BigJackW Skrevet 30. april 2006 Del Skrevet 30. april 2006 (endret) Hei Jeg hoster papMyAdmin fra min maskin. Så nå er det slik at jeg har glemt passordet mitt til den databasen. Er det noe mulig het for å finne tilbake passordet eller kanskje resette passordet.? Det er versjon 2.7.0-pl2 jeg har. Endret 30. april 2006 av BigJackW Lenke til kommentar
BigJackW Skrevet 30. april 2006 Forfatter Del Skrevet 30. april 2006 (endret) ok...jeg fikk det til. Jeg gjorde det på denne måte. [DENNE KAN STENGES] The procedure under Windows: 1. Log on to your system as Administrator. 2. Stop the MySQL server if it is running. For a server that is running as a Windows service, go to the Services manager: Start Menu -> Control Panel -> Administrative Tools -> Services Then find the MySQL service in the list, and stop it. If your server is not running as a service, you may need to use the Task Manager to force it to stop. 3. Create a text file and place the following command within it on a single line: SET PASSWORD FOR 'root'@'localhost' = PASSWORD('MyNewPassword'); Save the file with any name. For this example the file will be C:\mysql-init.txt. 4. Open a console window to get to the DOS command prompt: Start Menu -> Run -> cmd 5. We are assuming that you installed MySQL to C:\mysql. If you installed MySQL to another location, adjust the following commands accordingly. At the DOS command prompt, execute this command: C:\> C:\mysql\bin\mysqld-nt --init-file=C:\mysql-init.txt The contents of the file named by the --init-file option are executed at server startup, changing the root password. After the server has started successfully, you should delete C:\mysql-init.txt. If you install MySQL using the MySQL Installation Wizard, you may need to specify a --defaults-file option: C:\> "C:\Program Files\MySQL\MySQL Server 5.0\bin\mysqld-nt.exe" --defaults-file="C:\Program Files\MySQL\MySQL Server 5.0\my.ini" --init-file=C:\mysql-init.txt The appropriate --defaults-file setting can be found using the Services Manager: Start Menu -> Control Panel -> Administrative Tools -> Services Find the MySQL service in the list, right-click on it, and choose the Properties option. The Path to executable field contains the --defaults-file setting. 6. Stop the MySQL server, then restart it in normal mode again. If you run the server as a service, start it from the Windows Services window. If you start the server manually, use whatever command you normally use. 7. You should be able to connect using the new password. Endret 30. april 2006 av BigJackW Lenke til kommentar
nomore Skrevet 30. april 2006 Del Skrevet 30. april 2006 Sjekk configfila til phpmyadmin. Der står passordet til databasene/serverene. Lenke til kommentar
