VB.NET - Slette IE history?
Eksempelvis med følgende prosedyre:
    Public Sub DeleteFolder(ByVal FolderPath As String)
        Dim sFile As String
        ' Go through all files within this folder
        For Each sFile In System.IO.Directory.GetFiles(FolderPath)
            ' Delete the given file
            System.IO.File.Delete(sFile)
        Next
        ' Then go through all the subfolders
        For Each sFile In System.IO.Directory.GetDirectories(FolderPath)
            ' Kill all subfolders and files within
            DeleteFolder(sFile)
        Next
        ' Finally, kill the folder itself
        System.IO.Directory.Delete(FolderPath)
    End Sub
For å slette mappen du nevnte, kaller du bare prosedyren slik:
DeleteFolder("C:\Documents and Settings\USER\Local Settings\History\")
Si ifra om det fungerte eller ikke da. En liten tilbakemelding og et takk skader ikke. :)
Du må legge prosedyren innenfor den aktuelle klassen (dvs. under Public Class <-Din modul->, samt ovenfor linjen End Class. Ennvidere må prosedyren ikke legges innenfor en annen prosedyre. Det letteste er nok bare å lime inn prosdyren rett under Public Class-linjen (marker slutten av den linjen, trykk ENTER og lim inn koden).
Endret av aadnk
6110014[/snapback]
"End of statement expected"... hva skal jeg putte inn?
Eh, rett under, ikke ved siden av. Såsom dette:
Skjult tekst: (Marker innholdet i feltet for å se teksten):
Public Class Form1
        Dim sFile As String
        Next
            DeleteFolder(sFile)
        Next
    End Sub
End Class
Da får jeg endeløse feilmeldinger..
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(256): '#End Region' must be preceded by a matching '#Region'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(16): '#Region' and '#End Region' statements are not valid within method bodies.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(242): 'AutoScaleBaseSize' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(243): 'ClientSize' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(246): 'Controls' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(247): 'Controls' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(245): 'Controls' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(244): 'Controls' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(36): 'Dispose' is not a member of 'System.Object'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(248): 'Name' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(252): 'ResumeLayout' is not a member of 'Deleterecent.Form1'.
'Sub Main' was not found in 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(83): 'SuspendLayout' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(249): 'Text' is not a member of 'Deleterecent.Form1'.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(13): Keyword is not valid as an identifier.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(294): Name 'SHAddToRecentDocs' is not declared.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(18): Statement cannot appear within a method body. End of method assumed.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(11): Statement is not valid inside a method.
C:\Documents and Settings\Edvard\My Documents\Visual Studio Projects\Deleterecent\Form1.vb(30): sub 'Dispose' cannot be declared 'Overrides' because it does not override a sub in a base class.
Hm, da bruker vi nok forskjellige kompilatorer (enten i applikasjon, versjon eller konfigurasjon). Antar du da må da sette prosedyrekoden (ikke lim inn hele koden i posten min ovenfor, kun selve subben) nedenfor #End Region.
Endret av aadnk
  • 2 uker senere...
