3com (router modem etc) tror det er en feil
Operation Data
Operation Data Upstream Downstream
Noise Margin 10 dB 19 dB
Output Power 4 dBm 18.5 dBm
Attenuation 25 dB 38 dB
Defect Indication
Indicator Name Near End Indicator Far End Indicator
Fast Path FEC Correction 0 0
Interleaved Path FEC Correction 0 0
Fast Path CRC Error 11 0
Interleaved Path CRC Error 0 0
Loss of Signal Defect --- ---
Loss of Frame Defect --- ---
Loss of Power Defect --- ---
Fast Path HEC Error 9 9
Interleaved Path HEC Error 0 0
Statistics
Received Superframes Interleaved 0
Transmitted Superframes Interleaved 0
Received Superframes Fast 6667655
Transmitted Superframes Fast 653046
noen som kan skjønne dette??
ser ut til at det er noe problem med
Fast Path CRC Error
og
Fast Path HEC Error
aner ikke hva dette er, men er det en måte å få fiksa dette på?
nettet er veldig ustabilt..
