Anonym5656 Skrevet 29. april 2006 Del Skrevet 29. april 2006 Har en laptop med Savage skjermkort(VGA compatible controller: S3 Inc. 86C380 [ProSavageDDR K4M266]), og nå kjører jeg vesa driveren i xorg, men syns det går veldig dårlig, og det hakker når jeg skal se på filmer og scrolle i internett sider. Men når jeg skifter til savage driveren i xorg får jeg kunn 640x400(?) i max oppløsning og skjermen ser vrengt ut. Noen som vet hvordan jeg kan få fikset det? (kjører Kubuntu Breezy) Lenke til kommentar
Palme Skrevet 29. april 2006 Del Skrevet 29. april 2006 Hvordan ser din xorg.conf ut? Lenke til kommentar
Anonym5656 Skrevet 29. april 2006 Forfatter Del Skrevet 29. april 2006 Slik(med vesa driverene): # /etc/X11/xorg.conf (xorg X Window System server configuration file)# # This file was generated by dexconf, the Debian X Configuration tool, using # values from the debconf database. # # Edit this file with caution, and see the /etc/X11/xorg.conf manual page. # (Type "man /etc/X11/xorg.conf" at the shell prompt.) # # This file is automatically updated on xserver-xorg package upgrades *only* # if it has not been modified since the last upgrade of the xserver-xorg # package. # # If you have edited this file but would like it to be automatically updated # again, run the following command: # sudo dpkg-reconfigure -phigh xserver-xorg Section "Files" FontPath "/usr/share/X11/fonts/misc" FontPath "/usr/share/X11/fonts/cyrillic" FontPath "/usr/share/X11/fonts/100dpi/:unscaled" FontPath "/usr/share/X11/fonts/75dpi/:unscaled" FontPath "/usr/share/X11/fonts/Type1" FontPath "/usr/share/X11/fonts/CID" FontPath "/usr/share/X11/fonts/100dpi" FontPath "/usr/share/X11/fonts/75dpi" # paths to defoma fonts FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType" FontPath "/var/lib/defoma/x-ttcidfont-conf.d/dirs/CID" EndSection Section "Module" Load "GLcore" Load "i2c" Load "bitmap" Load "ddc" Load "dri" Load "extmod" Load "freetype" Load "glx" Load "int10" Load "type1" Load "vbe" EndSection Section "InputDevice" Identifier "Generic Keyboard" Driver "kbd" Option "CoreKeyboard" Option "XkbRules" "xorg" Option "XkbModel" "pc105" Option "XkbLayout" "no" EndSection Section "InputDevice" Identifier "Configured Mouse" Driver "mouse" Option "CorePointer" Option "Device" "/dev/input/mice" Option "Protocol" "ImPS/2" Option "Emulate3Buttons" "true" Option "ZAxisMapping" "4 5" EndSection Section "InputDevice" Identifier "Synaptics Touchpad" Driver "synaptics" Option "SendCoreEvents" "true" Option "Device" "/dev/psaux" Option "Protocol" "auto-dev" Option "HorizScrollDelta" "0" EndSection Section "Device" Identifier "Generic Video Card" Driver "vesa" BusID "PCI:1:0:0" EndSection Section "Monitor" Identifier "Generic Monitor" Option "DPMS" EndSection Section "Screen" Identifier "Default Screen" Device "Generic Video Card" Monitor "Generic Monitor" DefaultDepth 24 SubSection "Display" Depth 1 Modes "1024x768" EndSubSection SubSection "Display" Depth 4 Modes "1024x768" EndSubSection SubSection "Display" Depth 8 Modes "1024x768" EndSubSection SubSection "Display" Depth 15 Modes "1024x768" EndSubSection SubSection "Display" Depth 16 Modes "1024x768" EndSubSection SubSection "Display" Depth 24 Modes "1024x768" EndSubSection EndSection Section "ServerLayout" Identifier "Default Layout" Screen "Default Screen" InputDevice "Generic Keyboard" InputDevice "Configured Mouse" InputDevice "Synaptics Touchpad" EndSection Section "DRI" Mode 0666 EndSection Lenke til kommentar
kyrsjo Skrevet 29. april 2006 Del Skrevet 29. april 2006 "vesa" er vel igrunn bare en standard-driver som funker på alle skjermkort. Du kan jo seff. prøve å bytte til et mer moderne kort... Lenke til kommentar
Anonym5656 Skrevet 29. april 2006 Forfatter Del Skrevet 29. april 2006 Jeg har jo prøvd og bytte til "savage", men det er da jeg ikke får høyere oppløsning enn 600x400. Lenke til kommentar
kyrsjo Skrevet 29. april 2006 Del Skrevet 29. april 2006 Jeg har jo prøvd og bytte til "savage", men det er da jeg ikke får høyere oppløsning enn 600x400. 6012377[/snapback] Kansje du må manuelt stille inn hvor mye ram kortet har i xorg.conf eller noe slikt? Lenke til kommentar
Anonym5656 Skrevet 29. april 2006 Forfatter Del Skrevet 29. april 2006 Hm.. hvordan gjør jeg det isåfall? Er jo bare vanelig laptop skjermkort.. Lenke til kommentar
FLuAA Skrevet 29. april 2006 Del Skrevet 29. april 2006 Prøv å kjør 'xorgconfig' som root. Da blir du prompta om hvilket kort du har og hvor mye minne. Lenke til kommentar
Anonym5656 Skrevet 30. april 2006 Forfatter Del Skrevet 30. april 2006 xorgconfig ga meg ingen verdens ting.(unknown command) Lenke til kommentar
FLuAA Skrevet 30. april 2006 Del Skrevet 30. april 2006 Merkelig.. har du xorg? For XFree86 var det xf86config som gjaldt tror jeg. Lenke til kommentar
Anonym5656 Skrevet 30. april 2006 Forfatter Del Skrevet 30. april 2006 Merkelig.. har du xorg? For XFree86 var det xf86config som gjaldt tror jeg. 6014256[/snapback] Ja, det er Xorg jeg bruker. Lenke til kommentar
kyrsjo Skrevet 30. april 2006 Del Skrevet 30. april 2006 Hm.. hvordan gjør jeg det isåfall? Er jo bare vanelig laptop skjermkort.. 6012476[/snapback] Husker bare at jeg hadde et S3-kort på en eldgammel stasjonær pc en gang, og det var det eneste kortet jeg ikke har fått til å funke i X med linux (fikk bare "mangefarget skrur"). Dog var jeg totalt uerfaren med linux da og hadde ikke funnet fram til dette forumet. Endte med at jeg bytta skjermkort med en venn som bare skulle bruke konsollet. Lenke til kommentar
Anonym5656 Skrevet 30. april 2006 Forfatter Del Skrevet 30. april 2006 Hm.. hvordan gjør jeg det isåfall? Er jo bare vanelig laptop skjermkort.. 6012476[/snapback] Husker bare at jeg hadde et S3-kort på en eldgammel stasjonær pc en gang, og det var det eneste kortet jeg ikke har fått til å funke i X med linux (fikk bare "mangefarget skrur"). Dog var jeg totalt uerfaren med linux da og hadde ikke funnet fram til dette forumet. Endte med at jeg bytta skjermkort med en venn som bare skulle bruke konsollet. 6014925[/snapback] Ok. Men jeg har brukt savage driverene med Ubuntu(altså ikke Kubuntu) og det funkget helt fint, men nå i Kubuntu vil ikke det ikke funke :\ Lenke til kommentar
kyrsjo Skrevet 30. april 2006 Del Skrevet 30. april 2006 Legg inn ubuntu og installer "kubuntu-desktop"? Lenke til kommentar
Anonym5656 Skrevet 30. april 2006 Forfatter Del Skrevet 30. april 2006 Det må vell være en annen løsning enn det. Det tar jo evigheter også. Lenke til kommentar
LessThanJake Skrevet 30. april 2006 Del Skrevet 30. april 2006 Har du prøvd Xorg -configure, hvis ikke kan du jo boot en liveCD og stjele xorg.conf derifra hvis den funker. Lenke til kommentar
