Projekt Offset, et fantastisk fantasy-FPS!
Projekt Offset
Dette spillet kommer til å bli fantastisk. Bare bildet over skulle være nok til å gi deg lammelser(positive). Med en sykt fantastisk grafikk, EPISKE omgivelser, genialt gameplay og multiplayer.
Grafikkteknologien er fantastisk(bedre enn Unreal Engine 3) og ble nylig lisensiert av Red 5 Studios(til bruk i et MMO), et spillstudio laget av hovedmennene bak WoW.
Her er litt info om spillet:
"Project Offset" (working title) is a first-person shooter set in an epic fantasy world.
The legendary tale opens with the selection of heroes' classes and appearances and leads the players across a perilous journey through the world. The quests heroes partake in rely on detailed scripting to enhance the drama of key moments within this war saga.
The world consists of sprawling environments that convey the massive scope of this fantasy setting and lead heroes along roads, rivers and natural trails as they uncover dark mysteries within dank caverns, fortified castles and labyrinthine dungeons.
Colossal cities, ancient structures and other war-ravaged settings are the stage of large-scale battles available in both the single-player and multiplayer campaigns.
Treasures will aid collectors in the form of myriad weapons, armour and magical artifacts. Heroes must take care when tampering with the forces of the arcane as magic is still an art full of mystery and unpredictability.
Despite the opportunity to improve heroes' arsenals, the core of combat still relies on the skills of the player and not their gear. The battles of this conflict are not won with weapons but with the skills of those that wield them.
Heroes may band together in cooperative play through the single-player campaign hosted on developer-run servers where persistent experience points and rare artifacts provide a compelling reason to relive the adventure again and again.
Litt om multiplayermodusen:
The high adventure contained within Project Offset's (working title) multi-player campaign emphasizes cooperation and strategy in a frenetic contest between two teams vying to complete set objectives across vast battlefields. Honor and untold treasure may be seized by heroes while acquiring experience points throughout battle that allow players to purchase further character customizations on their legendary path toward glory.
Allied heroes mutually work toward common goals as castle walls are breached, reinforcement positions are held and mighty siege engines are escorted toward their tactical positions. Employing ferocious beasts of burden, experienced heroes ride into battle on the wings of fire-breathing dragons to rain down death from above or charge into the fray on swift steeds to trample their enemies under hoof. The variety of exotic creatures offers many options for the cavalry-minded player.
The theatrical score and life-like ambience help set the tone for this truly cinematic experience that transports players into the thick of a battle between the forces of darkness and light. Project Offset (working title) takes full advantage of next-generation PC and console hardware with the phenomenal "Offset Engine" under its hood; designed from the ground up to immerse players in the action-packed adventure that will set a new benchmark for epic fantasy in the digital world.
For mer info om spillet, burde hjemmesiden www.projectoffset.com besøkes!
Ellers anbefaler jeg alle å se videoene. Her er de(men ikke i HD, besøk internettsiden hvis du ønsker det):
Sneak Peak 1(Gammel)
Sneak Peak 2
TV-reportasje med mye forskjellig.
Som dere sikkert skjønner, gleder jeg meg sinnsykt til dette spillet.
Endret av Kris R
