0.0);
glEnd();
glPopMatrix(); // Gjenoppretter tidligere matrise
glutSwapBuffers(); // Bytter om front bufferen med backbufferen
void idle()
glutPostRedisplay(); // kjør render metoden en gang til
void key(unsigned char key, int x, int y)
// Keypress func
switch (key)
case 'd':
posx += 0.01;
break;
case 'w':
posy += 0.01;
break;
case 's':
posy -= 0.01;
break;
case 'a':
posx -= 0.01;
break;
case '+':
if (posx < +0.5f)
xspeed += 0.001 ;
break;
case 'l':
cout << "test";
break;
if (posx > 0.499f)
yspeed += 0.001;
break;
/*case '-':
if (posy > -0.5)
yspeed += yspeed;
break;
if (posy > 0.5)
break;*/
//yspeed += 0.00001;
//xspeed += 0.00001;
break;
case '-':
xspeed -= 0.00001;
yspeed -= 0.00001;
break;
void resize(int w, int h)
if (h == 0)
h = 1;
float ratio = (1.0f * w) / h; // Regner ut forholdet mellom bredde og høyde
glViewport(0, 0, w, h); // Setter 'cliping' på vinduet
glMatrixMode(GL_PROJECTION); // Velger hvilken matrise du vil mqnipulere (projeksjons matrise)
glLoadIdentity(); // Nullstiller gjeldene matrise
//3D
//gluPerspective(45, ratio, 1.0, 100.0); // Setter opp projeksjon
glOrtho(-1, 1, -1, 1, 1, 100);
glMatrixMode(GL_MODELVIEW); // Velger matrise (model/view)
glLoadIdentity();
// Setter kamera posisjon, 'mål' og opp vektor
gluLookAt(0.0, 0.0, 2.0 // Posisjon
, 0.0, 0.0, 0.0 // 'Mål'
, 0.0, 1.0, 0.0); // Opp vektor
int main(int argc, char **argv)
glutInit(&argc, argv); // Initialiserer glut
glutInitDisplayMode(GLUT_RGBA | GLUT_DOUBLE | GLUT_DEPTH); // Setter display mode til 32bit og dobbel buffer (front og back)
glutInitWindowSize(800, 600); // Setter oppløsning på vinduet
glutCreateWindow("Hello World!"); // Lager vinduet
glutDisplayFunc(render); // Setter render metode
glutIdleFunc(idle); // Idle metode
glutKeyboardFunc(key); // Standard keyboard metode
glutReshapeFunc(resize); // Resize metode
init(); // init
glutMainLoop(); // MainLoop
return 0;
hva burde jeg gjøre for å bli kvitt problemene med å overføre kode fra dev-cpp til codeblocks??
og hvordan fikser jeg det??
får forresten samme feil i både dev-cpp og codeblocks nå...
men i dev-cpp får jeg komplimert så lenge jeg ikke endrer noe, hvis jeg endrer noe får jeg jeg den samme feilen
