AuronZ Skrevet 23. juli 2006 Del Skrevet 23. juli 2006 (endret) FF7 BLADES COMPLETE en mod som legger til mange forskjelige ting skjekk i vis/skjul teksten. Skjult tekst: (Marker innholdet i feltet for å se teksten): =======================================-This is me and D Angel's FF7 Blades COMPLETE Mod, and will include; -A quest complete with voice acting, a battle with sephiroth, and more! Please note that this quest will NOT have quest targets, meaning you will have to find the items/npcs ect. on your own. -Transform all the FF7 Cloud Swords made by Imaginalex into Tsurugi Complete. -Switch FF7 Blades to your offhand to get bonuses based on each weapon that boost combat abilities. -Once per day, you gain the strength and power to wield Tsurugi With One Hand, although afterward it Drains your strength, agility, endurance, and speed as an after effect. -A Harness that holds your weapons for you when you are not using them. ======================================= FOR THOSE WHO CAN'T FIND THE LIBRARY! Since I do not have map markers, the lost Library location is just south of the imperial city waterfront district, past the river. ======================================= AN ANOYING BUG! As soon as you get the tsurugi complete u will get a bugged harness. you can fix this by casting the tsurugi transformation spell, and it wont ever happen again. if i am trying to find a way to fix this. ======================================= This Mod will Have the swords -The Core: Apocalypse -The Back: Merciless (The Back: Butterfly) -The Blade: Organics -The Side: Ascalon (The Side: Rune) -Tsurugi Complete Level:-----------<<|1|5|10|15|20|25|30|>> Fortify Strength |3|6| 9|12|14|16|18| Fortify Endurance |3|6| 9|12|14|16|18| Fortify Agility |2|4| 6| 9|11|13|15| Fortify Speed |1|2| 4| 6| 7| 8|10| Fortify Blade |4|8|10|15|20|25|30| -Tsurugi Complete One Handed Same enchantments as the 2h The One Hander is 0.125 Speed higher than The Two hander. But you can only use the Tsurugi One handed ONCE PER DAY!And it is only for 45 Seconds. So Use it Wisely! Afterward you are completely exhausted from the reckless swinging around a 2 handed weapon with just one hand. You will suffer some stat losses that get greater and greater every level. Each one lasts a total of 90 seconds. -Apocalypse: Offhand Level 1: strength 5 and health 10 Incriments of 5|10 per 5 levels. -The Avenger (Butterfly: Offhand) Level1: Endurance 5 and Acrobatics 5 Incriments of 5|5 per 5 levels. -Organics: Offhand Level 1: Agility 5 and Athletics 5 Incriments of 5|5 per 5 levels. -The Sidewinder (Rune: Offhand) Level1: Speed 5 and Blade 5 Incriments of 5|5 per 5 levels. -Souba: After killing Kadaj, you get his Souba, not quite as powerful as the rest of the weapons, but that is the idea. Please note that this weapon DOES NOT LEVEL. -Masamume: After killing Sephiroth, you get the Masamume, very fast, two handed, but low damage to keep balance. Please note that this weapon DOES NOT LEVEL. -The swords all have the proper Reach/weight/damage for there "look" from eachother,but i based the actual damage on my own preferences. -Apon completing the quest you will get the tsurugi complete, the weapon harness, and all the spells used for Tsurugi ect. *Tsurugi Transformation: Transforms the Tsurugi Complete into the 6 blades, and vise versa. *Tsurugi's Reckless Chaos: A spell that will switch the Tsurugi Complete into a one handed weapon for 45 seconds, and can only be used once per day, and afterwards you get stat drains for 90 seconds. *Offhand Switcher: Switches the current weapon you are wielding into an offhand Weapon. ======================================= Installation INSTROOCTIONS-(mispelled on purpose) /Oblivion/Data/Textures/ /Oblivion/Data/Meshes/ /Oblivion/Data/Sound/ /Oblivion/Data/FF7 Blades Complete.esp ======================================= QUEST STARTER LOCATION -The Quest starts in the imperial city market district. The actual name of the quest NPC is Goshingorce ======================================= BUGS AND BUG REPORTING If you are going to report a bug, make sure you know EXACTLY what weapon you had out, what weapon you were switching to, ect. I MUST KNOW EXACT DETAILS TO KNOW HOW TO FIX IT. PLEASE don't make me look for it, I have about 20 scripts to look through. If your going to report a typo or gramar mistake. Please tell me when and where it was, I don't like hearing "There are gramar mistakes, fix them." -When switching a weapon to an offhand weapon, transforming the blades into Tsurugi, Or even Leveling them up not only erases any enchantment on it, but repairs the item as well. Theres no way to fix this. ======================================= CONFLICT ISSUES Any mod that I know of that will conflict with this mod. If you find a mod that conflicts please contact me so I can fix it, or write it in this section. -The Capes And Cloaks Mod WILL conflict with this mod, seeing on how the harness takes up the Tail and Quiver slot. -This Mod WILL conflict with D Angels versions of the mod.(well, the origional version of his just will give you two sets of the swords, mine and his. But the dwarven retexture just won't work with it.) ======================================= v1.0 -initial release.this was origionally the mod from http://www.elderscrolls.com/forums/index.p...=0#entry6306972 v1.1 -fixed a bug that when reverting Tsurugi back into the 5 blades at level 15 or higher that removed "Rune: Offhand" completely -fixed a bug that caused the Tsurugi Reckless Chaos After Affect spell to last longer then it should have. its now properly 90 seconds -Tsurugi Now has its own enchantments. -Tsurugi is now a little faster, and Tsurugi One Hand had the +2 damage i gave it taken away. -Tsurugi One Hand now levels with you, for those that have the ability to level without sleeping. ex. AF Leveling mod. v1.2 -You now can have both The Back: Butterfly, and Butterfly: Offhand v1.3 -Fixed a bug that if upgrading to 1.2 with the Butterfly: Offhand in your inventory already you couldn't get the origional back, you can fix this bug by recasting the Offhand Switcher spell. -fixed a bug where LVL 10 and 15 Butterfly: Offhand was using Runes 10 and 15 enchantment. -fixed a bug where the weight of the new Offhand Weapons wasn't added, causing Tsurugi to Weigh less than the 6 swords. v2.0 -Fixed a few bugs, the ones I can remember are; *Tsurugi One hand actually being two handed *Tsurugi would not transform back if you leveled at 15+ with it out. *Using the Tsurugi One Hand Switcher spell at level 15, it would try to equip the origional Tsurugi instead of the one hand. *Reverting the Organics back to mainhand at level 20 gave you butterfly instead. -Weapons Completely re-done. They are a little stronger, and the weights were adjusted. -The mod now has a quest complete with voice acting! -A Harness was added for the weapons you are not using. -Two new weapons added; Souba and Masamume. -The Tsurugi now has a custom Icon. -A few of the weapons were re-named. v2.1 -Fixed a bug where i obtained retard syndrome and the harness was given imediately. -Removed the harness auto equip feature. v2.2 -Fixed a bug where the hair didn't show properly. -Fixed a few typos, remember...i need the EXACT line if i want to fix any more... -Rebalanced Masamune and Souba. -Fixed a bug where creating a new character gave you no hair or dialogue. (guys i'm not sure that this is fixed, it doesnt happen to me so i have no way of really knowing. -Goshingorces appearance slightly altered. -Kadaj voice removed. It was not playing properly, and we will need him to re-record it before it can be added into the mod again. v2.3 -Tsurugi Icon added, sorry...guess i kinda, forgot to include it? <.< -Kadaj's voice re-added v2.4 -Fixed the French bug, imperial city market district is now properly named. -Offhand Butterfly's texture has been fixed. NOTE: Unless there are more bugs(other then AI) THIS RELEASE IS FINAL. ======================================= CREDITS Thanks to all these people on helping the mod! If i forget someone im sorry! BEEN CODING FOR 2 WEEKS STRAIGHT I CAN'T THINK! -Imaginalex: All the origional Weapon and Harness Meshes. Couldn't have done it without you! -ModelMan: The Re-texture of the Tsurugi. That shiny look makes it all the better! -Neon: The Meshes for Souba and Masamume. Thanks! Quest wouldn't be complete without them. -Ren: The hairs for Kadaj, Sephiroth, and the Remnants. Thanks! Your hairs rock! -Vilvi: Story Writter, Beta tester, Book Artist, and the voice of Sephiroth. Thanks, you were a great help! -DeadGuysRule: Voice of Goshingorce. Thanks! You were the key role in the story! -Dexter: Voice of Raksheno. Thanks! Voice actors are always important! -Freestyle: Voice of Kadaj. Thanks! Finding voice actors sucks =P. -Capucine: The eyes of Kadaj, Seph, and the Remnants. Thanks! Although its not much, its very much still appreciated! -Ramangellion: The Custom Tsurugi Icon. Thanks! Very small detail but every bit counts! Endret 23. juli 2006 av AuronZ Lenke til kommentar
MiSP Skrevet 23. juli 2006 Del Skrevet 23. juli 2006 Hvis jeg hadde fått sett screenshots, hadde det vært mye bedre... Lenke til kommentar
AuronZ Skrevet 23. juli 2006 Del Skrevet 23. juli 2006 har den modden selv. men det er ikke alt som stemmer der. stemmene ble borte på meg men ellers fungerte alt. Lenke til kommentar
MiSP Skrevet 28. juli 2006 Del Skrevet 28. juli 2006 Jeg anbefaler trådstarter (og alle andre for den saks skyld) å ta en titt her. Lenke til kommentar
ZoneBlade Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 Jeg har lett og lett nå en stund etter den modden til oblivion som gir meg et farget kart istedet for det grå, triste kartet som følger med spillet... noen som kan hjelpe meg? Lenke til kommentar
ZoneBlade Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 Tusen takk. sammen med den modden for å få fargede ikoner på kartet, burde dette nå se helt utrolig bra ut:) Lenke til kommentar
skyhawk Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 Tamriel VWD Denne moden gjør at du ikke bare kan se distant land, men også caver, ruins, settlements osv fra laang avstand. Disse fader som regel bort når du går lengre unna, men denne moden gjør at de er synlige. Lenke til kommentar
Morrdi2k Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 (endret) QUOTE(Goz @ 28/04-2006 : ¤¤¤ SNIPP ¤¤¤[/size) 6006784[/snapback] Du har et kraftid utviklet hobbyproblem ja Endret 30. juli 2006 av b-real Lenke til kommentar
Endre visningsnavn Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 Ser at en del av linkene er døde (spesielt mange av linkene til elderscrolls.com forumet), så her en liste med nye linker til de fleste av dem: Qarl's Texture Mod http://elderscrolls.filefront.com/file/Qar...re_Pack_2;64762 Harvest Mod http://planetelderscrolls.gamespy.com/View...s.Detail&id=202 Blue Glass Armor http://planetelderscrolls.gamespy.com/View...s.Detail&id=317 Gray Fox Leather Armor http://planetelderscrolls.gamespy.com/View...s.Detail&id=567 Sentient Weapon http://planetelderscrolls.gamespy.com/View...s.Detail&id=581 Illumination Within http://planetelderscrolls.gamespy.com/View...s.Detail&id=753 Cids Multitude of Magecraft http://www.tessource.net/files/cache/4482.html Evental's Dual Wielding http://planetelderscrolls.gamespy.com/View...s.Detail&id=783 Modder jeg ikke finner igjen: Nirnroot Potion Effect Booster Improved PP Prison Blood Elf Armor Lenke til kommentar
skyhawk Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 ¤¤¤ SNIPP ¤¤¤[/size] 6006784[/snapback] Du har et kraftid utviklet hobbyproblem ja 6578429[/snapback] Hvorfor så frekk? Synes dette var et ganske bra inijativ! Lenke til kommentar
MiSP Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 (endret) Værsåsnill, ikke quote hele verdenshistorien. Endret 29. juli 2006 av MiSP Lenke til kommentar
AuronZ Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 Morrdi2k har du hørt denne setningen før: når du ikke har noe positivt å si så hold munn. Lenke til kommentar
Nitrius Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 (endret) Nå er det en god stund siden jeg sist spilte Oblivion, men nå som maskina mi har fått bedre kjøling tenkte jeg å starte opp igjen. Uansett tenkte jeg skulle linke til en mod jeg brukte som jeg ser på en "must-have" mod. Oscuro's Oblivion Overhaul 1.3 versjonen av modden ser veeldig lovende ut, en av grunnene til at jeg skal begynne å spille igjen Trailer Endret 29. juli 2006 av Nitrius Lenke til kommentar
Morrdi2k Skrevet 29. juli 2006 Del Skrevet 29. juli 2006 Morrdi2k har du hørt denne setningen før: når du ikke har noe positivt å si så hold munn. 6579567[/snapback] Den har hvertfall ikke du hørt! Du hadde ikke noe positivt om meg men du holdt ikke munn! Lenke til kommentar
AuronZ Skrevet 30. juli 2006 Del Skrevet 30. juli 2006 Morrdi2k har du hørt denne setningen før: når du ikke har noe positivt å si så hold munn. 6579567[/snapback] Den har hvertfall ikke du hørt! Du hadde ikke noe positivt om meg men du holdt ikke munn! 6581662[/snapback] jeg gidder ikke å svare engang på slikke barnslighetter. Lenke til kommentar
MiSP Skrevet 30. juli 2006 Del Skrevet 30. juli 2006 Nå er det en god stund siden jeg sist spilte Oblivion, men nå som maskina mi har fått bedre kjøling tenkte jeg å starte opp igjen. Uansett tenkte jeg skulle linke til en mod jeg brukte som jeg ser på en "must-have" mod. Oscuro's Oblivion Overhaul 1.3 versjonen av modden ser veeldig lovende ut, en av grunnene til at jeg skal begynne å spille igjen Trailer 6579784[/snapback] Wow... Håper bare ikke de har puttet alt for mye dilldall i den! Jeg har planlagt å bruke en hel masse mods når jeg begynner å spille igjen (etter jeg har oppgradert PCen), så jeg håper at ikke alle modifikasjonene kræsjer med hverandre... Et par mods som finnes i denne pakken er faktisk også i en annen pakke jeg har tenkt å installere, men det er vel ikke noe problem, ettersom de vil overskrive hverandre. Lenke til kommentar
AuronZ Skrevet 30. juli 2006 Del Skrevet 30. juli 2006 Nå er det en god stund siden jeg sist spilte Oblivion, men nå som maskina mi har fått bedre kjøling tenkte jeg å starte opp igjen. Uansett tenkte jeg skulle linke til en mod jeg brukte som jeg ser på en "must-have" mod. Oscuro's Oblivion Overhaul 1.3 versjonen av modden ser veeldig lovende ut, en av grunnene til at jeg skal begynne å spille igjen Trailer 6579784[/snapback] Wow... Håper bare ikke de har puttet alt for mye dilldall i den! Jeg har planlagt å bruke en hel masse mods når jeg begynner å spille igjen (etter jeg har oppgradert PCen), så jeg håper at ikke alle modifikasjonene kræsjer med hverandre... Et par mods som finnes i denne pakken er faktisk også i en annen pakke jeg har tenkt å installere, men det er vel ikke noe problem, ettersom de vil overskrive hverandre. 6581949[/snapback] skal selv bruke modden men må man betale for å bli medlem i fileplanet? Lenke til kommentar
Went Skrevet 30. juli 2006 Del Skrevet 30. juli 2006 skal selv bruke modden men må man betale for å bli medlem i fileplanet? 6581973[/snapback] De har forskjellige typer medlemskap, bl.a. et som er gratis. Lenke til kommentar
AuronZ Skrevet 30. juli 2006 Del Skrevet 30. juli 2006 skal selv bruke modden men må man betale for å bli medlem i fileplanet? 6581973[/snapback] De har forskjellige typer medlemskap, bl.a. et som er gratis. 6582015[/snapback] ok takker så mye Lenke til kommentar
