Goscinny Skrevet 15. mai 2006 Del Skrevet 15. mai 2006 Hei! Kan en vennlig sjel se på den vedlagte filen om den kommer til å virke? Den er endret litt i forhold til den deafulte menu.lst-filen, Det jeg ville frem til med den var å få XP øverst på listen. # menu.lst - See: grub(8), info grub, update-grub(8) # grub-install(8), grub-floppy(8), # grub-md5-crypt, /usr/share/doc/grub # and /usr/share/doc/grub-doc/. ## default num # Set the default entry to the entry number NUM. Numbering starts from 0, and # the entry number 0 is the default if the command is not used. # # You can specify 'saved' instead of a number. In this case, the default entry # is the entry saved with the command 'savedefault'. default 0 ## timeout sec # Set a timeout, in SEC seconds, before automatically booting the default entry # (normally the first entry defined). timeout 10 ## hiddenmenu # Hides the menu by default (press ESC to see the menu) #hiddenmenu # Pretty colours #color cyan/blue white/blue ## password ['--md5'] passwd # If used in the first section of a menu file, disable all interactive editing # control (menu entry editor and command-line) and entries protected by the # command 'lock' # e.g. password topsecret # password --md5 $1$gLhU0/$aW78kHK1QfV3P2b2znUoe/ # password topsecret # # examples # # title Windows 95/98/NT/2000 # root (hd0,0) # makeactive # chainloader +1 # # title Linux # root (hd0,1) # kernel /vmlinuz root=/dev/hda2 ro # # # Put static boot stanzas before and/or after AUTOMAGIC KERNEL LIST ### BEGIN AUTOMAGIC KERNELS LIST ## lines between the AUTOMAGIC KERNELS LIST markers will be modified ## by the debian update-grub script except for the default options below ## DO NOT UNCOMMENT THEM, Just edit them to your needs ## ## Start Default Options ## ## default kernel options ## default kernel options for automagic boot options ## If you want special options for specifiv kernels use kopt_x_y_z ## where x.y.z is kernel version. Minor versions can be omitted. ## e.g. kopt=root=/dev/hda1 ro # kopt=root=/dev/hda6 ro ## default grub root device ## e.g. groot=(hd0,0) # groot=(hd0,5) ## should update-grub create alternative automagic boot options ## e.g. alternative=true ## alternative=false # alternative=true ## should update-grub lock alternative automagic boot options ## e.g. lockalternative=true ## lockalternative=false # lockalternative=false ## altoption boot targets option ## multiple altoptions lines are allowed ## e.g. altoptions=(extra menu suffix) extra boot options ## altoptions=(recovery mode) single # altoptions=(recovery mode) single ## nonaltoption boot targets option ## This option controls options to pass to only the ## primary kernel menu item. ## You can have ONLY one nonaltoptions line # nonaltoptions=quiet splash ## controls how many kernels should be put into the menu.lst ## only counts the first occurence of a kernel, not the ## alternative kernel options ## e.g. howmany=all ## howmany=7 # howmany=all ## should update-grub create memtest86 boot option ## e.g. memtest86=true ## memtest86=false # memtest86=true ## ## End Default Options ## # This entry automatically added by the Debian installer for a non-linux OS # on /dev/hda1 title Microsoft Windows XP Professional root (hd0,0) savedefault makeactive chainloader +1 ### END DEBIAN AUTOMAGIC KERNELS LIST # This is a divider, added to separate the menu items below from the Debian # ones. title Other operating systems: root title Ubuntu, kernel 2.6.12-10-386 root (hd0,5) kernel /boot/vmlinuz-2.6.12-10-386 root=/dev/hda6 ro quiet splash initrd /boot/initrd.img-2.6.12-10-386 savedefault boot title Ubuntu, kernel 2.6.12-10-386 (recovery mode) root (hd0,5) kernel /boot/vmlinuz-2.6.12-10-386 root=/dev/hda6 ro single initrd /boot/initrd.img-2.6.12-10-386 boot title Ubuntu, kernel 2.6.12-9-386 root (hd0,5) kernel /boot/vmlinuz-2.6.12-9-386 root=/dev/hda6 ro quiet splash initrd /boot/initrd.img-2.6.12-9-386 savedefault boot title Ubuntu, kernel 2.6.12-9-386 (recovery mode) root (hd0,5) kernel /boot/vmlinuz-2.6.12-9-386 root=/dev/hda6 ro single initrd /boot/initrd.img-2.6.12-9-386 boot title Ubuntu, memtest86+ root (hd0,5) kernel /boot/memtest86+.bin boot Goscinny Lenke til kommentar
RattleBattle Skrevet 15. mai 2006 Del Skrevet 15. mai 2006 (endret) Ta heller det slik som det var og endre heller på "default". Bare husk at den begynner å telle valgene fra 0 og ikke 1. Endret 15. mai 2006 av RattleBattle Lenke til kommentar
Goscinny Skrevet 15. mai 2006 Forfatter Del Skrevet 15. mai 2006 Ta heller det slik som det var og endre heller på "default". Bare husk at den begynner å telle valgene fra 0 og ikke 1. 6109026[/snapback] Er _helt_ ny i dette. Er det chainloader som skal stå på 0? Kunne du tenke deg, RattleBattle, å legge det ut slik det skal være? Lenke til kommentar
RattleBattle Skrevet 15. mai 2006 Del Skrevet 15. mai 2006 Kan jeg bare få vite hva du har gjort med GRUB? Har du lagt til Windows-delen selv, eller har Ubuntu gjort det? Den har alltid vært neders hos meg, derfor jeg spør. Lenke til kommentar
LessThanJake Skrevet 15. mai 2006 Del Skrevet 15. mai 2006 (endret) Ta den helt originale filen, og finn linjen default 0 , og endre det tallet til det nummeret XP har på listen(start å telle fra null). På den måten risikerer du ikke å ødelegge noe, i verste fall starter bare feil OS og du må fikse på tallet igjen. Endret 15. mai 2006 av LessThanJake Lenke til kommentar
Goscinny Skrevet 15. mai 2006 Forfatter Del Skrevet 15. mai 2006 Ta den helt originale filen, og finn linjen default 0 , og endre det tallet til det nummeret XP har på listen(start å telle fra null). På den måten risikerer du ikke å ødelegge noe, i verste fall starter bare feil OS og du må fikse på tallet igjen. 6109616[/snapback] Ok, tusen takk. Tror jeg skal klare det. Sitter i XP nå, men skal se på det seinere. Igjen takk! Goscinny Lenke til kommentar
