jensens Skrevet 9. mai 2006 Del Skrevet 9. mai 2006 Heisann. Jeg skal prøve og mounte den ene ntfs disken min, å da får jeg følgende: gentoo ~ # mount -t ntfs -o ro,defaults,umask=0222 /dev/sda1 /mnt/hd6 mount: wrong fs type, bad option, bad superblock on /dev/sda1, missing codepage or other error In some cases useful info is found in syslog - try dmesg | tail or so Jeg vet kernelen har støtte for ntfs, grunnet har alle andre ntfs disker mounta. Å når jeg tar dmesg | tail kommer: gentoo ~ # dmesg | tail NTFS-fs error (device sdb1): ntfs_ucstonls(): Unicode name contains characters that cannot be converted to character set iso8859-1. You might want to try to use the mount option nls=utf8. NTFS-fs warning (device sdb1): ntfs_filldir(): Skipping unrepresentable inode 0x2ad. NTFS-fs warning (device sda1): is_boot_sector_ntfs(): Invalid boot sector checksum. NTFS-fs error (device sda1): read_ntfs_boot_sector(): Primary boot sector is invalid. NTFS-fs error (device sda1): read_ntfs_boot_sector(): Mount option errors=recover not used. Aborting without trying to recover. NTFS-fs error (device sda1): ntfs_fill_super(): Not an NTFS volume. NTFS-fs warning (device sda1): is_boot_sector_ntfs(): Invalid boot sector checksum. NTFS-fs error (device sda1): read_ntfs_boot_sector(): Primary boot sector is invalid. NTFS-fs error (device sda1): read_ntfs_boot_sector(): Mount option errors=recover not used. Aborting without trying to recover. NTFS-fs error (device sda1): ntfs_fill_super(): Not an NTFS volume. fdisk viser: gentoo ~ # fdisk /dev/sda The number of cylinders for this disk is set to 48641. There is nothing wrong with that, but this is larger than 1024, and could in certain setups cause problems with: 1) software that runs at boot time (e.g., old versions of LILO) 2) booting and partitioning software from other OSs (e.g., DOS FDISK, OS/2 FDISK) Command (m for help): p Disk /dev/sda: 400.0 GB, 400088457216 bytes 255 heads, 63 sectors/track, 48641 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 1 48641 390708801 7 HPFS/NTFS Går det å få ut alle datane på denne. Eller få tilgang til den, slik jeg slipper og formatere den Lenke til kommentar
comicz Skrevet 9. mai 2006 Del Skrevet 9. mai 2006 Ja, har du testet med nls=utf8, da? -o ro,defaults,umask=0222,nls=utf8 Lenke til kommentar
jensens Skrevet 9. mai 2006 Forfatter Del Skrevet 9. mai 2006 Fikk den samme erroren som jeg fikk uten. Går det ann og konvertere disken over til reiserfs uten og miste noe data? Lenke til kommentar
Silvester Skrevet 9. mai 2006 Del Skrevet 9. mai 2006 Det er mulig du må ha utf-8-støtten i kernel og, hvis den ikke allerede er der. Å kjøre chkdsk på volumet kan også ha sin hensikt. Konvertere fra ntfs til reiserfs er dessverre ikke mulig. Lenke til kommentar
FLuAA Skrevet 9. mai 2006 Del Skrevet 9. mai 2006 Det er mulig å konvertere fra ntfs til fat dog. Lenke til kommentar
