404 på en fil som faktisk allerede finnes
fikset nå.
To permit IIS to serve content that requires a specific ISAPI or CGI extension that is already listed in the Web service extensions list, follow these steps:
1. Open IIS Manager, expand the master server node (that is, the Servername node), and then select the Web service extensions node.
2. In the right pane of IIS Manager, right-click the extension that you want to enable. In this example, this is Active Server Pages.
3. Click to select the Allow check box.
