AnBa Skrevet 19. april 2009 Del Skrevet 19. april 2009 (endret) Vel, jeg vet ikke helt om den inneholder alt det du vil ha, men med tanke på at vampyr-modusen i vanilla er ganske kjip, så dette er her bedre uansett. Klikk her. Dette får du: Vampire Age: There are five age levels, advancement through them is based on time. Age Level 1 - 7 days to Advance Age Level 2 - 30 days to Advance (37 days from awakened date) Age Level 3 - 180 days to Advance (217 days from awakened date) Age Level 4 - 360 days to Advance (577 days from awakened date) Vampire Powers: Gained at Age 1 * +5 to STR, AGI, END, SPD and Magicka * Water Breathing (dead things don't need to breathe) * Disease Resistance (100) * Sun Vulnerability (variable) * Fire Damage Vulnerability * Nocturnal's Embrace - Increases your F/M/H regen and Resist to normal weapons and Shield. Always active during night * Red Fear - Reduces your physical attributes and gives weakness to fire and normal weapons * Mask Darkness - Activates for 12 hours after feeding. Allows you to toggle vampire appearance on and off. Purly cosmetic and has no affect on stats. Gained at Age 2 * +10 to STR, AGI, END, SPD and Magicka * Blood Feed - Gained at age 2. High mana cast and low damage. Mainly used for feeding only. * Vampiric Suggestion - Will force the NPC to sleep for one minute. They will sleep in any nearby beds if possible, ability will do nothing if there are no beds nearby. Combat or any interaction will interrupt the AI package. * Paralysis Resistance (increases with age) * Resist Normal Weapons (Increases with age) * Mesmerising Gaze - Charm * Regeneration (increases with age) Gained at Age 3 * +15 to STR, AGI, END, SPD and Magicka * Frost Resistance (Increases with age) * Fatigue and Magicka regeneration (at older stages of unlife) * Will of the Undead - Command Humanoid, Command Animal * Shroud of Shadows - Chameleon Gained at Age 4 * +25 to STR, AGI, END, SPD and Magicka * Paralysing Gaze - Paralyse Gained at Age 5 * +50 to STR, AGI, END, SPD and Magicka * Terrifying Countenance - Demoralize and reduces mental and physical attributes Blood Craving / Starvation: * Required to drink blood to survive, each age level has different craving levels (the younger you are the more often you need to drink blood). If you don't drink blood as often as required, suffer consequences. Age Level 1 - Once per day Age Level 2 - Once per two days Age Level 3 - Once per three days Age Level 4 - Once per five days Age Level 5 - Once per week Starvation Consequences: The consequences start off small and increase over time, if you continue to ignore the needs of your vampiric condition. * Fatigue Drain * Appearance/NPC Reaction change * Increased Fire Vulnerability * Personality Penalty * Increased Sun VUlnerability * Normal Weapon Vulnerability Unlockable Powers: Six unlockable powers, unlocked by drinking blood. Drink enough blood and eventually gain these powers. * Scent of Blood - Gained at 25 Bloodpoints. Toggleable power (Detect Life) * Eye of the Hunter - Gained at 50 Bloodpoints. Toggleable power (Night-eye) * Blood Purge - Gained at 75 Bloodpoints. Replaces Blood Feed. Combat feeding spell. More damage and less mana cost. * Power Of Blood - Gained at 100 Bloodpoints. Temporary physical stat increases (higher level version available at older stages of unlife) * Blood Feast - Gained at 150 Bloodpoints also have to be age 4. Area effect aborb health. Will trigger feed upon direct hit. Better damage than Purge but higher mana cost. * Mortis Shield - Gained at 200 Bloodpoints. Temporary armour increase (higher level version available at older stages of unlife) Feeding & Sun Damage Starting at Age Level 2, you can go out in the sun for brief periods of time after feeding. The amount of time you can spend in the sun increases as you age. Sun Resist timer doesnt tick during night. Age Level 2 - Two hours Age Level 3 - Three hours Age Level 4 - Four hours Age Level 5 - Five hours Endret 19. april 2009 av KristofferAG Lenke til kommentar
jaxawier Skrevet 20. april 2009 Del Skrevet 20. april 2009 det er alltids denne og: aundae in cyrodil er f,ø kvalitetsmoddere som laget den, og mulig den blir borte etter hvert da moddene til den ene av dem skulle fjernes fra nettet,forståelig nok. Lenke til kommentar
FreezedOil Skrevet 23. april 2009 Del Skrevet 23. april 2009 Ganske noob med mods, men lurer på om det finnes våpen som gir deg hand to hand lvl og kan enchantes som gjør hand to hand nyttig? våpnene som ser ut som hansker eller brass knuckeles ellerno... Lenke til kommentar
kjermy Skrevet 24. april 2009 Del Skrevet 24. april 2009 Ganske noob med mods, men lurer på om det finnes våpen som gir deg hand to hand lvl og kan enchantes som gjør hand to hand nyttig? våpnene som ser ut som hansker eller brass knuckeles ellerno... Vet om noen hansker som gjør det, og vet hvor dem ligger, iallfall hos meg, med OOO... Klikk for å se/fjerne spoilerteksten nedenfor Ved arenaen er det et par folk som trener for å bli med i arenaen... Der de er, er det en kiste, med hanskene i... Tror det var 25 hand to hand... Verdi på rundt 20 000, så ikke rent billig... Men ops, det er tyveri... Lenke til kommentar
Lommebok Skrevet 6. juli 2010 Del Skrevet 6. juli 2010 Du har glemt 2 utrolig bra mods. Bob's armory og Warcry! Lenke til kommentar
NoNamesLeft Skrevet 21. juli 2010 Del Skrevet 21. juli 2010 Bra tråd! Har akkurat lastet ned en hel haug med mods som skal brukes for å få en bedre spill opplevelse. Lenke til kommentar
Lommebok Skrevet 22. juli 2010 Del Skrevet 22. juli 2010 Ganske noob med mods, men lurer på om det finnes våpen som gir deg hand to hand lvl og kan enchantes som gjør hand to hand nyttig? våpnene som ser ut som hansker eller brass knuckeles ellerno... Vet om noen hansker som gjør det, og vet hvor dem ligger, iallfall hos meg, med OOO... <!--SPOILER BEGIN--><div class="spoilertop" onClick="openClose('2d452bfc2467be11510f89c5d2aa40ad')" style="font-weight: bold">Klikk for å se/fjerne spoilerteksten nedenfor</div><div class="spoilermain" id="2d452bfc2467be11510f89c5d2aa40ad" style="display:none"><!--SPOILER END-->Ved arenaen er det et par folk som trener for å bli med i arenaen... Der de er, er det en kiste, med hanskene i... Tror det var 25 hand to hand... Verdi på rundt 20 000, så ikke rent billig... Men ops, det er tyveri... Når vi er litt ute i offtopic må jeg bare si at man får 25 Hand to hand bare ved og se på di 2 Lenke til kommentar
Gavekort Skrevet 22. juli 2010 Del Skrevet 22. juli 2010 (endret) Lurk heller på Shivering Isles, der fant jeg en ring til 15000. + 25 Hand to hand + 15%(?) Damagereflect Endret 22. juli 2010 av Gavekort Lenke til kommentar
Lommebok Skrevet 22. juli 2010 Del Skrevet 22. juli 2010 Lurk heller på Shivering Isles, der fant jeg en ring til 15000. + 25 Hand to hand + 15%(?) Damagereflect Hvis du lurte på hva "+15% damagereflect" er, så er det at du reflekterer 15% av damagen du får. Lenke til kommentar
aBadMan Skrevet 22. november 2011 Del Skrevet 22. november 2011 Selv om det er lenge siden noen postet her. I dag så kom det en mod til Oblivion, den har vært i utvikling i mange år nå. Jeg og mange andre trodde den var "død". Men her er den. Dark Brotherhood Chronicles Lenke til kommentar
E7ite Skrevet 22. november 2011 Del Skrevet 22. november 2011 Selv om det er lenge siden noen postet her. I dag så kom det en mod til Oblivion, den har vært i utvikling i mange år nå. Jeg og mange andre trodde den var "død". Men her er den. Dark Brotherhood Chronicles Hadde vore greit om dei klarte å få overført den til Skyrim.. Lenke til kommentar
aBadMan Skrevet 22. november 2011 Del Skrevet 22. november 2011 Joda, men hadde blitt litt vanskelig :/ Lenke til kommentar
Thoto79 Skrevet 17. januar 2012 Del Skrevet 17. januar 2012 Noen som vet Nexus Mod Manager er kompatibel til Oblivion og at moddene som allerede er laget (noen er vel flere år gamle) funker i manageren? Lenke til kommentar
-Léon- Skrevet 17. januar 2012 Del Skrevet 17. januar 2012 Noen som vet Nexus Mod Manager er kompatibel til Oblivion og at moddene som allerede er laget (noen er vel flere år gamle) funker i manageren? Mener jeg har brukt NMM til å legge til mods til Oblivion, det er hvertfall et av alternative til spill du kan bruke NMM til. Lenke til kommentar
